Welcome to the North American Subaru Impreza Owners Club Sunday November 29, 2020
Old 11-18-2020, 05:32 PM   #226
quentinberg007
Member#: 7887
2016 Red Car
2019 Blue Car
IMO, it is a characteristic of the dual VVT. When the valve timing is set for good torque at low RPM (gas mileage, daily driving) and good power at high RPM (performance), the mid band doesn***8217;t get any optimization. If this engine maxed out at 6500RPM, the timing target points would be different in the VVT and there would be more overlap. I***8217;m fine with it just like I was with the old car. Drive for efficiency or give it the beans. No half measures.
quentinberg007 is offline   Reply With Quote
Old 11-18-2020, 05:36 PM   #227
littledrummerboy
Member#: 94408
17 STI Sport-Tech
20 Corolla Hybrid Premium
Or is it characteristic of D4S in the boxer somehow. Not necessarily by design, but as a consequence somehow when managing the injectors and which does what, when.
littledrummerboy is offline   Reply With Quote
Old 11-18-2020, 05:36 PM   #228
JP Chestnut
Member#: 504432
Did the old VTEC Honda 1.6/1.8/2.0 have a dip like that? I don't remember anyone complaining about it.
JP Chestnut is offline   Reply With Quote
Old 11-18-2020, 05:42 PM   #229
Kostamojen
Member#: 2272
1999 2002 WRX Donor
93 FWD Base Impreza Autox
Did anyone else notice the factory oil cooler???
That was the first major mod I did with my 2013, and it makes a big difference with this motor. Glad its included now.
Every N/A Subaru boxer has had a torque dip at that same area, it was just more pronounced with the BRZ being small displacement and low torque to start with.
I blame the intake manfiold and header design, mostly the intake manifold. Porsche alleviated their torque dips with variable intake manifolds.
Old 11-18-2020, 05:56 PM   #230
littledrummerboy
Member#: 94408
17 STI Sport-Tech
Interesting. Guess I never really noticed it in the NA boxers Iíve had. But those have all been auto/cvt too so I wasnít exactly using it for performance.
Old 11-18-2020, 06:00 PM   #231
quentinberg007
Member#: 7887
2016 Red Car
2019 Blue Car
Their VVT timing advance and retard targets for the intake and exhaust cams would have not been nearly as aggressive as the FA20 and FA24. There is a reason that the FB20 and FB25 only made 160 and 190hp.
Old 11-18-2020, 06:01 PM   #232
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
Originally Posted by WRXnick16 View Post
Compared to the Gen 1 and ND2 Miata:
Power-to-weight for the lightest models:
BRZ Gen1: 2798 lbs/205 hp = 13.65 lbs/hp
ND2 Miata: 2341 lbs/181 hp = 12.93 lbs/hp
BRZ Gen2: 2815 lbs/228 hp = 12.35 lbs/hp
[/b]
Just to be complete for a more "hardtop" comparison, since not everyone wants a convertible:
ND2 Miata RF: 2452 lbs/181 hp = 13.55 lbs/hp
subyski is offline   Reply With Quote
Old 11-18-2020, 06:07 PM   #233
quentinberg007
Member#: 7887
2016 Red Car
2019 Blue Car
And then of course the new found torque:
BRZ Gen1: 156 lb-ft @ 6400 RPM
ND2 Miata: 151 lb-ft @ 4000 RPM
BRZ Gen2: 184 lb-ft @ 3,700 RPM
The FA20 made near peak at ~3000RPM, too.
Old 11-18-2020, 06:10 PM   #234
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
rear seats are good for insurance.
you can fold them down easily and (at least on the existing car) they fold flat.
Indeed. If folds flat, that sounds good. Can hear the exhaust better too.
oichan is offline   Reply With Quote
Old 11-18-2020, 06:17 PM   #235
JP Chestnut
Member#: 504432
I need a rear seat. Even if itís vestigial I can still push the passenger seat all the way forward and fit my daughters booster in the back in a pinch.
Old 11-18-2020, 06:29 PM   #236
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
Yeah, nobody cared about the torque dip in the old NA EJ25s because there was still plenty of torque in the dip (it was more like a 5% dip where the FA20 had a 10% dip). it was only really evident on a dyno chart. Most butt dynos weren't tuned with a precise enough sensor and the stock UEL headers made a nice little rumble that made everything more forgivable.
This new dash dyno chart and the official figures suggest a better breathing engine than the last NA Civic Si (K24)... and those motors were a delight. I loved my 2.4L ILX. It was quite a quick car.
Watch, the 5-60mph tests for the new BRZ are going to be impressive.
The old K24 Civic Si had a 5-60 of 6.4s with a similar curb weight and a lot less torque.
BRZ: 7.2s
WRX: 7.0s
STI: 7.1s
ND1: 6.6s
ND2: 6.5s
A lot of stock WRX owners are going to start to feel insecure about their turbo performance after driving a BRZ.
Old 11-18-2020, 06:41 PM   #237
Straight6
Member#: 419593
BRZ: 7.2s
WRX: 7.0s
STI: 7.1s
ND1: 6.6s
ND2: 6.5s
Doubt it, WRX can be quicker.
2015 WRX 6 MT
5-60 6.3
https://www.caranddriver.com/reviews...l-test-review/
2015 WRX CVT
5-60 6.4
https://www.caranddriver.com/reviews...c-test-review/
Straight6 is offline   Reply With Quote
Old 11-18-2020, 06:41 PM   #238
fathatch
Member#: 278626
2001 S2000
Regarding the torque dip, this is not unusual behavior for a N/A four cylinder. In fact there's a torque dip on my AP1 S2000 (when stock) of about 5% from 3500 to 6000. I owned a SVT focus that exhibited similar behavior (Even with a variable length intake manifold). The magnitude of the dip was just more significant on the BRZ.
fathatch is offline   Reply With Quote
Old 11-18-2020, 06:43 PM   #239
oichan
Member#: 492327
19 WRX 16 STI
The new torque dip is acceptable for me if that line is an actual data from the new engine.
You okay? This post and the other post stating 'Accords are gorgeous'? You on something?
Old 11-18-2020, 07:23 PM   #240
Calamity Jesus
Member#: 44501
that 's, like, your
2015 WRX 6 MT
5-60 6.3
2015 WRX CVT
5-60 6.4
I was using R&T's numbers: https://www.roadandtrack.com/new-car...ru-wrx-vs-sti/
but C&D's own test of the '18 WRX shows the same 7.1s: https://www.caranddriver.com/reviews...e-test-review/
Old 11-18-2020, 07:48 PM   #241
JP Chestnut
Member#: 504432
It's almost like both the WRX and the STI got slower in 2018 refresh.
Old 11-18-2020, 07:48 PM   #242
Calamity Jesus
Member#: 44501
that 's, like, your
The R&T numbers were for the 2015 cars.
Old 11-18-2020, 08:16 PM   #243
Altephor
Member#: 429442
2016 WRX Limited
CWP
Oof, hate the redesign.
Biggest pet peeve is the back end, completely ruins the lines of the car. You have the beautiful widening rear fenders and then it looks like someone pinched the back of the car so it wouldn't be 'too wide'.
Might have been saved with a wide, flat spoiler extending out like the outgoing models had but that lip monstrosity is terrible.
Looks like someone tried to design a Porsche on a Honda budget.
Altephor is offline   Reply With Quote
Old 11-18-2020, 08:25 PM   #244
Shapingo
Member#: 324291
2015 WRX
I think it looks a lot better on film than in still pics
Shapingo is offline   Reply With Quote
Old 11-18-2020, 08:41 PM   #245
JP Chestnut
Member#: 504432
I'm still not in love with the appearance, but I bet a tS or STI version would look great. It needs to big wing from the older tS to balance out the more aggressive front lip.
Old 11-18-2020, 08:45 PM   #246
DougNuts
Member#: 192568
2015 Outback 3.6R
2018 F150 3.5TT
I always assumed the torque dip was due to fueling and timing strategies in place to help fend off knock.
DougNuts is offline   Reply With Quote
Old 11-18-2020, 08:46 PM   #247
Pre
Member#: 139693
Will check insurance tomorrow. If my speciality carrier will do it, f me I may be buying one and putting a deposit down. In silver. Anything more than 2 doors I cannot insure cheap so it may be time to whip it out and get another car! I like it a lot. I love the looks, and the power bump may be just enough until the blower comes out for it
Old 11-18-2020, 09:04 PM   #248
dwf137
Member#: 161333
18 Highlander
Yami XSR
this thing looks great.
not sure I could swing it with a family of four, but I'll give it some thought.
Old 11-18-2020, 09:14 PM   #249
chanomatik
Member#: 159474
2017 Impreza Sport
Lithium Red - OLDKID
I think THIS is the BRZ to get for anyone who's been holding off. I don't know if I'd buy another one, but if I did I'd certainly get the tS version.
Old 11-18-2020, 09:32 PM   #250
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
.. and the power bump may be just enough until the blower comes out for it
Forced induction will be difficult with the 13.5:1 compression ratio. Maybe a bit of boost on E85.
A supercharged FA24DIT in a ~2850 lb BRZ does sound appealing
I think we'll see some decent gains in NA form with bolt-ons and E85 to take advantage of the high compression ratio.
WRXnick16 is offline   Reply With Quote
