Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 04-01-2004, 12:29 AM   #1
WRXsPWN
Member#: 35989
2011 Sti sedan
Default Can anyone explain how to remove the inner tierod from the rack
I need to know how to remove the inner tierod from the rack on a wrx. whoever changed my name, thats real cute :P
any help is greatly appreciated.
Thanks
WRXsPWN is offline   Reply With Quote
Old 04-01-2004, 12:40 AM   #2
PeterJ
Member#: 14727
2002 impreza RS
If you rip off that metal band thats connecting the boot to the rack body, you can peel back the boot to expose the ball joint. Then you have to take a flathead screw driver and bend back the saftey washer that locks the ball joint to the rack. Then you can just unscrew it.
You will need to install a new washer and hit it with a chisel or flathead to bend it back into the V-shaped groove when you put it back together. The ball joint gets tightened to 50ft-lbs. You can buy a new band and safety washer at subaruparts.com
PeterJ is offline   Reply With Quote
Old 04-01-2004, 05:04 PM   #3
WRXsPWN
Member#: 35989
2011 Sti sedan
yeah i read something and concluded that from the low ratio rack someone had done a writeup on. so i tried pring those tabs with the rack on the car and it is a big pita. also i noticed i have a bent control arm too. now i am just hoping i didnt damage the frame. stupid curbs. thanks for the help though. i just had the car flatbedded in. It's beyond what i want to deal with at this point.
How to remove front inner axle stub/input shaft? (pic) salvator_rizzo Transmission (AT/MT) & Driveline 10 02-20-2011 08:47 PM
Can anyone explain how to install Cobb AP in lamens terms soobie05 South West Impreza Club Forum -- SWIC 6 05-10-2006 02:47 PM
anyone know how to remove toolbar from browser? ImprezaTs Off-Topic 11 11-08-2004 02:19 AM
Can anyone explain how this has to be a catch to my friend? Thursday Off-Topic 8 01-01-2004 09:43 PM
Anyone know how to import a used car from the US? GooseMan Canada Region Forum 3 11-17-2003 08:17 PM
