Welcome to the North American Subaru Impreza Owners Club Wednesday March 3, 2021
Old 09-06-2020, 12:34 PM   #1
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
Default 2000 2.5RS wrx swap/ej257/ turning into track car
Gonna make a thread here documenting what i do to the car.
rs25.com is very dead these days, this place seems more alive still.
ONTO THE STORY:
bought it 8 years ago after having to sell my 08 wrx.
it came with sti seats, i overpaid, bought it from a kid who withheld info about it, yadda yadda yadda
couple years later replaced all struts/springs with kyb struts and h&r springs.
in 2017 i graduated college and got a good job and decided i wanted to swap it with a turbo since i missed having a turbo.
2018 i found a wrecked wrx about 2 hours away.
picked up engine and harness and that started the headache!
https://i.imgur.com/KGqQty6.jpg
2.5 MOTOR IS OUT
https://i.imgur.com/jDOAIIo.jpg
NEW(to me) motor waiting to go in
https://i.imgur.com/P07Icib.jpg
anthony12052 is offline   Reply With Quote
Old 09-06-2020, 12:59 PM   #2
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
UNSURE WHY PICS ARENT POSTING.... COULD SOMEONE HELP ME OUT WITH THAT?
the swap took a few months.... like 4-5
i did everything myself, with lots of searching and youtube videos.
I did the ecu merge myself (while reading braydens post a million times)
took my time and printed out all the ecu pinouts, labeled wires
made sure i knew what to do before i started cutting wires.
RS HARNESS
https://i.imgur.com/3UCnAwC.jpg
https://i.imgur.com/vbfGdXL.jpg
https://i.imgur.com/U3drmBw.jpg
FUEL PUMP CONTROLLER STUFF
https://i.imgur.com/w6h0fGC.jpg
FINAL PRODUCT, mostly everything has blue tape with label
https://i.imgur.com/JOu8Qjj.jpg
GETTING NEW HARNESS BACK IN
https://i.imgur.com/d4xPErQ.jpg
Old 09-07-2020, 11:27 AM   #3
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
got the harness in, got the motor in.
https://i.imgur.com/sE9tfXm.jpg
i had to buy quite a few parts that was missing from the motor i picked up.
-turbo
-turbo inlet
-stock air box
-boost control solenoid
got it together, got it started. instantly started seeing white smoke. not a lot but enough to make me concerned
tested the coolant to see if it was head gaskets. I asked the girl i got the motor from about the headgaskets and according to her they were never done
i did not believe her since there was about 200k miles on the engine.
Took it out and started tearing it apart.
upon taking it apart one of the bolts that holds the cams in decided to break.
LUCKILY there was enough threads sticking out that i could grab it and get it out without damaging the hole/threads
https://i.imgur.com/Ms97Cj4.jpg
took off heads and stuff to inspect
surprised to see a killer b pickup and baffle
https://i.imgur.com/FpYojEg.jpg
did the headgasket job myself, all new timing belt components/water pump/etc.
got it together started it up to find out it was still smoking.
a buddy suggested the turbo, sure enough i swapped it and bam no more smoke...
a kid sold me a bad turbo claiming it was good
SO I UPGRADED
vf48 out of a 2015 sti with about 30k miles
GR top mount
https://i.imgur.com/E2Q3SDp.jpg
https://i.imgur.com/qKsHVQj.jpg
got them in and it was running good... for now
Old 09-07-2020, 11:46 AM   #4
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
i bought a tune online that included e-tuning
bought a tactrix, and learned how to use rom raider and ecuflash
that was a fun learning experience
spent a few weeks doing data logs, emailing back and forth.
it was going good, until right after thanksgiving.
i was on a drive and i started hearing a noise.
it got louder the more i drove.
i was 10 miles from home and had to drive it back.
this is what it sounded like.... i assumed the worst.
i felt all that work i did was for nothing, like i wasted that entire summer building this car for nothing.
i debated selling it and getting rid of it.
Old 09-08-2020, 01:05 AM   #5
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Could be your timing belt tensioner is not good.
D-Rodman is offline   Reply With Quote
Old 09-08-2020, 03:08 AM   #6
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Could be a ton of different things. At this point if you want to keep it might as well tear it down and build up with better parts at the weak points (pistons, rods, bearings). Could be something less, but why risk the extra trouble of not knowing what you have? Sorry you have had so much trouble, it comes with the territory when buying high mileage items that have a lot of wear. That said- a 2000 2.5RS with a 2.5l WRX engine is an awesome ride. The real problem is that if you didn't swap the transmission you will have a grenade on your hands. Trust me, I'm on transmission #3, where I finally had one built with PPG gears and a front LSD.
Best of luck with getting things fixed.
speedyHAM is offline   Reply With Quote
Old 09-08-2020, 11:04 PM   #7
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
i should have updated sooner!!
SO without digging into it first i just assumed a rod was bent and called it toast.
i took this time to order a IAG stage 2.5 block, cuz why not.
while waiting for that i took the engine out for the 2nd time in under 3 months.
started to disassemble
AND FOUND THE TIMING BELT TENSIONER WAS WOBBLY!!!!
was this my fault? did i not bleed the air properly? no idea.
this is when i learned that gates was outsourcing their pulleys and junk.
disappointing
anywho i thought i could just buy oem idlers/pulleys/tensioner and call it good.
yaaaaaa right.
i put it all back together, started it up and bam i hear some bent valve/valves... awesome
then i started thinking of where to go with it from here
Old 09-08-2020, 11:22 PM   #8
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
MOTOR BACK OUT for the 3rd time with intent to have a shop put everything together on the new iag block that i got. because i wanted it done right, and had a year "warranty".
https://i.imgur.com/gJ5dbDA.jpg
https://i.imgur.com/2yYHUon.jpg
this was an exciting one to show up at my door step
https://i.imgur.com/3V3JRa2.jpg
I disassembled everything off the ej205 labeled everything and took the new block and everything else to a shop in portland in march 2019
https://i.imgur.com/LyhIpgi.jpg
heads got ported and cleaned to match the 2.5l and some other junk went on
picked the car up in september?
and started the break in miles. after 1000 miles i could go back for the power tune.
https://i.imgur.com/s8gourq.jpg
Old 09-08-2020, 11:40 PM   #9
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
while all the engine parts were out/away, the car was still here waiting. i did a few things.
sanded some rusty spots and made it look better
https://i.imgur.com/9PfaeCM.jpg
https://i.imgur.com/d2VRD1H.jpg
made a mount for the extinguisher
https://i.imgur.com/4zqv5lj.jpg
got rid of the back seat and panels
made a deck panel delete thing
https://i.imgur.com/P2JMXFW.jpg
https://i.imgur.com/0slXZxS.jpg
the passenger rear QP on he inside is a mess, it was previously hit and "fixed"
there was a huge hole where the vent thing is/was.
so the trunk would always have water/dust/dirt inside
https://i.imgur.com/1uLl5dV.jpg
https://i.imgur.com/kfuir21.jpg
it was gross. i cleaned it all up, got rid of the sound deadening,
took out the vent and put a cover over it and sealed it up, which i dont have pics of
Old 09-08-2020, 11:51 PM   #10
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
in november 2019 it got tuned. at 18lbs it made 288whp/330tq, at 16lbs it made 281/311.
i constantly run the 16lb map.
boring little video i made when i got it back.
oem sti catback w/catless downpipe
TBC
Old 09-13-2020, 10:50 PM   #11
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
i wanted to turn this car into some sort of race car.
in 2019 i watched the rose cup in portland, and i was hooked and wanted to try track racing.
This was my first track day on june 18th this year.
https://imgur.com/a/KxUHxB8
a little in car footage from the event.
this was my first time at ORP let alone on a track.
After reviewing some footage i realized i was being very cautious. But i figured thats a first timer thing.
Old 09-13-2020, 11:02 PM   #12
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
that track day was a blast. i shaved time off each session.
by the end of the day i shaved my time down by 35 seconds. To me was a big accomplishment.
the 2nd track day i did was with bridge city autosports. and this one included a instructor.
this event was at PIR in portland.
with a lead follow type setup which was weird. but i still learned a lot.
did not focus on time here and focused on proper braking and proper race line/apexing/etc.
short video
Old 09-26-2020, 11:51 AM   #13
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
on monday 9/28, i have a track day at oregon raceway park.
probably final event for the year.
it will be run counter clockwise which is different than my first time a few months ago.
should be a fun change.
Took front driver fender off to sand down and primer.
doing it panel by panel until its all primered.
installed some whiteline front endlinks that i got for a deal on ebay.
to do's before track day:
rotate tires
oil change
finish fender and install
check air filter
do tech inspection for track day.
Old 09-26-2020, 03:40 PM   #14
snow_bound26
Member#: 395793
2005 92x Aero
Beige
I really want one of these to make into a track toy as well. OR raceway looks really fun. That track hadn't crossed my radar. Might have to make a trek out there one day.
snow_bound26 is offline   Reply With Quote
Old 09-27-2020, 12:52 PM   #15
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
its a cool track!!
worth the drive out there to check it out.
Old 10-03-2020, 12:15 PM   #16
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
went to another track day last monday.
northwest autocross association put it together.
they ran it counter clockwise, so it felt like a new track
on session 4 i hit fuel cut 2 or 3 times coming out of a right hand turn. decided to skip the last 2 sessions and just pack up.
now i need to figure out what to do to fix the fuel starvation.
ive seen a anti slosh mod on 25rs.com, i might give that a try.
Old 10-03-2020, 07:17 PM   #17
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Oregon Raceway Park 2 laps counter clockwise|swapped 2.5rs - YouTube
Another option is a surge tank. I'm looking into options as well.
Old 10-04-2020, 01:04 PM   #18
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
ya but that is spenddddyyy!!!!
i'm on a budget here haha
Old 10-19-2020, 10:23 PM   #19
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
hopefully more track days next year.
I need some opinions on what to do over the winter to the car.
i got some items that i have in mind.
-better tires *these all seasons are terrible*
-oil cooler?
-oil pressure gauge
-iag AOS
-find a way to paint car.
probably find some rear end bushings to swap out
Old 11-22-2020, 01:02 PM   #20
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
no work has been done.
i did notice oil "vapor" on the outside of the head vent hoses that goes back to the intake
and also on the rubber elbow from the top mount to turbo
light oily substance... idk doesnt seem normal
hopefully buying a IAG AOS this winter to help with that smoke on startup.
im home for 2 weeks for quarantine because i was exposed.
going to try and start sanding the car.
Old 01-12-2021, 10:39 PM   #21
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
got the iag aos a month after i purchased it on black friday.
took a week to do the install (working on it an hour after work each day)
what a pain in the ass it is to do on a gc. with the smaller engine bay it makes things very tight in there.
i put my arm on a bad spot on the upper coolant reservoir and snapped a nippe off, so i cant even start the car until i get a new one.
been reading and doing research on 6 speed swap stuff.
Old 01-15-2021, 09:03 PM   #22
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Glad to see you pushed through the BS and have enjoyed the car. I would always recommend bugging the guys at pro drive up at PIR a try, did there skid car stuff back in high school and enjoy the people that they section off for the 3rd group (advanced) its a great time!!! Been running with them and such forever!
I have been a fan of toyo 888's for a long time, heat up well but hard to overheat with a hard sidewall. I would also say add the pressure and and temp guage, both are helpfull.
Not sure what "small town" your in but if you ever need parts (I have a spare upper coolant tank) or help feel free to pm me, nice to see you tracking that car.
Scuby04STi is online now   Reply With Quote
Old 01-16-2021, 12:23 PM   #23
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
I live in the dalles. i did a learning event at pir this past summer with bridge city. it was a fun even and learned a lot. it sucks because of covid its a lead follow type setup.
yea i def need new tires for this year!! hopefully i can swing something decent instead of the crap all seasons i have now.
I am wanting to get it painted before spring but not sure what route to go, theres body work and small rust spots in the quarter panel/trunk area that i dont want to put money into getting fixed.
Also i appreciate it but i have a coolant tank showing up Wednesday. got it on ebay from go fast tuner bits/parts.
