Welcome to the North American Subaru Impreza Owners Club Sunday May 31, 2020
Old 07-13-2005, 08:26 AM   #1
singsing
Member#: 36991
2003 Liberty B4
blue
Default what is turbine clipping and what does it do?
as per the subject...
im seriously itching to get a sz55 with the fatboy turbine... but it costs a little more to get the turbine wheel clipped
what does this mean exactly and what does it provide in terms of power/spool etc...
thanks
singsing is offline   Reply With Quote
Old 07-13-2005, 08:49 AM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Don't get it clipped. Clipping is a poor man's way of increasing the flow through the turbine by actually clipping the exhaust wheel's blades. This reduces drag, but it ruins the aerodynamics of the wheel and kills spool, all for a little better top-end potential.
Garrett strongly recommends never clipping a wheel - just buy an appropriately sized turbo for your needs, don't screw with the turbo designer's millions of dollars in R&D that came up with the ideal wheel shape.
serendipity is offline   Reply With Quote
Old 07-13-2005, 08:52 AM   #3
Project Rex STi
Member#: 77249
04 STi
Agreed.
Project Rex STi is offline   Reply With Quote
Old 07-13-2005, 12:10 PM   #4
pux888
Member#: 8356
02 STi swap
12 WRX limited
most of DB's 20g come w/ a 10 degree clip now, do you guys feel thats a bad thing? if you running a stock location turbo you can deal w/ so much backpressure before it becomes a problem, especially on the 2.5.
pux888 is offline   Reply With Quote
Old 07-13-2005, 04:03 PM   #5
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Its internet fokelore that clipping is bad no matter the circumstance. Garretts position is that you no longer need/have to do this as they have newer GT wheels. If you choose the right product you no longer have to make a compromise. Garrett does offer factory clipped wheels right in the catalog.
Most Mitsu hybrid turbos use a clipped 5H or 6H turbine wheel. This is done as the 7cm housing is far to small. The solution was to clip the wheel to increase flow. Its been done for years and years. while it can reduce the effectiveness of the turbine and lowers Shaft trq, it does increase flow. In this case the flow increase FAR outweighs the loss in power to the shaft.
It is also internet fokelore that clipping a wheel increases lag or slows spool as a rule. In our application it actualy helps spool producing more power every where in the RPM band. While its generaly known that clipping a wheel helps top end (which it can do), clipping can many times help spool. This has been tested back to back with a Td05/50trim turbo (green) when run on our EJ motors. The clipped wheel produced 40ft lbs more in the middle(from memory) and had more power everywhere. Top end power stayed the same. Jarrad from PDX Did alot of testing last year and might even have those charts still.
Clark
AZScoobie is offline   Reply With Quote
Old 07-13-2005, 04:21 PM   #6
pux888
Member#: 8356
02 STi swap
12 WRX limited
thanks for the info thats just what I was waiting to hear, as my turbo is about to be shipped out for a nice clip! How much did you guys go w/ on the green 10-15 deg?
Old 07-14-2005, 04:20 AM   #7
singsing
Member#: 36991
2003 Liberty B4
blue
ooook... so a clipped sz55 is better than an unclipped sz55?
Old 07-14-2005, 11:06 AM   #8
pux888
Member#: 8356
02 STi swap
12 WRX limited
i would think it would require a clip if your using the 6h. with the fatboy trubine its fine.
Old 07-14-2005, 01:46 PM   #9
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
the turbine on my deadbolt 20g wes very subtle.
more of a shear than a clip... i'm sure if you ask jerry about it he will give you the lowdown.
i have no problems with spool...... whatsoever...
DISCOPOPE is offline   Reply With Quote
Old 07-14-2005, 02:23 PM   #10
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
+1
That makes two of us. When I inspected the turbine wheel prior to installation you could barely even tell it was clipped. Spooling and boost response in partial throttle situations are both excellent with my 20G.
SilverSurfer04STi is offline   Reply With Quote
Old 05-20-2020, 11:41 AM   #11
Jedi03
Member#: 491095
2009 STi Blue
how does this improve vs porting the housing?
Jedi03 is offline   Reply With Quote
Old 05-22-2020, 06:45 AM   #12
bp05obxt
Member#: 459799
Porting a housing only improves inlet flow or how the exhaust pressure is introduced to the turbine wheel. Clipping is about flow though the turbo. Essentially the turbine wheel and housing A/R become a choke point and prevent the turbo from making power at some point. Clipping the wheel removes part of that choke allowing the turbo to potentially generate more efficient flow and boost at a higher rpm; generally.
In aftermarket turbos there are various different size A/R options for turbine housings. These housings will fit the same turbo, but allow the turbo to be tuned to a specific need. Garrett is a perfect example; just in TiAl housings alone there are .63/.82/1.03 A/R. V-band housings for a 35r. Each of which are interchangeable to I crease or decrease flow through the A/R of the turbo and past the turbine wheel.
In short porting can gain you spool and response, but increased flow through the turbo via clipping or increased A/R will decrease choke and increase efficiency into high rpm.
Ill always go for increased A/R over clipping. Most aftermarket turbo options available today have largely improved aero and housing designs that factory turbos cant compete with. The idea of clipping a turbine wheel and potentially compromising overall performance for a little gain up top just isnt my preferred method. 9/10 times Id go aftermarket even with the increased costs.
bp05obxt is offline   Reply With Quote
What is Variable Turbine Geometry and how does it work? ka mano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 10-22-2011 04:16 AM
What is this hose and where does it go? Sputt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-08-2009 09:31 PM
STi: What is this part and where does it go? benyl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-18-2006 02:58 AM
what the hell is SBF 5 and why does it keep blowing? jared nelson Electrical & Lighting 3 05-04-2005 07:52 AM
Isnt this arik's car and why does it do that? STi Sev General Forum Archive 8 05-15-2000 08:25 PM
