Welcome to the North American Subaru Impreza Owners Club Wednesday March 3, 2021
Old 12-03-2020, 11:51 PM   #4926
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
That's a pricey tire wearing camber angle. I hope you are getting your money's worth from it.
Fierysun is offline   Reply With Quote
Old 12-04-2020, 12:04 AM   #4927
07imprezRS
Member#: 164302
11 20 STi, 11 STi
07 WRX, 02 WRX
Agreed. They look sweet But I personally donít run more than -2 degrees of camber on my cars. For a track dedicated car, thatís obviously different.
07imprezRS is offline   Reply With Quote
Old 12-04-2020, 12:27 AM   #4928
kaeknows
Member#: 357191
2016 WRX
ISM
I only drive it in the canyons during the weekends, but yeah stock alignment is best
kaeknows is offline   Reply With Quote
Old 12-04-2020, 12:49 AM   #4929
Stoleyourboard
Member#: 483007
2018 Subaru
ISM
Default 18x9.5 +22 255/35/18
Stoleyourboard is offline   Reply With Quote
Old 12-19-2020, 08:59 PM   #4930
Nbrac27
Member#: 501968
Originally Posted by kaeknows View Post
nankang ar1 275/35/18
weds tc105x 18x9.5 +25
This is beautiful
Nbrac27 is offline   Reply With Quote
Old 12-22-2020, 12:28 PM   #4931
kaeknows
Member#: 357191
2016 WRX
ISM
some more pics
Old 12-22-2020, 08:01 PM   #4932
jcwrx
Member#: 25989
2009 WRX Built EJ257
Lightning Red Hatchback
Default The Meaty Tire Thread
Michelin Pilot Sport 4S 245/40/18 ; wheel spec 18X8.5 e44
jcwrx is offline   Reply With Quote
Old 12-24-2020, 01:13 AM   #4933
Savage388
Member#: 488985
2009 wrx
dgm
Originally Posted by jcwrx View Post
Michelin Pilot Spot 4S 245/40/18 ; wheel spec 18X8.5 e44
Any issues rubbing with that much tire and wheel? What suspension is under it?
Savage388 is offline   Reply With Quote
Old 12-24-2020, 10:28 AM   #4934
07imprezRS
Member#: 164302
11 20 STi, 11 STi
07 WRX, 02 WRX
I donít think 245/40/18 is ďmeatyĒ thatís pretty standard affair. I run that on my bugeye with no issues.
Old 12-24-2020, 10:43 AM   #4935
Shiloh51933
Member#: 498320
2005 Saab 9-2x
This looks perfect and it fits perfectly, unlike the silver sedan with negative camber. This red hatchback owner shouldn't change a thing.
Shiloh51933 is offline   Reply With Quote
Old 12-24-2020, 02:48 PM   #4936
Savage388
Member#: 488985
2009 wrx
dgm
On an 08-10 anything wider than stock 225 without camber is tough to fit and be functional.
Old 12-24-2020, 05:50 PM   #4937
kaeknows
Member#: 357191
2016 WRX
ISM
Old 12-25-2020, 05:15 AM   #4938
07imprezRS
Member#: 164302
11 20 STi, 11 STi
07 WRX, 02 WRX
Maybe, offset and wheel size play a factor. I run close to no negative camber at all on a GD chassis. Thereís room in those fenders, even if itís a narrow body gen.
Like I said. Kinda standard affair, which theres nothing wrong with as I run a similar tire and size. Michelin Pilot Super Sports. I Just donít really consider it ďmeatyĒ.
Old 12-25-2020, 05:35 AM   #4939
Savage388
Member#: 488985
2009 wrx
dgm
Maybe, I'm stock height running 17x8 +45 on a 225/40/17 and I don't have tons of room inside or out in the front, my wheel is even with the fender line. The back is different, there's much more room. Here's what I mean, the lip is about flush with the fender, not the greatest shot but the rest are in my camera.
Old 12-25-2020, 09:56 PM   #4940
jcwrx
Member#: 25989
Thank you for the gracious comment. Fitment is an art.
Old 12-25-2020, 10:52 PM   #4941
jcwrx
Member#: 25989
There are many factors one takes into account while creating desired fitment. I like a square tire profile. The goal of this build is sport touring. Meaning, I can put in hours upon hours of seat time, be comfortable, yet have the power curve and suspension profile for aggressive driving. Side wall profile and tire choice played a huge roll in comfort and low noise in the cabin. I could go on....
Current camber specs: Front -0.5 ; Rear -1
Note: Rear fenders are rolled, Front fenders rolled with slight pull ( pictures show fitment before Front roll/pull).
Old 12-26-2020, 09:44 PM   #4942
SilversNova
Member#: 521233
Chapter/Region: HIIC
2008 Subaru
Originally Posted by Stoleyourboard View Post
Man that is a great picture angle. Excellent fitment too.
SilversNova is offline   Reply With Quote
Old 12-26-2020, 09:47 PM   #4943
Savage388
Member#: 488985
2009 wrx
dgm
That's basically my goal since my car is a daily driver, more towards the aggressive side of things I suppose, at -.5 front camber I'm still chewing up the outside of the front tires pretty bad. I'm not a fitment guy though, function comes first so I was curious as to how you fit that much tire under there without rubbing up front. What suspension are you running by the way?
Old 12-27-2020, 07:03 PM   #4944
jcwrx
Member#: 25989
Suspension: Bilstein Cup Kit with RCE Black springs, Cusco LCA, Whiteline toe arms, Perrin F/R swaybars, Legacy SpecB aluminum front lower control arms w/ SiperPro ALK, SuperPro front inner bushing, Whiteline roll center kit, Group N top hats F/R, Whiteline rear swaybar mount brace, Cusco rear member side braces.
Old 12-30-2020, 01:18 AM   #4945
Boost is Best
Member#: 102858
15' WRX
ISM
nicely done
Boost is Best is offline   Reply With Quote
Old 12-30-2020, 01:34 AM   #4946
Savage388
Member#: 488985
2009 wrx
dgm
How much of a difference did the cusco lca's and alk make? I'll be running a similar setup only with rce yellows in the spring and I'm not sure how needed they are or if money can go other places.
Old 12-30-2020, 05:36 AM   #4947
ScoobyGT
Member#: 404382
2004 GDB STI
SanRemo Red
235/40 R17 on 7.5x17 Wheel
ScoobyGT is offline   Reply With Quote
Old 12-30-2020, 01:13 PM   #4948
jcwrx
Member#: 25989
The LCA are paramount for proper alignment in the rear. By lowering your car you will negate any adjustment the OE parts may have in the rear. Which is slim to none to begin with.
The SuperPro ALK adds caster, which should make the car track better. I replaced the steering rack with 13:1 ratio 2015+ STi rack, and added the roll center kit at the same time. So, I donít have an isolated objective opinion of just the ALK. However, I do notice the front wheels sit further forward in the wheel wells with the SuperPro ALK.
I ran GTSpec rear LCA and Whiteline ALK prior, and will say the car feels much more planted and predictable now. I had to run 1Ē top hat spacers in the rear in order to have the car sit even front to rear, with the GTSpec LCA. Elevating the body of the car to achieve aesthetics was what I choose to do back in 2012, when choices of LCA were limited. GTSpec no longer produces the rear LCA for 08-14 MY Impreza, and for good reason. The geometry sucked, period.
In my opinion, quality rear LCA, and roll center kit to a where to put your money. Adding a ALK is icing on the cake, and a major undertaking to install. My $0.02.
Old 01-15-2021, 07:10 PM   #4949
hcosteveo
Member#: 454785
2017 WRX
Not sure this qualifies, but was very happy with the end result
265/35/18 on Work ZR10s, 18x9.5 +38
hcosteveo is offline   Reply With Quote
Old 02-28-2021, 12:24 AM   #4950
T-37
Member#: 175624
0304 WRX WRX
SY WRB
275/35r18 I'm not sure if I've pulled the rear quarters enough yet...
T-37 is offline   Reply With Quote
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 12:53 PM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 02:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 08:52 PM
