Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 05-01-2009, 02:25 AM   #1
sagelwwa
Member#: 53975
2004 Forester XT
Java Black Pearl
Lightbulb How-to: Cleaning ABS Speed Sensors
It has become apparent that one of the main causes for DCCD issues with the STi is brake dust coated ABS speed sensors. Whether you have an STi with DCCD or not, cleaning your sensors is a good practice. Unfortunately, with all of those out there who tell others to 'clean your speed sensors' no one seems to have a how-to or post about it. There are many others who believe they need their sensors cleaned, but have not even tried because they have no idea what is involved. The good news is that it is a simple practice and can be done very quickly!
BEFORE: (see below for link to pics)
AFTER: (see below for link to pics)
Cleaning Rear ABS Speed Sensors (2004 STi):
Need: 12mm socket, extension, ratcheting wrench, towel/cloth, cleaner such as Simple Green (many will work)
  1. Jack using the rear differential. Always properly support the vehicle with jack stands and wheel-chocks as well.
  2. Locate rear ABS speed sensor on the dust shield on the back of your rotor. The sensor is on the side closest to the front of the car. It is being held in by one bolt and has black wiring leading to it.
  3. Remove the bolt with the 12mm socket/wrench
  4. Pull the sensor out and proceed to clean the brake dust buildup off. I used Simple Green Motorsports Version sprayed onto a microfiber towel.
  5. Replace the sensor and tighten the bolt.
  6. Repeat for the other rear speed sensor.
  7. Carefully/properly lower the vehicle.
Front sensor how-to will be added soon.
I do not have photos of the front, if someone else has photos of the front, please post them!
UPDATE 04/18/2013
Photos Related to Post:
https://plus.google.com/photos/10995...53048115763905
sagelwwa is offline   Reply With Quote
Old 05-01-2009, 02:25 AM   #2
sagelwwa
Member#: 53975
2004 Forester XT
Java Black Pearl
Old 05-01-2009, 02:31 AM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I want to see pics
Old 05-02-2009, 10:38 PM   #4
sagelwwa
Member#: 53975
2004 Forester XT
Java Black Pearl
Rear pics added. Anyone have Front pics?
Old 05-04-2009, 04:55 AM   #5
sagelwwa
Member#: 53975
2004 Forester XT
Java Black Pearl
Still hoping someone has front pics, I won't be back under my car to get any for a bit. Post em up if you have em!
Old 05-07-2009, 02:33 PM   #6
sagelwwa
Member#: 53975
2004 Forester XT
Java Black Pearl
Added diagram, still hoping someone has front pics.
Old 01-08-2010, 06:30 PM   #7
burken
Member#: 191915
I just did this and now my speedometer is not working... help!!??
burken is offline   Reply With Quote
Old 01-09-2010, 07:58 PM   #8
burken
Member#: 191915
anyone?
Old 02-28-2010, 12:30 AM   #9
TJOD
Member#: 178898
I was about to clean my sensors until i saw this
TJOD is offline   Reply With Quote
Old 02-28-2010, 12:34 AM   #10
TJOD
Member#: 178898
I just read cleaning the sensor with compressed air can cause problems. Did you clean it with compressed air?
Old 02-28-2010, 03:38 AM   #11
Web Foot STi
Member#: 39086
2004 STi
If you are not having any problems I would not even think of cleaning any parts. If you are, CRC Brake Cleaner. You want to get rid of the grease and any metallic partials. The ABS system wants a nice clean square wave from each tooth. Any Klingon's to the tone ring can screw things up. 20 years ago I spent a good bit of time with this issue. We were defining manufacturing limits on how clean the edge could be, and how flat a pressed on ring had to be.
Web Foot STi is offline   Reply With Quote
Old 06-29-2010, 11:50 PM   #12
biv343
Member#: 246476
2006 Impreza WRX
Gray
Good info, +1
I use Valvoline break cleaner, works like a charm.
biv343 is offline   Reply With Quote
Old 04-18-2013, 03:00 PM   #13
b00stedAJ
Member#: 342532
Sorry to bump this up from so long ago but does anyone happen to have the pictures that are missing? or similar ones? Thanks!
b00stedAJ is offline   Reply With Quote
Old 04-18-2013, 03:22 PM   #14
sagelwwa
Member#: 53975
2004 Forester XT
Java Black Pearl
Updated with a link to Google hosted pics. Add me to Google+ while you are there!
Old 11-08-2015, 06:13 PM   #15
Dr. octagon
Member#: 171127
2005 Subaru
I cleaned all 4 abs sensors and what used to be Claaaaaack, Bind, bind ,claaaack from the center diff with a volume of 10 has now been reduced 95%.
My rear abs sensors were horribly dirty, the front not so much.
02 wrx
05 sti trans
05 wrx front struts
R180
Dss rear axles to accommodate r180 and stay 5x100.
Was experiencing horrible binding g during slow speed turns like when turning into parking space.
No cels, spedo works, no abs lights either.
I used crc brake clean as paper towels.
Dr. octagon is offline   Reply With Quote
Old 01-04-2016, 09:17 PM   #16
Qbo707
Member#: 432065
are these sensors the same sensors for a P2158 code (vehicle speed sensor "B") on a 2015 STI? I've been searching and can't find anything on this.
Qbo707 is offline   Reply With Quote
Rear ABS speed sensor interchange - Impreza/WRX/STI to Forester? ModemJunki Brakes, Steering & Suspension 1 02-03-2010 02:51 PM
WTB: Front Passenger ABS Speed Sensor for 2004 STi sagelwwa Private 'Wanted' Classifieds 2 07-20-2009 01:06 AM
How to clean a maf sensor simpsons7s Newbies & FAQs 10 08-05-2007 01:08 AM
How to: clean nasty/pitted fog/headlamp lenses imprezasti88 Interior & Exterior Modification 11 12-25-2005 02:15 PM
How to Clean the MAF Sensor starBug Electrical & Lighting 2 07-24-2004 10:10 AM
