Welcome to the North American Subaru Impreza Owners Club Wednesday December 2, 2020
Old 11-01-2020, 11:50 PM   #1
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Default 2007 WRX with 275k miles P2021
I have a stock (engine anyway) early 2007 WRX, and I am now throwing the P2021 "Useless sensor on unneeded part reads wrong. No cruise for you" code. When I search, the forum only shows this for TGV deletes and I have mine. It is the driver side. I pulled the sensor and reinstalled with the 90 degree clock, and I thought it was fixed! For about 5 minutes... I have no drivability issues. At least no new ones. I have a full throttle stumble that I thought was the MAP sensor, but replacement only made it a little better... But that is several years old, and the P2021 is new.
So I need...
Troubleshooting steps to know if it is the sensor in the front or the weird valve Rube Goldburg device in the rear. If the sensor, what is the part number? The diagrams only show the valve thing! And how is the person to slap for putting all the pipes in front of the screws on this thing? Sigh...
PS: Engine only has 70k miles. A rod let go at just under 200k. But most of the bits on it are old.
bofh is offline   Reply With Quote
Old 11-02-2020, 11:15 AM   #2
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
So I need...
If you're just looking to replace the sensor, here's a link to one that should suit your car:
https://www.fastwrx.com/products/sub...tgv-tps-sensor
BeastianSTI is offline   Reply With Quote
Old 11-02-2020, 11:37 AM   #3
Jp925
Member#: 510046
Swap the sensor with the other bank, if you have an accessport you can monitor left and right side sensor measurements to see if itís A. working and B see if it moves to give the error on the other side.
The tgv sensors are actually Toyota TPS sensors, After a little bit of digging I actually got one from autozone for about $18.
Jp925 is offline   Reply With Quote
Old 11-02-2020, 12:07 PM   #4
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
I wasn't sure if they were side-specific or generic. If they're all the same then def look at swapping one side to the other like jp said
Could also be worth inspecting the wiring and connectors. I recently had to replace my engine wiring harness because there were a bunch of random breaks in the wiring. My car is at 155k too (far less than OPs).
Old 11-02-2020, 01:47 PM   #5
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
With the access for the other side, I would rather buy one! Anyone have a part number for the Autozone version?
Old 11-02-2020, 04:56 PM   #6
Jp925
Member#: 510046
looking now, I might have to call them.
Old 11-02-2020, 05:13 PM   #7
Jp925
Member#: 510046
this is the one I bought
TPS4117
Old 11-02-2020, 10:11 PM   #8
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Worth risking $70 to not have to get the back one on the passenger side! Especially if it fixes it!
Old 11-05-2020, 03:23 PM   #9
Jp925
Member#: 510046
any luck?
Old 11-08-2020, 01:45 PM   #10
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Today is my first day off... Gonna try!
Old 11-21-2020, 11:12 PM   #11
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Forgot to follow up. Seems to work well! Thanks for the help!
Old 11-22-2020, 06:30 PM   #12
Jp925
Member#: 510046
Awesome!
