Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-27-2008, 02:56 AM   #1
pandamaster
Member#: 169887
2005 wrx
Default Need help connecting utec to lap top
I have a utec on my o5 wrx
i finally got an adapter for the serial cable extending from the utec to make it a usb so that i can upload the stage 3 map from my laptop(it dosent have the right serial port in it). i was using my home pc before and using a 9v to power the ecu last time i uploaded my maps. So when i go to connect the laptop for the first time i can not get the utec main black screen to pop up on hyperterminal. I have had no problems before and even followed the instructions on the manual step by step just to be sure. The only thing i can think is that in the manual it says to set the port connection to "com1" but the only options my lap top gives my from the drop down menu that are even close is com3. Also another thing that might be the problem is that i am connectong through the usb this time and not the serial port so i might have to change the connections, some how?
Hopefully i was clear enough on my problem and i would aprreciate any suggestions so that i don't have to unistall the utec again and use the 9v again
pandamaster is offline   Reply With Quote
Old 06-27-2008, 02:52 PM   #2
sorrowfulkiller
Member#: 170439
I <3 Lamp
what you need to do is go to your my computer icon, right click on it, then go to properties, then go under hardware, device manager and then find out what the com port is on your usb that you are connected to, it should say something along the lines of "usb to serial converter (com3)" whatever is in the ()'s is the com port you want to connect to.
PM me if you have any issues
sorrowfulkiller is offline   Reply With Quote
Old 06-27-2008, 10:32 PM   #3
pandamaster
Member#: 169887
2005 wrx
thanks for the info ill try mesing with it to see if i can get it up and running
Old 06-29-2008, 02:09 PM   #4
bcblues
Member#: 17256
18 Outback
on the road....
Make sure you have to USB to serial adapter plugged into your USB port of your computer before you look at Device Manager, otherwise it will not show up.
Then, open HyperTerminal Properties and point the app to connect to the proper port.
bcblues is offline   Reply With Quote
Old 06-29-2008, 02:54 PM   #5
pandamaster
Member#: 169887
2005 wrx
ill try it again and see ^^^^
Old 06-29-2008, 03:37 PM   #6
pandamaster
Member#: 169887
2005 wrx
tried to connect it using com port 3 like it specified in the device manager and it is a no go still
Old 06-29-2008, 03:49 PM   #7
bcblues
Member#: 17256
18 Outback
on the road....
Did you try hitting the Esc key in HyperTerminal? That usually will get you to the UTEC menu.
Old 06-29-2008, 10:05 PM   #8
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
Or any UTEC command. Sometimes the buffer in hyper terminal gets confused, and hitting a UTEC command fixes that.
Also, make sure you have the correct drivers for your converter. I remember my Belkin connector needed drivers (which it didn't come with) before it would run.
AruisDante is offline   Reply With Quote
Old 07-06-2008, 10:32 AM   #9
bcblues
Member#: 17256
18 Outback
on the road....
OP, any success?
Old 07-08-2008, 01:37 PM   #10
turbobird14
Member#: 147780
2002 Bugeye WRX
Flippin Awesome
im having the exact same problem, and have the belkin adapter (recommended from Turbo XS) where did you download the drivers from? i did get a CD from the manu, but i am starting to think its lacking the drivers.
turbobird14 is offline   Reply With Quote
Old 07-08-2008, 06:06 PM   #11
AruisDante
Member#: 122365
Ice Silver
They are buried somewhere in the bowels of the Belkin site. It takes me a solid hour to find the damn things. You have to find the product page for the adaptor (it'll help alot if you know the model number), and then there should be a link to driver downloads on it. However, it's just files and not an installer, so you have to manually uninstall the defualt USB device that windows installs (go to the device manager and look for the new USB device that pops up when you plug it in if you can't find which thing to uninstall), and then the next time you plug it in windows should ask if it can install new hardware, and you tell it to install from the folder containing the files that you downloaded from Belkin.
Yeah, it's a big pain in the ass, and I have no idea why they don't tell you you need to do it.
Old 07-09-2008, 01:25 PM   #12
turbobird14
Member#: 147780
2002 Bugeye WRX
Flippin Awesome
thanks alot thats a lot of help. im going to see whats going on with it hopefully this weekend. If nothing else ill let my brother play with it, he like f'in with computers all the time. Ill let him do the boring driver stuff and ill just go and tune it!
quick question about connecting ap to lap top chibich AccessPort 0 05-12-2007 06:49 PM
Need help connecting my razr to my computer w/ a usb bluetooth thing.... stevenh Off-Topic 8 04-04-2006 02:00 AM
Need Help Pulling UTEC Map off of my car to send off for tweaking....HELP ME!!! YourMother'sLover Texas Impreza Club Forum -- TXIC 10 11-09-2005 01:37 AM
UTEC hooking up to lap top? axion7606 Newbies & FAQs 2 10-15-2003 08:26 PM
How to connect utec to new laptop without serial port? RyeDaddy Engine Management & Tuning 0 09-04-2003 01:12 AM
