Welcome to the North American Subaru Impreza Owners Club Monday May 21, 2018
Old 09-30-2005, 10:45 PM   #1
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Default the threading on the block for my headers is striped
yea the threading is stripped out on the block for one of the screws to hold the headers on to the block, so now what do i do ?
99subi is offline   Reply With Quote
Old 09-30-2005, 10:57 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
heli-coil it.
Tim Sanderson is offline   Reply With Quote
Old 09-30-2005, 11:07 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Put a helicoil in it. You should be able to find them at your local auto parts place or hardware store. http://www.emhart.com/products/helicoil.html Not too hard to do, but you'll almost certainly need to drop the header to give yourself clear access to the hole. I know in the 5.0L Mustang world some aftermarket aluminum heads (either Edelbrock or AFR, I think) come with all the bolt holes helicoiled from the factory, so it's a durable and accepted way to fix (or strengthen) damaged threads. I've used them a couple of times here and there with no problems.
Pat Olsen
Darn it... Just stripped the threads on the bolt that holds the knock sensor in. Surestick Normally Aspirated Powertrain 3 04-21-2010 05:28 PM
what is the size of the piping on the stock header? Adreniline Rush Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-09-2009 04:41 AM
GTF is the Bitch On The Block For New Kids With Cawks? imprezton Off-Topic 19 12-15-2005 05:04 PM
looking for the best thread on the intraweb....ass on bike Walt2GPinPA Off-Topic 8 12-28-2004 02:11 PM
This is the best mod evar, be the first on your block to die! Puckaveli Off-Topic 16 02-26-2004 09:27 PM
