Welcome to the North American Subaru Impreza Owners Club Tuesday July 23, 2019
Old 11-05-2017, 11:03 AM   #3626
DsKs17
Member#: 476738
2017 Wrx limited
2017 WRX. My clutch pedal intermittently vibrates. I've found that pressing it in and releasing it quickly eventually resolves the issue. Has anyone else experienced this? Is this something I should be concerned about?
DsKs17 is offline   Reply With Quote
Old 12-03-2017, 11:32 AM   #3627
DaHeights718
Member#: 470141
Does anyone have a loose driver side window. Mine rattles unless I push it down. So annoying
DaHeights718 is online now   Reply With Quote
Old 12-06-2017, 10:43 AM   #3628
vtwinjunkie
Member#: 415503
2016 WRX limited
black silica
vtwinjunkie is offline   Reply With Quote
Old 12-11-2017, 10:41 PM   #3629
buckwilly
Member#: 252012
2010 STi
Default 2015 WRX Defects
2016 WRX limited purchased in July 2015. 42k miles since new and not a single defect or issue. 32k of those miles at stage 1 or stage 2 plus. No rattles , leaks, paint issues, or anything of the sort. As a matter a fact, itís the most reliable car Iíve ever owned (Iíve owned several WRX, STIs, BMWs, Nissans, Lexus, and Infiniti). Itís almost hard to believe the defects and complaints I keep reading.
Only basic maintenance and lots of motor, brake, and suspension mods. Itís been a fun and stress free two years with her. Zero complaints. Just smiles and spirited drives. I do take excellent care of my cars though. Always garage kept and doesnít see daily driving for last 18 months.
buckwilly is offline   Reply With Quote
Old 12-12-2017, 03:29 PM   #3630
subySerb
Member#: 155411
Can I just go to the dealership with this list and tell them to fix all of the issues?
subySerb is offline   Reply With Quote
Old 12-12-2017, 05:10 PM   #3631
vtwinjunkie
Member#: 415503
2016 WRX limited
black silica
I have no idea what year you have since its not listed. if you have an early model 2015 chances are you have a few of these or more. If you have a 2016 like me, you may have 2-3 but it inst a given that your car will exhibit symptoms of the issues listed. I merely posted this as a means of information for you to research on your own and see which ones apply to your car.
If you have a 2017 or newer. these will most likely not apply to you.
if you open the links and read, you will see what I am talking about.
Do what you want, but I have found that the honey approach always works best for me. I value the relationship that I have built with my dealer and would not come to them with bull**** like what you are proposing.
Old 12-12-2017, 05:51 PM   #3632
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
Interesting list
The Door Mirror Loose TSB applies to my car, even though the year listed on the TSB is up to 2016.
Ill have to go up to the dealer and talk to them. Im more afraid of them scratching my car, than the mirror assembly being loose.
vapore0n is offline   Reply With Quote
Old 12-13-2017, 10:01 AM   #3633
vtwinjunkie
Member#: 415503
2016 WRX limited
black silica
Originally Posted by vapore0n View Post
Interesting list
Read through the TSB. it is simply an update to the bolts.
you can purchase these bolts and do this yourself if it makes you feel better.
they are probably only a few bucks. Hardly worth your time to go through the service dept for those savings.
Old 12-13-2017, 01:10 PM   #3634
xtremsiege2
Member#: 232721
2015 wrx premium
ICM
If it aint broke don't fix it, is what they'll probably say. Bulletins are based on the amount of people having the same problem, doesn't mean your car has these problems. Or they may charge you for the diagnostic.
xtremsiege2 is offline   Reply With Quote
Old 12-13-2017, 03:36 PM   #3635
vapore0n
Member#: 21356
2017 Subaru Corolla
not a bad idea.
I have wanted to take the assembly off. I figured I needed to tighten something. Now I got instructions on how to
Old 12-13-2017, 09:21 PM   #3636
vtwinjunkie
Member#: 415503
2016 WRX limited
black silica
not a bad idea.
I intend to do the same thing. Although its not bad enough to warrant it right now perhaps in another year or so for me.
Good luck!
Old 02-27-2018, 01:14 AM   #3637
DaHeights718
Member#: 470141
Anybody having issues with condensation in their fog lights. Itís driving me crazy
Old 03-05-2018, 05:17 PM   #3638
CBSWRX
Member#: 424895
2016 WRX - (SOLD!)
Lol, Iím so jealous!! You find it hard to believe that people have issues, I find it hard to believe there are WRXs out there with no issues! Haha. Maybe the secret is not to use it as a daily driver like I have.
CBSWRX is offline   Reply With Quote
Old 03-08-2018, 03:12 PM   #3639
CBSWRX
Member#: 424895
2016 WRX - (SOLD!)
Good tip Just noticed that my mirrors are pretty loose. Will pick up bolts and do the fix myself.
Old 03-08-2018, 04:17 PM   #3640
RuskiWRX
Member#: 481410
2015 WRX Premium
I have issues putting my car into first and second gear. Very often it takes a lot of effort to shift into 1st or 2nd, other times none at all. I don't know if this is a defect.
RuskiWRX is offline   Reply With Quote
Old 03-08-2018, 04:21 PM   #3641
RuskiWRX
Member#: 481410
2015 WRX Premium
I think I have a similar issue, but only after driving my car hard. The clutch vibrates when I press it in, but it eventually goes away after use.
Old 03-08-2018, 04:34 PM   #3642
samus2017
Member#: 474813
2017 WRX
I had the same issue. There is a TSB for the Clutch Release Bearing.
samus2017 is offline   Reply With Quote
Old 03-15-2018, 08:39 AM   #3643
fredzy
Member#: 317270
15 WRX
and a Sienna
Did you have any transmission related work done? Maybe check that all of the shift cables/anchors are secured and fully seated the next time you can get under the car. I'm assuming this isn't just cold (harder shifting) vs. warm.
Twice I've had issues with intermittent hard-shifting (in a Nissan and a Saturn) and both times, the clips that secure the ends of the shift cables had become loose. It reduces the precision of the cable movement, which can cause conflict at the gearbox.
The one thing that I most expected to be let down by going to the 2015 WRX, but have been most happy with is the shifter. Not the best, but nowhere near bad, even in the cold. I've never even seen how Subaru's cables are set up, so my advice above could be entirely not-applicable.
fredzy is offline   Reply With Quote
Old 03-15-2018, 09:07 AM   #3644
nevernudedrew
Member#: 480079
2018 WRX
ME TOO
There's no issue when the window is all the way up or down, but when I cruise with the window partially open, it will jostle just enough to make a little noise.
Also, weird thing I've noticed: I use a cigarette lighter --> micro usb charger for my phone from the center armrest, when the phone is plugged in, and if I leave it on my passenger seat, the passenger seatbelt sign will trigger and start chiming. As soon as I lift the phone off the seat, it stops. I think it has something to do with triggering an electrical circuit and just the right contact, but I know that this is definitely causing it because it took me weeks to diagnose wtf was going on and narrowed it down to being directly related to having the phone plugged in charging and setting it on the passenger seat.
nevernudedrew is offline   Reply With Quote
Old 03-16-2018, 04:49 PM   #3645
vladd
Member#: 158185
17 WRX
CWP
Agreed, the tranny is much better than I was expecting.
vladd is offline   Reply With Quote
Old 08-22-2018, 04:06 PM   #3646
CWPwrx
Member#: 461151
Hey guys,
Wondering if anyone has encountered this problem.... I have a 17 WRX when my turbo spools up I get the standard turbo noise in the cabin as well as what I would describe as a noise it you stuck a piece of paper into spinning fan blades... Hope that makes sense? Could it be a turbo leak?
CWPwrx is offline   Reply With Quote
Old 02-15-2019, 03:30 PM   #3647
oldenoughtoknowbettr
Member#: 497063
2015 WRX
rollover white
the passenger side windshield wipers limit is right in my eyeball path looker & i focus on the little bit of impression it leaves
cause it's right
there
i may just need new wiperblades, but that's a messed up place to set the wipers
oldenoughtoknowbettr is offline   Reply With Quote
Old 07-10-2019, 11:13 AM   #3648
SLOW_motion
Member#: 116625
20?? 2xSTI(s)LGT&WRX
Silver-White-Garnet-BLK
Default SUBARU of America (SOA) Service Bulletin
SUBJECT: Abnormal Sound from Air Conditioning (A/C) Compressor
This bulletin announces availability of a new A/C compressor to address a limited number of customer concerns regarding abnormal knocking or fluttering-type sound heard when switching the system on. The compressorís internal check valve spring may not have been installed properly during assembly.
https://tools.carmd.com/Tsb/Download/121398/136543
SLOW_motion is offline   Reply With Quote
Old 07-10-2019, 11:15 AM   #3649
SLOW_motion
Member#: 116625
This bulletin announces availability of a new A/C compressor to address a limited number of customer concerns regarding abnormal knocking or fluttering-type sound heard when switching the system on. The compressor’s internal check valve spring may not have been installed properly during assembly.
Associated SUBARU Service Bulletin
SUBJECT: New A/C Compressor / Clutch Assembly
This bulletin announces the availability of a new Air Conditioning compressor / clutch assembly to address customer concerns of the system not operating. Electrical windings located inside the clutch assembly have been changed to eliminate the condition. The service procedure will involve replacement of the A/C compressor and clutch as a complete assembly.
Link to SOA Service Bulletin: https://testing-public.carmd.com/Tsb.../114137/124407
Last edited by SLOW_motion; 07-10-2019 at 11:23 AM. Reason: Duplicate info needed correction/editing accordingly.
