Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 01-21-2010, 06:49 PM   #1
L Bo
RIP Brother
Member#: 8739
Default auto connect with wi-fi hotspots, is it possible?
I travel around the area and on the search for free wi-fi. <need them to transmit orders for work> Is there software that can automatically find hot spots, filter out all the secure locations and connect to an unsecure open location? I find a lot of hotels I can sign on to but need to purchase a pass access to the www. It takes too much time to search, look for unsecure places, try to connect and then find out it's not free.
Ideally I want to turn the laptop on and connect automatically, if available, like it was when I had an air card. Possible?
L Bo is offline   Reply With Quote
Old 01-21-2010, 06:50 PM   #2
Porter
Member#: 486
2004 Forester XT
bug spattered
Yes, and it's easy. It's called "promiscuous client mode" and is a feature of most wifi client chipsets. The utility to enable it is usually chipset-specific, though there are some utilities out there to do it through the Windows wifi config layer.
[edit] Oh, you also need it to check for full http access on systems that use a gateway credential... not sure on that. I'm sure it's out there though.
Porter is offline   Reply With Quote
Old 01-21-2010, 07:58 PM   #3
L Bo
RIP Brother
Member#: 8739
dude thanks, promiscusuos client mode is my google friend.
http://www.filesland.com/software/promiscuous-mode.html
I see Promiscan is $400, but offer a free download. Is there a link for a free one, only requirement is that it works.
google promiscuous client mode wi-fi hotspots circles me back to nabisco;
http://www.google.com/search?hl=en&r...tspots&spell=1
what should I get?
Old 01-21-2010, 08:50 PM   #4
dr_wheel
has never eaten a strawberry
Member#: 60106
I eat pieces of
* like you for breakfast
dr_wheel is offline   Reply With Quote
Old 01-21-2010, 09:35 PM   #5
Jay911
Member#: 50002
2013 red Raptor
add 'linksys' to your trusted networks?
Jay911 is offline   Reply With Quote
Old 01-21-2010, 09:59 PM   #6
LastResort
Member#: 99289
Wouldn't it be easier to just get a MiFi or WAN card?
LastResort is offline   Reply With Quote
Old 01-21-2010, 10:13 PM   #7
L Bo
RIP Brother
Member#: 8739
Originally Posted by dr_wheel View Post
Does it auto connect? Looks like for $50 it just gives me everything the Dell option (clicking the antenna strength toolbar icon instead of the monitor looking Microsoft icon) gives me. No?
Old 01-21-2010, 10:46 PM   #8
dr_wheel
Member#: 60106
I eat pieces of
Did you click the link? It's a separate device used to sniff out networks.
Old 01-21-2010, 11:17 PM   #9
L Bo
RIP Brother
Member#: 8739
It's doesn't say anything about auto connecting, like it does when I get home.
Third generation WiFi detection and analysis device!
We haven't seen any WiFi sniffing dogs at the airport, but we suspect that somewhere there is a small group of individuals dedicated to training such useful helpers. Until these canines are trained and domesticated we have a device that can assist in "sniffing out" the presence of WiFi. It's a nice unit that offers several improvements on currently available WiFi detectors.
Your typical WiFi detector will only show the presence of a signal and relative signal strength - not very helpful. This Digital WiFi Detector has a backlit LCD screen that provides information on signal availability and strength as well as essential network information, including SSID, security status and channel. When multiple networks are present, the LCD will allow you to scroll through information for each network.
Also has these great features.
•Backlight LCD screen shows signal strength, network ID (SSID), encryption status and channel
•Provides specific information about each network when multiple networks are present
•Detects Encryption (WEP and WPA)
•Shows channel used (1-14)
•Coverage: Up to 200 feet (60m) open environment
•Identifies 802.11b and 802.11g networks
•Dimensions: 2.5" x 2.75" x 1" thick (65mm x 70mm x 24mm)
•Batteries: 2 x AAA (included)
•CE approved and FCC compliant
•Auto power off
All of this can be had with the built in WiFi Catcher on my Dell. Maybe I am overlooking something, how does it connect my laptop to teh webz? I can already see what's out there.
Old 01-21-2010, 11:44 PM   #10
dr_wheel
Member#: 60106
I eat pieces of
It does not help you 'auto-connect' to anything. Again, it's a separate device for finding networks.
Yes... at the expense of having to have your laptop turned on the whole time you are roaming for a signal, using up battery. With a device like this, you could drive/roam around, find an acceptable AP, and then turn on your laptop and surf away. Get it?
Running 6 speakers with a 4ch amp, is it possible? mneste8718 Car Audio, Video & Security 33 06-20-2006 12:37 AM
Is it possible for me to run two different auto-x classes in the same auto-x? Swine Motorsports 9 05-04-2005 02:13 PM
Is it possible to convert an auto to a manual? Supapooh General Forum Archive 10 03-03-2001 11:22 PM
auto to stick is it possible? azncandyman Normally Aspirated Powertrain 3 01-23-2001 03:43 PM
Is it possible to change from auto to manual? Andrew General Forum Archive 14 05-26-2000 12:18 PM
