Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 07-16-2018, 02:28 PM   #1
obiling
Member#: 409438
2003 Sedan
white
Default Rust damage in an important spot?
There's rust all over my car, so much so I sometimes just want to throw it away just so I don't have to deal with it. I can't even use the jack stand point on the rear driver-side wheel because it doesn't even exist anymore.
The new spot I found does not seem like it will last much longer and although it somehow miraculously holds up the car its not very safe as you can see by the pictures lol...
Anyways, the reason I am posting is because I'm not really sure if I should even drive the car anymore due to the area the rust has damaged. It looks as if the spot holds some significance to the frame of the car and realistically its only a matter of time before what ever metal is there, fails.
What are your guys thoughts? Thanks
obiling is offline   Reply With Quote
Old 07-16-2018, 03:28 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Year and model?
Assuming the horizontal rear diff mount pictured?
Yes, pretty ugly. Wonder what the rear strut towers look like.
As a DD commuter (no spirited driving, no off-road, no real rear loads or trailering), you have some time left. Start saving for something different.
Old 07-16-2018, 04:54 PM   #3
D-rock240
Member#: 284221
2011 WRX GV SSM
01 Legacy/03 Outback wgns
I would not trust that jacking point
D-rock240 is offline   Reply With Quote
Old 07-17-2018, 09:18 AM   #4
rtv900
Member#: 428511
2016 STI
of course those rails are important, but it's not like one day your car is just going to cave in or something.
There's tons of redundancy in unibodies.
It's almost unfixable, once it's rotted years further the car will have to be scraped but just drive it
rtv900 is offline   Reply With Quote
Old 07-19-2018, 08:29 PM   #5
fleezy
Member#: 436768
2004 WRX
the diff carrier is part of the sprung weight, as in to say it moves as a whole, with everything passed the springs so rusty rails probably won't create too much of a problem. That being said, if you do any thing to do with the diff carrier (changes bushings for example), you're probably going to take the threads with the bolts and have to do a massive repair to get it back together. the welds on the nuts inside of the rails are piss poor.
evidence: i did bushings on my carrier. while unbolting the big bolt through the bushing, the nut INSIDE THE FRAME RAIL spun off it's welds, and i had to cut out part of the frame and weld in a new piece, with a nut on it... was about 2 weeks of hoist time for me to do it myself, and my rails weren't as bad as this.
fleezy is offline   Reply With Quote
Old 07-19-2018, 08:38 PM   #6
91 RS RA
Member#: 457410
1991 Legacy RS RA
Personally I would never drive a car with that much rust.
Scrap it and get a new one.
That rust is only what you can see, Im imagining there will be more under there that you can't see
91 RS RA is offline   Reply With Quote
Old 07-19-2018, 11:57 PM   #7
obiling
Member#: 409438
2003 Sedan
white
I appreciate the responses and yes itís pretty depressing that I drive something so rusted but unfortunately I need it to last another year lol.
Itís an 03 coming on 120k, surprisingly the rear strut towers are fine but thatís where the good stuff ends. I always wanted to keep this thing as a winter beater to fix up but itís definitely beyond fixing at this point.
Old 07-20-2018, 02:45 PM   #8
Wappit
Member#: 487203
2018 WRX STI
WR Blue
Thats what she said.
Wappit is offline   Reply With Quote
Old 07-20-2018, 03:36 PM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Originally Posted by Charlie-III View Post
Year and model?
While still your choice, I think these are valid and worthwhile replies. You have to decide mission and risk.
I would drive it as a DD, no spirited driving, AutoX, track days, etc. Nor really bad roads, at least above slow speeds.
Old 07-20-2018, 10:17 PM   #10
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Also, that bracket that you're using as a jack-stand point in the rear is used for the rear differential mounting bracket. You should not use that bracket as a jacking point or a jack-stand point.
I also agree with the points above. It's time to start saving, if you have not already done so, and buy another car.
