Welcome to the North American Subaru Impreza Owners Club Thursday June 22, 2017
Old 05-27-2017, 06:46 PM   #1
MF-DIF
Member#: 62197
2002 PSM WRX
Mini Cooper S, Yami FZ-09
Default High pitch squeal only when steering wheel is turned right slightly
I've been trying to diagnose this issue for a while. When the wheel is in the 1 o'clock position while moving I get a high pitched squeal. Only other thing is it sometimes when I come to a stop it'll make the same squeal oddly enough. Not the familiar brake pad squeal.
So far I've...
Replaced the accessory belt (old belt was only a year old, so it looked fine)
Adjusted the belt to varying degrees of tightness
Replaced the power steering hoses
Replaced the power steering o-ring
Flushed the power steering fluid
Suggestions on what's else it might be? If it's a pulley, which one? Anyway to test those other than throwing parts on the car?
MF-DIF is online now   Reply With Quote
Old 05-27-2017, 11:53 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Short term, take the PS/alternator belt off, see if the sound stops.
Charlie-III is online now   Reply With Quote
Old 05-30-2017, 07:55 PM   #3
MF-DIF
Member#: 62197
2002 PSM WRX
What would that indicate if it did or did not stop? I assume I'd have to try and take it for a spin around the block without any power steering.
Old 05-31-2017, 08:44 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Correct, if the noise goes away, you're down to the belt, PS pump and alternator. If you still have the noise, then it's the other belt, AC compressor, rack.
Old 06-01-2017, 06:42 PM   #5
MF-DIF
Member#: 62197
2002 PSM WRX
Welp. Took off the PS/alternator belt and still had the squeak. So I guess it's down to the AC belt, AC compressor or rack correct?
Any next steps to narrow it down? The belt is the easiest and cheapest to try.
AC works good. On or off it makes no difference. Hope it's not the rack. There isn't any difficulty turning or anything. But there is a "groaning" noise when I get close the the turning stop point.
Old 06-19-2017, 05:08 PM   #6
MF-DIF
Member#: 62197
2002 PSM WRX
Well I did the AC belt this week with no difference. Something odd I did notice is that after taking the car to an automatic car wash, the noise temporarily went away. I'm guessing something got wet and that helped lube something. Of course, as it dried it came back.
Could it be something in the suspension? It's driving me crazy!
Old Yesterday, 08:39 PM   #7
rexxx161
Member#: 461066
2009 WRX
Crank pulley rubbing on timing cover shields?
rexxx161 is online now   Reply With Quote
