Welcome to the North American Subaru Impreza Owners Club Thursday January 24, 2019
Old 12-02-2012, 07:08 PM   #1
lvlatthew
Member#: 336712
2002 bugeye wrx
Previous owner said always filler with Mobil 1/ royal purple. What kind of oil would I get for my 02 bugeye wrx. Thanks.
Assuming Mobil1 xxxx
5w-30 should be a good one? Is that Mobil one
lvlatthew is offline   Reply With Quote
Old 12-02-2012, 07:13 PM   #2
02bugeyed
Member#: 248761
2011 Civic Si
Did it come on or just faintly glow?
My 02 would faintly glow when it was really cold out and would go away when it warmed up.
I think it has something to do with the sensor.
02bugeyed is offline   Reply With Quote
Old 12-02-2012, 07:13 PM   #3
02bugeyed
Member#: 248761
2011 Civic Si
And for oil, a lot of people use shell rotella t6
Old 12-02-2012, 07:15 PM   #4
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
PPG's,Polka pickled,ewg
Any 5w30 full synthetic oil will suffice. I would opt for a 5w40 though. Most tend to have good experience with Shell Rotellla,which can be had at most any store including walmart. I personally run Motul 5w40 on the street in my car. Unfortunately the fact that your oil light has illuminated is the bigger issue at hand imo. I would not drive it until your absolutely sure your oil level is at the full mark.
Brand of oil is not nearly as important at this point as making sure that your oil level stays full at all times. A lot of members will warn against using Mobil1 oil, but honestly as long as the oil is changed when its supposed to be and kept full, you should have no issues. These motors a very prone to spin bearings when ran low on oil. You should be checking your oil level at every fill up especially if this is a new car to you. This way you get a feel for how much oil the car consumes as well as making sure its always topped off!
If your oil level is at the full mark and you still see the oil light illuminated then most likely your oil pickup has developed a crack and needs to be replaced asap! I don't here about this very often on your model year but I'm sure it is possible! Good luck!
blazzin06wrxdude is offline   Reply With Quote
Old 12-02-2012, 07:16 PM   #5
lvlatthew
Member#: 336712
2002 bugeye wrx
Well previous owner said he used Mobil one. So might wanna keep that. But idk if it was on or glowing it is cold and hasn't been driven over the weekend. But the oil was low on the dip stick too.
I only drove it like 100 feet before noticing. So going to get oil now
Also if I out oil in it till its in the like full zone. Will the light definitely go away an what if it doesn't. I have work in the morning and don't want to drive to work with that scaring me
Old 12-02-2012, 07:28 PM   #6
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
If you add oil and the light is still illuminated, shut your car off and find another ride. Your oil pickup has most likely began to fail and will lead to severe engine damage if driven in this condition.
Old 12-02-2012, 07:31 PM   #7
lvlatthew
Member#: 336712
2002 bugeye wrx
Is this a Serious fix or anything? Like ugh I just bought this car.
Willll it go off right away or will I have to drive for like 2 minutes
Old 12-02-2012, 07:40 PM   #8
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
The oil light should go off right away if everything is functioning as it should. As long as you don't hear any loud thumping or tapping on start up you might be ok. As a general rule with subaru's though, you NEVER want to see that oil light illuminate as that light comes on when there is less then 2psi oil pressure I believe. You typically don't want to see anything lower then 25psi at idle for oil pressure on these motors and anything less can cause potential bearing damage.
It could also be something very simple..here's a quote from KILLERBmotorsport who is a vendor on this forum. "Your oil pressure is fine, you have a bad connection from sensor to block. Usually caused by corrosion or moisture. The sender is below the alternator on the top of the block. Remove, clean and reinstall.
If you had low oil pressure (the light comes on at 2.1psi) the light comes ON."
hope this helps
Old 12-02-2012, 07:42 PM   #9
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
Link to thread with the above quoted from Killerbmotorsport.
http://forums.nasioc.com/forums/show....php?t=2262081
Old 12-02-2012, 07:49 PM   #10
Jack
Add Lightness
Member#: 13699
not my president
(From General)
And if your oil light is on, shut off the car until you figure out why and fix it. If it's full, I'd be getting the killer B oil pickup. Subaru oil lights usually only come on to tell you "I'm done, go buy a new engine".
Old 12-02-2012, 07:51 PM   #11
lvlatthew
Member#: 336712
2002 bugeye wrx
I think I'm low on oil.. That's just it. I'm glad I caught it..just bought oil so ill put it in inike 5 min
Old 12-02-2012, 07:52 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
If the light is ON or flickers turn the car off ASAP! Personally, I'd get a cheapo mechanical gauge and install it at startup. If the pickup is cracked (and the oil isn't hot) it may or may not light the light, but your pressure could still be really low. A mechanical gauge is cheap and will give you a very accurate reading.
FYI, cracked pickups go back to the begining of the EJ engines in the early 90's. The oldest car I've personally seen a broken pickup in was a 1997 with over 200K on the clock.
Old 12-02-2012, 07:54 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Low oil will not illuminate the light. If it reads any on the dipstick it's nowhere near low enough to make the light come on.
Remember, your viscosity is different cold/hot so the symptoms will change.
Old 12-02-2012, 08:01 PM   #14
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
Good to know! And I apologize for misleading the op! So essentially that light will not illuminate unless the oil pan is pretty much empty? The pickup has to be uncovered?
Old 12-02-2012, 08:03 PM   #15
lvlatthew
Member#: 336712
2002 bugeye wrx
Put in two quarts And light went off. Should I be all set now?
Old 12-02-2012, 08:04 PM   #16
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
Let it warm up to operating temp and see what happens as oil viscosity changes. Keep an eye for the light and any noises out of the ordinary.
Old 12-02-2012, 08:06 PM   #17
lvlatthew
Member#: 336712
2002 bugeye wrx
I'm going to take it for a small calm ride and ill check it. No different sounds at all while starting throughout this whole thread
Old 12-02-2012, 08:06 PM   #18
prometheum
Member#: 92003
04 bicycle!
2 quarts is pretty friggen low! Personally I'd change the oil so i could send a sample to blackstone labs to see if there was any excessive metal content in the oil especially from the bearings (typically lead and copper). There's not much you can do if you did cause any damage but at least you'd know if you need to save up for a new short block...like the one i'm selling
Personally i've had the oil light come on while driving up hill through the rockies running 1.25 quarts low. Nothing out of the ordinary showed up when I sent the sample to blackstone labs. The car went on to live 20,000 miles more before the transmission blew up
edit: I'd personally switch over to a different oil that subarus don't drink like water
prometheum is offline   Reply With Quote
Old 12-02-2012, 08:09 PM   #19
lvlatthew
Member#: 336712
2002 bugeye wrx
Car seems to be running fine no issues at all just the light scared me. Low on oil. So going to recheck now that I've warmed it up
I went to like read the dip stick. And now it looks to be reading like to much oil now... Like wtf
Old 12-02-2012, 08:30 PM   #20
lvlatthew
Member#: 336712
2002 bugeye wrx
I think I'm gonna get an oil change tomorrow because I think there may be to much now... But what's a recommended oil to change and stick with? Ill ask the person I go to to get it
Old 12-02-2012, 08:53 PM   #21
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
Royal Purple and Mobil1 5W30 are teh 2 worst oils you can put in a turbocharged Subaru.
Old 12-02-2012, 08:57 PM   #22
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
That reminds me. I want to check mine out when I pull the spun bearing motor out of my 04 -_- (220,000+ miles)
Old 12-02-2012, 09:03 PM   #23
HinshawWRX
Medium Frank
Member#: 140114
2013 Audi
A6 3.0T
KillerB (basically the king's of Subaru oil issue solving) said if the light is on, don't start or drive. I wouldn't touch the car.
Old 12-02-2012, 09:22 PM   #24
lvlatthew
Member#: 336712
2002 bugeye wrx
Already stated the light is now OFF
Old 12-02-2012, 09:44 PM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
If it were my car I would drop the pan ASAP, no driving. Pain in the butt, YES. Worth it vs thousands for a blown engine/turbo? God yes!!
You'd be kicking yourself if something like this happened because you didn't check it out. Worse case you find a problem with the pickup and replace it. Best case you find nothing, know there's nothing wrong, and don't loose any sleep over it.
no one wants this...
