05-09-2017, 07:58 PM | #1 |
Member#: 103539
Vehicle:2015 STi Limited |
Stock EJ255 VF52 on E85 Owners Only! Please chime in!
Just curious to know how many ej255 owners with a vf52 on e85 still have their motors running with no issues. Please answer the following....
-How long have you been on e85? -Did your motor blow or is it still running strong? -whp/wtq figures.
05-10-2017, 01:03 AM | #2 |
Member#: 446267
TXIC
Vehicle:2014 WRX Premium Dark Grey Metallic |
I have a 2014 WRX on E85 making 330whp 400wtq. Had it at that level for 8k miles and the motor has been running fairly well but I haven't driven any other subies before.
As for the motor... I think it's fine but I've been monitoring my coolant overflow because it's pushing coolant and overflowing into the engine bay when pushed hard. I've been told it might be early signs of head gasket failure, but I got a koyo radiator in hopes that my stock one was beginning to leak. |
05-10-2017, 06:29 AM | #3 |
Member#: 103539
D3LTAwrx how many psi of boost are you running?
05-10-2017, 06:19 PM | #4 | |
Member#: 171948
Vehicle:19 Sti Crystal white |
05-10-2017, 06:23 PM | #5 |
Member#: 333315
As above. 332 whp 15k miles on E85 only and loving it. Doing 3 autoX, performance driving events/yr with no problems. 2009 wrx 60+k miles on the engine. I add ethanol cleaner every 3 months for whatever it's worth...91 map is 19psi e85 is 21. It has been stage 2 on 91 for 30k miles.
05-10-2017, 09:29 PM | #6 |
Member#: 103539
Taxkourel how much wtq are you making??
05-12-2017, 08:03 AM | #7 |
Member#: 333315
376 on e70 (never tuned for true e85) 340 on 91
05-13-2017, 09:53 PM | #8 |
Member#: 103539
Nice numbers!! What ethanol cleaner do you use? Do you go back and forth from pump to e85 often?
05-13-2017, 11:14 PM | #9 |
Member#: 333315
Gummout! Haven't really researched this though.nope ethanol all year long! I would not hesitate if i were you. This is a "tried and tested" solution for subarus. :-)
Addendum Just realized you ve been running ethanol:-) Last edited by taxkourel; 05-13-2017 at 11:36 PM. |
05-14-2017, 10:21 PM | #10 |
Member#: 103539
05-27-2017, 01:06 PM | #11 |
Member#: 467972
isn't the vf52 from the legacy gt?
06-09-2017, 08:36 PM | #12 |
Member#: 417552
Vehicle:07 wrx limited |
320hp 350lbs torque with a vf48 on e85 for the past 8k miles and motor is running strong I'm above 110k miles
06-09-2017, 08:38 PM | #13 |
Member#: 171948
06-13-2017, 09:14 PM | #14 |
Member#: 467938
Vehicle:2011 STi Grey |
I know this is for owners only but I am interested in the
longevity of engines and e85. From my research I can add that they seem fairly reliable with some large mileage figures (post 100000). I also note that as long as your source of e85 has a consistent rating you will see good numbers in the performance department. Up to 30% plus when compared to a vehicle with same mods running gasoline. |
06-13-2017, 11:25 PM | #15 |
Member#: 446267
TXIC
Sorry for the late response, but i'm running 20psi
Still pushing coolant after replacing the radiator =( I just made a thread so hopefully someone can help me out: https://forums.nasioc.com/forums/sho....php?t=2842564 |
06-14-2017, 08:38 AM | #16 |
Member#: 77863
South East
Vehicle:2013 WRX WRB |
2013 WRX
340whp 370wtq, E75 22psi 8.5k miles Still going.... |
06-14-2017, 12:15 PM | #17 |
Member#: 446267
TXIC
06-14-2017, 03:29 PM | #18 |
Member#: 77863
South East
Cobb AP v3
Cobb SF+ Intake Cobb Flex Fuel Kit w/ FP Sensor Invidia Catted DP Invidia Q300 Grimmspeed EBCS Grimmspeed TMIC Injector Dynamics ID1000 Injectors DeatschWerks DW300C Everything else is stock. |
06-14-2017, 04:44 PM | #19 |
Member#: 372777
SCIC
Vehicle:2014 WRX Sedan Lmtd WRB |
Mine went out within a month. Baseline 91 came back with 50 less whp, but the E85 tune came out to 330/400. Car gave no issues of it going out, I was maxing out 4th one day and when I got off the highway I heard ticking. When I got back on to go home, it was a spun rod.
I never found out what caused it, but I never had any tune issues on E85. I cant wait to finish breaking in the new engine. |
06-14-2017, 05:59 PM | #20 |
Member#: 446267
TXIC
10-17-2017, 06:38 PM | #21 |
Member#: 427123
SCIC
Vehicle:2008 WRX |
I just swapped to flex / e85 yesterday, got the protune done in the morning with perfect SoCal weather.
2008 wrx Bone stock with a TBE ; dyno @90k miles (dyno dynamics) 208whp 222tq on 93pump Add VF52 new shortblock ARP head studs forged pistons PW Verticooler 3port ebcs invidia catless DP walbro 255 dyno (dyna pack) 270whp 308tq on 91ACN Added Cobb Flex Kit ID1050x injectors dyno (dyna pack) 311whp 360tq :tup: the propel station i went to got 75% ethanol based on the cobb sensor, car feels like a new animal with all that torque. im very happy with the car, on a conservative tune as it is a DD, and the corn is only 2.10$ so significantly cheaper then the ****ty 91 acn |
10-19-2017, 12:42 PM | #22 |
Member#: 372777
SCIC
-How long have you been on e85? 1 month
-Did your motor blow or is it still running strong? 1 month -whp/wtq figures 360ish/400whp I should have upgraded oil pan before hitting the canyons lol, spun bearing. |
11-12-2017, 06:15 PM | #23 |
Member#: 103539
Update!
-How long have you been on e85? 8 months -Did your motor blow or is it still running strong? Still running strong -whp/wtq figures. 370whp/390wtq |
12-18-2018, 03:13 AM | #24 |
Member#: 417552
update. still same power. only use E85 fuel for past 2+yrs, @135k miles and on this setup.(vf48, id1000, walbro255, sti intercooler, protune.) runs like champ. has hiccups every now and then. new timing belt, plugs, coils. but now possibly pulley going out. (under boost sounds like I'm supercharged..) but motor over all is pretty solid. (high hopes) and will continue to daily corn. had set up for 32k miles so far. still pulls as hard as ever.
12-18-2018, 09:47 AM | #25 |
Member#: 77863
South East
