Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 02-18-2004, 09:32 AM   #1
Puckaveli
Member#: 1518
00 2.5RS
Default EJ20G wiring issues.
Brief summary of what I got: 93 JDM WRX EJ20G w/ tranny and complete drivetrain going into 2000 RS. I downloaded wiring diagrams from the jimclarkeracing.co.uk site for a pre 96 Impreza. Well after going over them they are about 95% correct. I have the ECU, complete engine harness, front harness, and a cut up bulkhead harness. Here are some issues.
The pinouts are in the pic below, but after going through my ECU plugs pin by pin I found that these pins have wires in them but they are not on the sheets below. I followed them all and this what I found:
B44-16 is cut but the wiring diagrams show it as the power steering oil pressure switch. Even stranger is it's in the wiring diagrams but not in the pinout page.
B43-4 pressure sensor
B43-5 goes to unknown plug.
B96-11 is cut and not in the wiring diagrams so?
B43-12 is cut and not in the wiring diagrams so?
So if anyone has pinouts for an EJ20G could you please look for those.
pinout page 1
pinout page 2
Figured out the "EGT" plug.
Puckaveli is offline   Reply With Quote
Old 02-18-2004, 04:48 PM   #2
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Sorry, I can't be much help, but I am very interested in your results as I will likely be doing a very similar swap later this year.
I have some questions that may help point in the right direction...or maybe they are completely useless
It sounds like you only need to figure these out (the other two appear to be solved).
B43-5
B96-11
B43-12
Where are they cut at?
For the mystery sensor, which connector(s) and pins does it connect to? Can you trace it back to the ECU? Can you take a pic of the sensor?
You could just ignore these for now and see if the ECU diagnostics can give you insight when you try to start it.
-Rob
rob is offline   Reply With Quote
Old 02-19-2004, 10:20 AM   #3
Puckaveli
Member#: 1518
00 2.5RS
The wires are cut where the bulkhead harness divides and goes through the firewall and continues under the dash toward the driver's side.
The second wire from the unknown plug goes to the ECU and guess what pin it is? That's right B43-5 one of the pin missing from my pinout sheet. I have to get the sensor back from a friend, once I get it i'll snap a pic of it.
Old 02-19-2004, 11:24 AM   #4
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Ok, then only 2 more left
B96-11
B43-12
Can you identify which bulkhead connector and pins those are on?
BTW, you said B43-5 was cut, so how did you trace it out to the sensor?
-Rob
Old 02-19-2004, 12:04 PM   #5
Puckaveli
Member#: 1518
00 2.5RS
Both B96-11 and B43-12 are cut about one foot from the ECU so I can't tell where they should go.
I miss read my notes on B43-5 I checked it again last night it goes to the supposed EGT probe.
Old 02-19-2004, 06:50 PM   #6
granteeton
Member#: 53529
i have a pinout for a my97 LHD ej20t if your interested.
granteeton is offline   Reply With Quote
Old 02-20-2004, 08:46 AM   #7
Puckaveli
Member#: 1518
00 2.5RS
So do I and it really doesn't reveal anything but I do appreciate the offer, thanks.
Old 03-01-2004, 04:49 PM   #8
Puckaveli
Member#: 1518
00 2.5RS
So no one else has the pin out for a EJ20G?
Old 03-02-2004, 03:45 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Puck,
Did you get this figured out?
-Rob
Old 03-03-2004, 02:36 PM   #10
Puckaveli
Member#: 1518
00 2.5RS
Well it appears the diagrams I have are for the UK model and I have a JDM model. So I'm enlightened but I'm still in the dark about the ECU pins.
The "EGT" plug is just a "your cat is not working" sensor. Most of the UK guys with imports just unplug it and leave it be when they up grade downpipes, so no issue there.
Old 03-03-2004, 03:00 PM   #11
Structure828
Member#: 50488
1999 GC8 ej20g!
Welcome to my world
Looks like we are in somewhat of a similar wiring hell. My mechanic might have to tow my car 300 miles to Subaru of Jacksonville to some guy that can get the car out of DIAG mode. Or have some hardcore VW wiring expert look at it. Im going on week what... 18 now.... 4 and 1/2 months
Structure828 is offline   Reply With Quote
Old 03-06-2004, 03:51 AM   #12
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
I deleted my comment sorry....
AWJunkies is offline   Reply With Quote
Old 08-23-2005, 05:19 PM   #13
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Trying to close the loop on an old thread.... I have found these two pins listed in the JDM manual.
B96-11 goes to some switch under the dash. Not sure what it's for, I have a listing that it's an accelerator switch on the pedal shaft? I'll hunt around and find it on my clip.
B43-12 goes to some warning bulb in the cluster. Since I sold my cluster, I can't check on this directly.
-Rob
Old 08-24-2005, 02:39 PM   #14
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
The B96-11 switch is indeed on the gas pedal. It's normally closed with the throttle at 0%. Now what in the world does the ECU do with this?
B43-12 is confirmed to go to the Exhaust Gas Temp warning light in the cluster.
-Rob
Old 08-25-2005, 12:36 AM   #15
Storm
Member#: 5218
96L Most Over-
Developed Beater
-Rob
Could possibly be a WOT switch to cycle out the A/C....
[/hijack]
Jay Storm
WTB: EJ20G Wiring Harness and ECU scarless ronin Private 'Wanted' Classifieds 0 08-23-2009 04:42 PM
Noob Question and Problem.... tjwilke UTEC 8 07-04-2006 12:14 AM
Oil change question and problem tubular031 Service & Maintenance 23 09-13-2005 03:49 PM
Wheel Bearing question and problems? ImprezedRS Service & Maintenance 3 05-01-2003 01:02 PM
fog light wiring question and pics. zeke21 Interior & Exterior Modification 0 02-14-2002 09:00 PM
