![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 534765
![]() Doing winter driving with the WRX and I usually long press the traction control to turn it off, but ABS lengthens my brake distance in snow, and I'm pretty sure there is some residual VDC (vehicle dynamics control) remaining even when TC is turned off, because the car doesn't rotate as easily as it should.
I'm also annoyed that it's very hard to tell when ABS kicks in because the noise/feel is almost undetectable to me, making threshold braking much harder to dial in. Maybe the NVH from the mounts in my car are camouflaging the feel of ABS, who knows. I haven't attempted anything yet, but based on my research I have run down the following options:
That's what I've got to start with. Hopefully someone out there knows how to do this. Kind of surprised I can't find anyone who's accomplished it considering how popular the VA is, but most people are racing with cheap older Subarus. Links:
#2 |
Member#: 540094
Vehicle:2022 WRX WRC Blue |
![]() Nick,
Did you have any luck? I’m going to be driving my VB in a RallyCross event this weekend. I tried to pull the VDC SOL fuse, dash went crazy (as expected), power steering was 100% and rev limiter kicked in around 5500. Then I tried the right wheel sensor and the dash went even more crazy with extra warnings, power steering was gone, rev limiter at 5500 again. I would love to get the car to where they had it at Team O’Neil with no electronic assists for the race. I will keep searching. But hopefully I can find a solution other than the disable traction button. -Thanks! |
#3 | |
Member#: 534765
![]() Quote:
On the VA WRX this is internal fuse #8, 7.5A. I can't find a diagram for the VB but it's probably similar. Still trying to figure out ABS. |
#4 | |
Member#: 540337
![]() Quote:
#5 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
![]() you cant unplug the abs module?
