Welcome to the North American Subaru Impreza Owners Club Wednesday December 2, 2020
Old 11-18-2020, 07:41 PM   #1
dahoseman
Member#: 330468
1932 Ford Model A
Default Turbo Swap Into NA?
I didn't see a satisfying answer to this already.
I have a 2005 Outback XT with an STI drivetrain. The body has taken a real beating over the years and a lot of suspension and body parts have been falling apart, so I was already thinking of swapping my drive train into a Forester XT. Several parts crapped out recently, so it's time to abandon XT.
I recently found a similar generation 5sp Forester that had an engine failure, which would be a good 'shell'.
Does anyone know how difficult it would be to swap a turbo drivetrain into a NA vehicle?
Are the wiring harnesses compatible?
dahoseman is offline   Reply With Quote
Old 11-20-2020, 03:06 PM   #2
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Us guys on the legacyGT.com forum have told many new guys over many years, if you want a turbo car, buy a subaru that came with a turbo, there is to much work involved in the swap and you still don't have everything the turbo car came with.
Max Capacity is offline   Reply With Quote
Old 11-20-2020, 04:15 PM   #3
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
There's many things to consider here. For one, Subaru made changes to the fueling system between 05/06 depending on which model you're looking at. There's the issues or wiring when dealing with single vs dual AVCS (depending on what year XT you have), finding the proper front subframe for the car you're swapping it into, differences in axle/driveshaft length between the outback and forester, etc. As stated, it's easier to buy a chassis that was originally a turbo model and swap everything in. It's not hard to find one with a blown engine and go from there.
snow_bound26 is offline   Reply With Quote
