Brakes & Suspension Forum sponsored by The Tire Rack |
05-08-2006, 12:35 PM | #1 |
Member#: 92852
Impreza Front lateral link vs. rear lateral link
Car: Impreza coupe 1995 ej18 AWD
Are the front and rear lateral link the same on Impreza that came without rear sway bars? One of the front lateral links is bend and I am in the process of sourcing rear lateral links with sway bar mounts. So it would be great if I din’t have to get a front lateral link if I can just use on of the original rear links to the replace the bent front one. Thank you in advace for any relevant information.
05-08-2006, 04:57 PM | #2 |
Member#: 53625
Vehicle:00 16' FXT |
only the rears have the mount, you can use the back one on the front!
05-08-2006, 05:12 PM | #3 |
Member#: 92852
thank you, just wanted someone to confirm my conclusion
05-08-2006, 05:30 PM | #4 | |
Member#: 71875
Neither did mine and I swapped them. I wrote it up here, it might be helpful. The only difference is that you don't have to worry about tire well clearance. |
05-08-2006, 06:04 PM | #5 |
Member#: 66739
Vehicle:2002 WRX wagon silver |
same one, i had a bent one, and just heated it up while in place, and used a handheld sledgehammer. viola! problem solved. mine wasn't too terribly bent, so use your best judgement! --keith
05-08-2006, 06:54 PM | #6 |
Member#: 92852
I just took them out both front and back lateral links and put them side by side, if i had not marked it a market I wouldn't be able to tell the difference. So the answer to my own question is
Yes the front and rear lateral links in an impreza without a rear sway bar are the same. thank you all for the input |
Similar Threads | ||||
Perrin Lateral Links vs. STI Lateral Links | Umphreys448 | Brakes, Steering & Suspension | 22 | 10-10-2018 05:20 PM |
Front O2 sensor vs Rear O2 sensor (MY00 RS) | Jewbaru | Service & Maintenance | 3 | 07-29-2012 10:14 PM |
WTB:05+ STI Aluminuim rear lateral links | ronzogonzo | MWSOC Private Classifieds | 2 | 12-11-2009 05:23 PM |
WTB: 02-05 WRX front control arm and rear lateral links | qtr_wrx | Private 'Wanted' Classifieds | 7 | 06-21-2006 02:59 AM |
97 outback sport rear lateral link/poly bushings Q's | jhew84 | Brakes, Steering & Suspension | 7 | 01-26-2006 08:15 AM |
