04-12-2006, 03:01 PM | #1 |
Member#: 112396
Vehicle:1997 Impreza OBSW Green |
2.2 Cylinder Heads Help required
I have a 97 Impreza Outback Sport Wagon, 2.2l non turbo, the previous owner broke the exhaust manifold mounting stud off the cylinder head . . . need to replace head.
Have not be able to find a single exhaust port head, but found a set of dual port exhaust heads. Will these work on the existing engine if I replace the exhaust manifold with a set of headers? (i.e. Borla 17183?) Thanks for your help!
04-12-2006, 03:36 PM | #2 |
Member#: 54525
Vehicle:2000 ej20g rs blue ridge pearl |
It will work, but there may be wiring involved, as long as they're the same ie.sohc or dohc you should be okay. Have you tried to have someone drill out the broken stud?
04-12-2006, 04:28 PM | #3 |
Member#: 112396
The stud is totally gone and took part of the head casting with it. It was then covered with sealer and I didn't notice it when I bought the car. It has 115K on it so I decided to replace the timing belt/water pump to avoid this at a more critical time, that's when I noticed this.
FS:CT-2003 Subaru Wrx 2.0 Cylinder Heads/ New STI Head Bolts | 98SubbyLeg | Engine/Power/Exhaust | 10 | 11-12-2011 10:42 PM |
Identifying 2.5L cylinder heads??? | WRXINTX | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 07-21-2006 09:09 AM |
2.5L cylinder head | lovemylegacy | Private 'For Sale' Classifieds | 5 | 04-18-2006 01:31 PM |
2.5L cylinder head | lovemylegacy | Private 'For Sale' Classifieds | 2 | 04-07-2006 12:36 PM |
99 2.5 cylinder heads/intake manifold for sale | soslow | Private 'For Sale' Classifieds | 2 | 09-18-2005 07:36 AM |
