View Poll Results: Please report your oil consuption here for the vehicle you own(ed) | |||
2011-14 Forester - Excessive Consumption | 13 | 13.68% | |
2011-14 Forester - Normal/No Consumption | 8 | 8.42% | |
2013 Legacy - Excessive Consumption | 2 | 2.11% | |
2013 Legacy - Normal/No Consumption | 4 | 4.21% | |
2012-13 Outback - Excessive Consumption | 4 | 4.21% | |
2012-13 Outback - Normal/No Consumption | 5 | 5.26% | |
2012-13 Impreza - Excessive Consumption | 34 | 35.79% | |
2012-13 Impreza - Normal/No Consumption | 30 | 31.58% | |
Multiple Choice Poll. Voters: 95. You may not vote on this poll |
01-09-2016, 12:45 AM | #226 |
Member#: 3409
NWIC
Vehicle:98 My FMIC Is bigger than yours. |
01-09-2016, 12:45 PM | #227 |
Member#: 44652
BAIC
Vehicle:16 Colorado diesel ATC Bobcat Pop-up |
Strange, my 2015 Forester 2.5i 6MT has seemingly stopped consuming oil by 22k miles. Had issues early on, kept using the 0w20 syn, just sorta stopped doing it I guess. Just finished a 700+mi roadtrip over new years and no issues, checked oil before during and after.
GF's 2015 XV 5MT also has stopped consuming, seemingly. No noticeable consumption since early on as well, she drives it 5 days a week, 70mi commute, its been full winter here, snow dumps, temps down to negatives a lot lately and doing fine. Weird, but I'll take it. |
01-11-2016, 01:08 PM | #228 |
Member#: 88514
HIIC
Vehicle:2010 Outlander XLS Brown Metallic |
Subaru settles oil consumption lawsuit:
http://www.torquenews.com/1084/subar...mption-lawsuit "Subaru has agreed to extend its 5 year, 60,000-mile warranty in respect to the alleged defect to an 8 year, 100,000-mile warranty. SOA will also reimburse certain expenses for vehicle repairs, rental cars, towing and the purchase of up to six quarts of oil per vehicle with appropriate proof." |
01-11-2016, 04:38 PM | #229 |
Member#: 432963
SCIC
Vehicle:2013 Impreza Hatch Deep Cherry Pearl |
2013 Impreza with normal oil consumption to no oil consumption here.
01-14-2016, 05:08 PM | #230 |
Member#: 266179
Older Subarus with excesive oil consumption
Where's the love?
I have a 2010 Forester (87K miles) and a 2007 Impreza (122K miles). Both have been well cared for and have no visible leaks and both have PCV valves replaced. Use synthetic 5W-30 on both and change oil every 5000 miles with new filter. Driving does involve short trips 7 miles (10 minutes) each way. Impreza burns up to 4.0 quarts over 3000 miles, Forester burns 1.5 quartz over 3000 miles. Really, what gives? I have never owned a car that burns that much oil. In addition to oil consumption, the Impreza has had: New alternator (70K), Real wheel bearing (90K), new exhaust (95K), the list goes on and on. Does this sound normal? Thank goodness I can do most of the work myself. |
01-15-2016, 09:14 AM | #231 | |
Member#: 415635
NESIC
Vehicle:2016 WRX Limited 6MT Lapis Blue Pearl |
Sounds like you got subaru's special 2 stroke motors In all seriousness, no, this does not sound normal. Are you the original owner of both cars? |
01-15-2016, 01:21 PM | #232 | |
Member#: 88514
HIIC
My 2002 Impreza (EJ25) had the head gasket issue and was leaking I think a 1 qt between 3k mile changes. Probably need to start a new thread on that matter to be honest. Doesn't sound related to the newer motors oil consumption issue. |
01-23-2016, 01:52 PM | #233 | |
Member#: 94945
Vehicle:2015 Dodge Charger AWD |
Is it possible that your commute changed, or you started using an engine block heater? Cold engines, short trips, stop & go, etc, all affect consumption rate. |
01-25-2016, 04:14 PM | #234 |
Member#: 4876
Vehicle:2006 WRX San Remo Red |
I think this is funny because I am currently dealing with Honda on excessive oil use on my wife's Pilot. According to Honda, anything under 1 quart per 1,000 miles is normal. I am having an "oil consumption test" run now to demonstrate to them that I am burning more than that. Honda has 10,000 mile oil change intervals, so I pretty much have to add 10 quarts of oil in between oil changes just to keep it topped off. If it weren't for the filter, I wouldn't need to change the oil at all due to the constant burning and refilling.
01-25-2016, 04:33 PM | #235 | |
Member#: 44652
BAIC
01-31-2016, 04:35 AM | #236 | |
Member#: 439350
Nor true .. now im getting a new motor build because some suit... Push them to fix my
Wwwwxhjihjkjgjklk
02-06-2016, 04:47 PM | #237 |
Member#: 361330
Vehicle:2013 Impreza 5MT |
I have 22800 miles on my '13 5MT Sport Premium Impreza. I have gone about 1700 miles since my last oil change and the oil has dropped about 1/4 to 1/3 of the way from the "full" mark to the "add" mark on the dipstick. The dealer slightly overfilled at the last change, as well. So it appears as though I am getting close to the unacceptable consumption rate. My question is this: has anyone had an engine replaced within the past 3-6 months? Was the oil issue cured? Did things go smoothly after the replacement? I question whether an engine installed by a dealership service center could ever come close to the quality of the factory. Any insight would be helpful.
02-06-2016, 10:52 PM | #238 |
Member#: 310672
Vehicle:2012 Impreza Ltd 5Dr Dark Gray Metallic |
I had the short block replaced in my 2012 Impreza CVT in January 2015, at 42200 miles, and the engine is now at 54100 miles. I was also concerned about the quality of the work, but have had zero problems. The oil consumption (by my own measurements, not the dealers) was 2678 miles per quart before the short block replacement, and 11600 miles per quart afterwards.
The quality of the work will depend entirely on the technician. I would choose the dealership carefully. Carlsen Subaru in Redwood City, CA, did the work on my car. I broke in the short block with some full and part throttle acceleration. My only concession is that I am now using Subaru (Idemitsu) 0W-20 instead of Mobil 1 AFE 0W-20. Apparently there are different wear additives. I hope that this time, the oil control rings hold up... |
02-07-2016, 02:42 AM | #239 | |
Member#: 439350
02-07-2016, 03:24 AM | #240 |
Member#: 439350
Details of my experience with Subaru
FB2.0 at 30000 miles notice oil loss about 1/4 to 1/2 quart. 31000 miles oil light comes on. to the dealership for a test. Unknown to the service guy I took pictures of oil level, mileage before and after the test. Upon return i missed the 1200 miles because of bad weather and holiday weekend. took the car in at 1400 miles. Service guy tells me that it only burned about a 1/2 quart of oil upon returning my car to me. And that it didnt qualify and I could take it up with SOA if I felt he was wrong. Before I left I told him if it only burned a 1/2 a quart then when we go out to check it it should be at the top hole on the dipstick. I smiled as we walked out to the car. He checked it and it was 1/2 from the top. I told him i read the class action lawsuit and post online about what was going on with dealerships and that I did not blame him for doing what he was told to do. Left dealership called SOA and told them how I felt and sent them my pictures. Now when i called two dealerships i was told a quart was acceptable but when I confronted them it went from a 1/2 quart on one conversation to 1/8 of a quart on the next call. SOA explained that I had to have the car in by 1200 miles in order for dealership to be paid to replace the motor. dealership told me the car had been tested once before and passed. And that it was not eligible for another test. SOA said that was not true and asked if I wanted to go to another dealership. I told them i was not mad at the first one and we can go back there for another oil test. 1160 miles later 1.1 quarts used. what do I get. a new short block with a 1 year unlimited mile or 3 year/36000 mile warranty on the block. They put all the other parts back on like the intake and surrounding motor parts. The internals are supposed to be replaced. I have been reading about replacement that have issues but I am hoping for the best. One thing to consider if the car starts burning more than a 1/4 of oil in 1k miles is it will continue to get worse. Mileage will decrease and the motor will sound different as it gets low on oil. My concern is what damage is caused by excessive oil burn to other parts of the motor if any.
02-07-2016, 11:54 AM | #241 |
Member#: 361330
Thanks for the feedback, much appreciated. I will monitor and have a consumption test done when it is time.
02-07-2016, 12:22 PM | #242 |
Member#: 406369
Vehicle:2012 impreza silver |
I have a 2012 impreza i bought used with 30k on it. When I first changed the oil I thought it was burning oil because when i changed it I only put 5 qts in. I would check it a few weeks after I changed it and it would be down a qt. But now I realize it takes 6 qts, So I just buy some kind of addative like slick 50 or lucas oil and throw a qt in when i change it. Now I have 70k on it and it uses no oil between changes. I have done nothing to the engine. I love it. Although sometimes it starts hard. But It always starts and runs fine.
02-07-2016, 12:57 PM | #243 |
Member#: 439350
oil consumption class action lawsuit
more info
aegar v. Subaru of America, Inc. et al., No. 1:14-cv-04490 http://www.girardgibbs.com/subaru-oi...ction-lawsuit/ http://www.torquenews.com/1084/subar...mption-lawsuit |
02-07-2016, 01:31 PM | #244 |
Member#: 361330
I wish something as cheap and easy as an oil additive would be a fix. Are you worried about masking an underlying problem?
02-07-2016, 04:11 PM | #245 |
Member#: 406369
Nope Not worried about a problem. I just buy a 5 qt container. And the additive is not that much more then an extra qt. Also I figure it cant hurt.
02-08-2016, 11:28 AM | #246 |
Member#: 361330
At this point I will just monitor the situation and take it to the dealer when time. The oil seems to burns progressively faster with mileage.
02-12-2016, 09:42 PM | #247 |
Member#: 372004
NESIC
Vehicle:2013 XV Crosstrek Venetian Red Pearl |
I've taken my XV to the dealer and they said it was within spec because of the viscosity of the oil to consume about an eighth of a quart per 1,000 miles. I am taking my car to a local shop to try Motul to see if that will help as it is supposed to help with consumption issues.
02-12-2016, 10:10 PM | #248 |
Member#: 361330
Please keep us posted. I'd be thrilled if another oil was the solution.
02-14-2016, 10:27 AM | #249 |
Member#: 361330
Has anyone had luck with specific oils mitigating consumption?
02-24-2016, 05:36 PM | #250 | |
Member#: 132389
BAIC
But, IMO, if you still can, get your engine replaced under warranty. The difference between the new FB25 short block in my Forester and the original FB25 short block that was in there is really night and day. More power everywhere in the rev range and, so far, I can't notice any consumption on the dipstick. I went up in snow country (Lake Tahoe area) last month and the engine was really running well even at 6000 ft. The car never ran that well up there. |
