Welcome to the North American Subaru Impreza Owners Club Friday November 16, 2018
Old 07-25-2007, 04:10 AM   #1
StageWrx
Member#: 143583
07 wrx
ugm
Default 18x8 with 47 offset, will it work?
My friend has a set of rims , size is 18x8 with 47 offset, and a set of 235/35/18 tires to go with them. will this combo work on a 2007 wrx?
StageWrx is offline   Reply With Quote
Old 07-25-2007, 08:09 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I think it will work. The offset is a little low, but definitely not bad for a 18x8. 235/35/18 is a pretty short tire, so it also gives you less chace for rubbing. Just watch out for potholes! Oh, and are you on stock suspension?
Old 07-25-2007, 08:38 AM   #3
Blue5spdWRXWgn
Member#: 93606
2002 WRX Wagon - WRB
2005 9-2X - SGM
Do they have the correct bolt circle diameter and hub-centering pilot diameter?
Blue5spdWRXWgn is offline   Reply With Quote
Old 07-25-2007, 09:04 AM   #4
mav1c
Hoodbridge!
Member#: 560
Oh yeah, very good questions. Should be 5x100 and at least 56.1 hub bore. If they have a hub bore greater than 56.1, you'll need hub rings.
Old 07-28-2007, 06:37 AM   #5
StageWrx
Member#: 143583
07 wrx
ugm
u guys are great help thks... he is on stock suspension, will be putting on Swifts springs on to close the ugly gap
Old 07-28-2007, 10:20 AM   #6
Td5turbo
Member#: 126410
02 WRX Wagon
Hubcentric rings are a very debated topic. basically no weight is carried on the hub, even with the correct bore diameter. Think about it, the tollerance out have to be so high that the machining of each (the hub, the wheel bore, and the lug holes) would have to be PERFECT. Point is, the weight is carried out on the wheel bearings...NOT the lug studs because tapered lug nuts center the wheel over a given stud, making it not carry the car weight, but transfering it to the wheel bearings.
This is why most hubcentric rings are PLASTIC or some sort of composite.
Its insignificant to use hubcentric rings, in all honesty.
Td5turbo is offline   Reply With Quote
Old 07-28-2007, 12:10 PM   #7
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
yes they will work, i'm running 18x8.5 +48 with no rubbing or fender rolling
ray101381 is offline   Reply With Quote
235/40/18 on WORK emotion 18x8.5 + 37 offset will it fit? DieselClown Tire & Wheel 1 12-15-2008 04:14 AM
18x8 Offset +51 will it work for a 05 Wagon WRXsai Tire & Wheel 2 07-25-2007 07:15 PM
Impreza headlight housing with sti HIDS, will it work? whifkey Sti Electrical & Lighting 1 04-11-2007 05:20 PM
help with a turbocharger? will it work? David Medina Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-19-2005 04:29 AM
v6/v7 sti seat - does it come with airbag or will it work with side airbag? maaw Interior & Exterior Modification 4 05-27-2004 02:37 PM
