Welcome to the North American Subaru Impreza Owners Club Tuesday January 21, 2020
Old 08-20-2013, 11:35 PM   #201
erixon84
Member#: 354850
2013 WRX Sedan
I was wondering what brand of oil for the engine you fellas recommend.
I have a 2013 WRX and the first oil change was complimentary.
But at almost $100 for the next one, I think I rather do my own.
So as for the oil and oil filter, what do you recommend? Brandwise
erixon84 is offline   Reply With Quote
Old 08-21-2013, 04:13 PM   #202
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Please look at Post #2 of this thread, there is an Oil FAQ listed there. Oil is a touchy subject, as is most of the "what part/fluid should I use questions". There is a list of filters that have the proper valve pressure listed there.
prochucker is offline   Reply With Quote
Old 09-16-2013, 09:35 PM   #203
Reese
Member#: 306479
2012 WRX Limited
Satin White Pearl
Ill be going to the dealership on Friday to get my home link mirror vibration issue fixed. While there I was planning on buying OEM tranny & diff fluid.
Is this still recommended as the A option? Or any others come up the ladder?
Car is 2012 wrx 25k miles.
Edit: I purchase the extended warranty so I will be looking for something that does not void it.
Thanks
Reese is offline   Reply With Quote
Old 09-16-2013, 10:02 PM   #204
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
Motul and redline are also good. Not sure if the dealer sells quarts of the trans fluid..
T_woot is offline   Reply With Quote
Old 09-20-2013, 06:12 PM   #205
Reese
Member#: 306479
2012 WRX Limited
Satin White Pearl
Just took the car in to get the home link mirror fixed.. They do not sell the fluid for either trans or diff by the quart.
I will check out motul and redline! Thanks!
Old 09-20-2013, 06:49 PM   #206
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
Yeah thats what I thought. Sometimes you can find it but it seems like a rare occurrence. You should be able to search up what to buy. Or grimmspeed has a cocktail mix that is descent. Probably not needed for a new car though. Just dont buy the lightweight redline if you go for their stuff, way too viscous.
Old 10-01-2013, 04:25 PM   #207
shamrock 05
Member#: 120057
2018 WRX (base) 6spd
http://www.subaru.com/content/downlo...04SchedFed.pdf
So what is the recommended maintenance for when you are 140,xxx plus miles?
I have done all normal maint as required.
shamrock 05 is offline   Reply With Quote
Old 10-10-2013, 11:49 AM   #208
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Repeat the 90K to 120K sequence.
Old 10-11-2013, 01:35 PM   #209
sk8eroyaker
Member#: 328067
2008 SWP WRX (sold)
2000 BRP RS Coupe
Question guys, I'm about to perform the 60K service on my 2008 wrx by myself. I picked up an intake filter for the stock airbox at advance auto for around $15. The brand of the filter is driveworks or somethingg similar. According to their computer it is a fit for my car. My question is will this filter perform well or is it worth spending the extra money for the OEM paper filter. Thanks for any input
sk8eroyaker is offline   Reply With Quote
Old 10-11-2013, 03:10 PM   #210
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
I have a 2010 WRX that hit it's 30k mark the other day; I have a maintenance schedule brochure that says to replace the brake, differential and tranny fluid.
What do you guys/girls recommend?
I was thinking....
ATE Type 200 (Amber color) Blue Brake Fluid
Redline Lightweight Shockproof for tranny fluid
Mobil 1 75W-90 synthetic gear oil for the differential fluid
thanks!
falconWRX is offline   Reply With Quote
Old 10-11-2013, 10:56 PM   #211
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I'm a fan of motul flyids.
Louie is offline   Reply With Quote
Old 10-12-2013, 08:15 AM   #212
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
I don't know much about motul--
Old 10-12-2013, 08:16 AM   #213
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
how does it compare to the others
Old 10-12-2013, 06:25 PM   #214
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
I was thinking....
thanks!
I wouldn't use the lightweight fluid in the trans.
Old 10-13-2013, 08:42 AM   #215
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
great thanks for the help!
Old 10-14-2013, 09:39 AM   #216
sk8eroyaker
Member#: 328067
2008 SWP WRX (sold)
2000 BRP RS Coupe
Bump. Hoping someone can answer this for me. OEM paper filter worth it or cheap aftermarket?
Old 10-14-2013, 12:34 PM   #217
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
A crap filter is a crap filter. Id return it and buy a k/n filter personally. I use those cheapies on my girlfriends 2000 celica but not on my rex. I like my cobb after market intake as it sounds awesome...
Old 10-14-2013, 12:35 PM   #218
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
However a cheap fresh filter isn't going to be bad for your car in anyway if you still have the factory one in.
Old 10-14-2013, 02:28 PM   #219
sk8eroyaker
Member#: 328067
2008 SWP WRX (sold)
2000 BRP RS Coupe
So I think you're saying since I have the stock intake still that it shouldn't really matter if I use a cheapo filter. Aftermarket intakes do sound cool but I can't justify spending the extra cash for cool sounds.
Old 10-14-2013, 07:56 PM   #220
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
I'd still run a k/n filter. Its a few bucks more but works better and is reusable for life.
Old 10-29-2013, 02:09 PM   #221
redleg93
Member#: 372235
2008 impreza 2.5i
black
Default engine shudders at idle
I have a 2008 impreza 2.5i wagon with 96,000mi on it about 4 weeks ago my head gaskets blew and I had them replaced with oem gaskets and the heads machined it did not require any cylinder work but they noted that the heads were warped the timing belt and water pump were also replaced as well as spark plugs and gaskets.The car is running fine now except when the car is idling it has a very strong shudder to the whole car and. Is idling at around 500rpm and sounds like its about to die the shop says that this is from. Coolant that got into the exhaust and plugged it up. Could this be the cause and if so how much work would it be to fix it myself im not a savant with vehicl maintenance but im also not an idiot about things. And is it bs that they did not take care of it when the had it as they knew it was a Problem? Also the cel comes on about every 3 days with the same exhaust fault and the shop clears it and sends me on my way.
redleg93 is offline   Reply With Quote
Old 10-30-2013, 04:47 PM   #222
Rayzor
Member#: 343257
Are you still able to get these manuals?
Rayzor is offline   Reply With Quote
Old 10-31-2013, 04:23 PM   #223
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Call BS on the coolant in the exhaust, even at an Idle the temps would boil most liquids, and a full throttle run to highway speeds would blow everything out. If everything is OK, your ECU should be able to adjust the idle to the proper range. Sounds like an O2 sensor problem to me.
Old 10-31-2013, 04:24 PM   #224
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Which ones you looking for? You can still find manuals on cd on Ebay for about anything, fairly reasonable too.
Old 12-01-2013, 02:15 PM   #225
SIMPFLY
Member#: 54794
Jan 2004 WRX new
JAN2020 282,000 miles
if you are going with a k&n air filter, make sure you have an extra generic air filter for those days when you are going to over-oil the k&n and need a replacement until the k&n dries and is ready for use.
K&N needs maintenance. If you don't want the hassle of cleaning and oiling use the oem one. buy a 6 pack online and replace every 20K miles.
SIMPFLY is offline   Reply With Quote
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 338 10-25-2019 01:04 AM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 391 08-16-2019 11:49 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 307 07-07-2019 04:40 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 118 12-08-2016 01:24 PM
