Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2020
Old 08-28-2007, 03:16 AM   #1
BillMac
Member#: 124593
2007 Sti fp red
346whp 366wtq
Default 07 sti Vacuum Diagram PLEASE Help
Ok heres my probly i had a friend help me with removing my intake manifold he said he knew what he was doing but turns out he didnt i have two vacuum spots open one i think i can figure out but not sure it runs like right under the throttlebody and the one i have no clue about is on a sensor the bottem right in around where the powersteering pump is its the bottom port its open. Please help need to have my car put back together tommorow getting tuned saterday.
Thanks Bill
BillMac is offline   Reply With Quote
Old 08-28-2007, 11:07 AM   #2
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
The one right under the throttle body sounds like the vacuum source for the PCV.
The sensor right behind the power steering pump is the gas tank vapor solenoid. This one's difficult to put back together. If you get a picture of this area...I'll tell you where it all goes.
SloRice is offline   Reply With Quote
Old 08-28-2007, 12:50 PM   #3
x99percent
Member#: 27108
2004 STi
2004 A4
Originally Posted by SloRice View Post
The sensor right behind the power steering pump is the gas tank vapor solenoidS.
Fixed.
They replaced the "UFO" pressure solenoid with another electric one on the 2007 cars.
x99percent is offline   Reply With Quote
Old 08-28-2007, 12:54 PM   #4
SloRice
Member#: 44351
2004 Mitsubishi Evo
is it harder to break than the older ones??
They magically seem to break the plastic ports off when you look at them funny.
Old 08-28-2007, 01:21 PM   #5
BillMac
Member#: 124593
2007 Sti fp red
346whp 366wtq
If i just blocked off the open port would it run what would happen?
The perrin 3"inlet got rid of the pcv valve, but i beleive i have that hooked up right.
Old 08-28-2007, 01:35 PM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
Sounds like you're not clear as to what/where the PCV valve is... Installing an inlet doesn't eliminate the PCV valve at all.
Old 08-28-2007, 02:33 PM   #7
SloRice
Member#: 44351
2004 Mitsubishi Evo
it kinda does. The Perrin inlet gets rid of the port on the turbo inlet that the PCV connects to. You are supposed to tee the PCV port in with the head breather ports and run it through a catch can.
ttiwwop
Old 08-28-2007, 05:16 PM   #8
x99percent
Member#: 27108
2004 STi
2004 A4
ttiwwop
I agree that the inlet requires the PCV line and the valve cover breather line to be T-ed together, but the PCV *valve* is never touched.
I think he may be referring to the PCV diag connector... the useless gray "sensor".
Old 08-28-2007, 05:21 PM   #9
SloRice
Member#: 44351
2004 Mitsubishi Evo
tomato, tamoto.
Old 08-29-2007, 12:55 AM   #10
BillMac
Member#: 124593
2007 Sti fp red
346whp 366wtq
Can anyone get me a picture or diagram of where the vacuum lines in the front two sensors exsplaining where they go.The pvc valve is still there just doesnt have the part where it goes into the inlet. I worked way to late today but i stopped into subaru today and they couldnt pull up any good diagrams. Please help me out.
Thanks
Bill
Old 08-29-2007, 11:38 AM   #11
SloRice
Member#: 44351
2004 Mitsubishi Evo
Old 08-29-2007, 03:35 PM   #12
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
in case the vac lines differ, just want to point out that the diagram posted above looks like its from an 04 STi
TROLL is offline   Reply With Quote
Old 08-29-2007, 06:10 PM   #13
BillMac
Member#: 124593
2007 Sti fp red
346whp 366wtq
Mine does not have the item 21 it has a senor or relay with a plug on it.
Old 08-29-2007, 06:11 PM   #14
x99percent
Member#: 27108
2004 STi
2004 A4
Yep.
HELP!!! NEED 04 STI Vacuum Diagrams!!! WRXINTX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-21-2012 12:14 PM
Need 07 2.5i Headers, Please Help djrasta Impreza Forum 5 11-10-2009 02:17 PM
07 Sti ECU Diagram needed Jimmy168 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-14-2008 11:19 PM
07 Sti oil feed line HELP Please BillMac Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 01-26-2008 02:46 PM
EJ20H wiring diagrams. please help snowman4us Subaru Conversions 2 01-17-2006 01:45 AM
