Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 07-08-2007, 02:42 AM   #1
Fused
Member#: 129818
1997 GF8 Impreza R6
2004 JDM BE5 Legacy B4
Default Electrical Question, COP -> Wasted Spark conversion
I have here a coil-on-pack equipped 1990 JDM BC5 GT, which is misfiring like a dog (dud ignitor), so rather than replace bits over and over again as one seems doomed to do with a coil-on-pack setup, I'd like to make use of the 2ch 95 impreza wasted spark gear i have here. What I need to know is this. can I combine, pre ignitor, the ECU ignition trigger outputs into pairs directly to drive a 2 channel ignitor? I would say yes from my knowledge (would expect them to be standard transistor driven signal outputs), but would like confirmation from someone with a little more. Otherwise, building an OR gate type setup to drive the ignitor is an option.
Cheers.
Cameron
Fused is offline   Reply With Quote
Old 07-08-2007, 08:33 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
well simple form would just be two rectifying diodes to "sum" the two ecu coil driver outputs, but you'd have the voltage drop across the diode (typically ~0.7v) taking some of your spark energy.
it would probably be fine despite that fact.
other than that probably inconsequential issue, i can't see any reason why it would not work. however, i have never done it myself.
hth
ken
edit: if you try this out, consider using schottky diodes instead of normal PN diodes... the lower voltage drop (around half that of PN diodes, or ~0.3v) means higher efficiency and less waste and they are generally much "faster" than PN diodes. the only thing with schottkys is the fact that they are not available in high reverse voltages, and i don't know what kind of flyback you'll be seeing from the coil primaries.
Old 07-08-2007, 05:44 PM   #3
Fused
Member#: 129818
1997 GF8 Impreza R6
*points out that the mod would be pre-ignitor, not post*
I could probably get away with using a pair of transistor-based OR gates? given the signal is a 5v low current pulse. My main concern is the lag time of the components, and the fact the pack may not get enough dwell time (ive heard that subaru COPs usually use 3 or 5ms, but wasted spark packs prefer 7 or 9)
Wasted Spark Conversion kbahus Pre-2002 Factory Turbo Powertrain 9 06-26-2007 10:29 PM
EJ22 > EJ18 cam conversion question pilfflip Subaru Conversions 1 05-22-2006 07:09 PM
Another RS -> WRX brake conversion question Rabidbyte Brakes, Steering & Suspension 1 05-05-2004 05:11 PM
Waste spark ignition info RallyNavvie Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-06-2002 04:00 AM
CAN -> US Bumper conversion question Billy Canada Region Forum 6 08-14-2001 03:16 PM
