Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Mid Atlantic Impreza Club
Old 07-14-2010, 01:27 PM   #1
robbysean.fitz
Member#: 207874
Exclamation HELP! NOW! carless in Silver Spring MD with blown engine block !!!
i drove a 2006 Legacy 2.5i and i just blew the engine block (says fitzgerald subaru of rockville) and now it's sitting in the shop until i decide what i'm doing with it...
they want $6500 to replace n/a 2.5i engine block...
...no
found JDM FXT EJ257 motor from gruppe-s for $2999
found STI short block from gruppe-s for $2350
i am uninterested in replacing block with OEM piece for $6500
more interested in replacing with upgraded sti block and building n/a motor or swapping blown engine for the JDM FXT EJ257 at a local tuner shop
i'm aware if i swap engines (if possible) that i would have to upgrade everything else in my drive train but would i have to immediately? while breaking in the engine and not using boost until i did so?
help?! please?! and what mid atlantic shops would you recommend this being done at
robbysean.fitz is offline   Reply With Quote
Old 07-14-2010, 02:09 PM   #2
Jard
Member#: 34935
Phil Kessel is a 2x
Stanley Cup Champion!
AndrewTech, IAG Performance, Mach V Motorsports
All are great shops, all have done swaps. All are pretty busy, so give them a call and talk to them directly.
Do you have an overall budget?
I would guess add about $5,000 on to the price of that JDM FXT EJ257 to have the swap done CORRECTLY with the right drivetrain.
Jard is offline   Reply With Quote
Old 07-14-2010, 02:24 PM   #3
robbysean.fitz
Member#: 207874
$5000 is alot less than $6500 thanks man!
Old 07-14-2010, 02:39 PM   #4
Mach V Dan
Member#: 12029
Uh...Jard said $5000 PLUS the cost of the motor. So $8000. And I'd say that's probably low. You're putting a turbo engine into a car that didn't start out as a turbo. You're going to need a LOT of parts. ECU, custom wiring harness or full car wiring harness from the donor car, intake and exhaust manifolds, full exhaust, intercooler, gauge cluster...the list goes on and on. It's do-able, but no way it's going to be less than $6500.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 07-14-2010, 02:57 PM   #5
Jard
Member#: 34935
Phil Kessel is a 2x
I would call all the shops I listed and ask for a quote to replace the stock short block with another 2.5i block too...
Old 07-14-2010, 04:18 PM   #6
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
This/\
And like Dan said your talking some serious jing to convert a non turbo car to a turbo car.
IMO stick with an NA engine
jagcars26 is offline   Reply With Quote
Old 07-14-2010, 09:43 PM   #7
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
What is so fancy about the JDM FXT EJ257 anyway?
I'd do the OEM replacement, sell the car, and buy a Legacy GT. Just saying!
PS: I'd call the local shops as well, easier to get a feel for each of them.
Abnormal is offline   Reply With Quote
Old 07-14-2010, 10:22 PM   #8
WorldRallyRedneck
Member#: 6506
2005 WRX Wagon
I know how you feel, i am currently driving my dads old s-10 while my subie sets in a garage with a spun rod bearing. Will be purchasing a new motor this week.
If you are set on going with a sti block, check out flatironstuning they have the sti shortblock on sale for 1799.00 plus shipping.
If you plan on staying N/A what about one of the Flat 6's from the Legacies. It would be pretty sweet with a 3.0 or 3.6 H6. I dont know what the price tag on that would be though, probably cheapier than going turbo in a non turbo car.
WorldRallyRedneck is offline   Reply With Quote
Old 07-14-2010, 10:27 PM   #9
DavC825
Member#: 201736
12 IS-F Sold!! :(
Slowest 07 STi
Give some shops a call, Andrewtech is about 15mins from where your car is at.
DavC825 is offline   Reply With Quote
Old 07-15-2010, 10:48 AM   #10
moss
Member#: 10197
Just to drop the engine in is going to be around $1200 depending on the shop
if you're going to drop a motor in, why not a Legacy GT motor from the same year ? A full long block can be found for roughly $2500-3000 - there's plenty of wrecked GTs out there. Of course then you'll need the ECU and key chipped to the ECU to run the car, and the turbo crossmember. Then you'll need the wiring... add another $2-2500.
High end - $7000.
Or...just buy a used 2.5i motor?
moss is offline   Reply With Quote
Old 07-15-2010, 06:08 PM   #11
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I agree with the comments along the lines, "fix with (used) stock engine, then sell car and buy GT". It's just not worth the trouble making the swap when you're starting with an NA car, unless you have a lot of time or money on your hands. So much easier to just start with the right car. The transaction costs of selling a used car anding buying another used car will be less than the added cost of the swap.
Frank A is offline   Reply With Quote
Old 07-17-2010, 04:47 AM   #12
robbysean.fitz
Member#: 207874
thanks guys. im glad to know i can depend on the locals for advice, that helps a lot. talked to sam at andrewtech, leaning more towards swapping blown engine block for sti short block and going long term build as n/a with available option of turbo b/c forged internals of upgraded engine block.
talked to local shops figuring $1000 for engine swap maintenance and $3000 for engine if i purchase FXT JDM from gruppe-s. but have the option to bid for multple wrecked STI's in new england for $2000. thats entire engine for less that $2.5k and a shop in RI i can install myself and wreckecd STI includes wiring harness and ECU for turbo'd engine
does anyone have any links from other forums for n/a builds?
i'm not talking about that "i made a mistake buying a n/a 2/5i and want to make it look sweet with trim and stickers (while still rocking casted internals)"
i'm talking about a beautiful high top speed slow acceleration respectable naturally aspirated build. anyone?!
because we all know how much nicer sounding and long lasting and dependable a naturally aspirated engine can be... with some tender love and care.... (care i.e CASH)
Old 07-17-2010, 08:21 AM   #13
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Subiesport, aka the NWIC newsletter, did something like this a while ago, "zero to hero" or something like that i think.
http://forums.nasioc.com/forums/show....php?t=1070854
Bolt ons though, I don't think they had an STi block.
The bang for buck doing this will suck compared to doing a swap. Just a warning.
Why do they think the engine died?
Butt Dyno is offline   Reply With Quote
Old 08-05-2010, 04:51 PM   #14
nyc2004wrx
Member#: 253827
2004 wrx wagon
Default possible engine failure
Just hit 105k miles.....got off parkway, no warning signs, now I may have a blown engine!!
2004 wrx wagon brand new tires, brakes, rotors....very pissed! What now, is there a market to sell it as is?
nyc2004wrx is offline   Reply With Quote
Old 08-05-2010, 10:11 PM   #15
xenonk
Member#: 18823
2011 with 4 wheels
monochrome?
welcome to the club..
unfortunately, you may end up spending about $5k plus when said and done due to all the other parts that may need replacing. I know, because I'm in the same situation as you and my LGT is at Andrewtech now..
xenonk is offline   Reply With Quote
Brake/Service in Silver Spring, MD area skilit Mid Atlantic Impreza Club -- MAIC 7 06-08-2010 09:01 AM
Turbo swap on Sunday in Silver Spring, MD Jard Mid Atlantic Impreza Club -- MAIC 10 08-28-2005 08:55 PM
Install Day - Sunday 8/14/05 - ShannonO's House in Silver Spring, MD Jard Mid Atlantic Impreza Club -- MAIC 139 08-18-2005 11:18 AM
HELP! STRANDED! Need scanner in Silver Spring MD area Brandon Clifton Mid Atlantic Impreza Club -- MAIC 3 11-25-2004 12:49 AM
need accessories in Laurel/Silver Spring MD Area Chris Stein Mid Atlantic Impreza Club -- MAIC 0 04-15-2004 07:48 PM
