10-03-2012, 01:05 PM | #1151 |
Member#: 326540
BAIC
Vehicle:2012 Impreza MT SP DGM |
10-03-2012, 01:20 PM | #1152 | |||
Member#: 73068
Vehicle:2008 STI Boost Wagon 2014 Honda Accord Hybrid |
Either you're silly, or you're a troll. Quote:
You'll spend more on the car to make it faster than it would be to just buy a WRX. Taking an econobox and having high ambitions will burn a hole in your wallet with not proportional gains. Not trying to squash your hopes and dreams, just giving you the reality of the matter. *Edit, I think I'm feeding a troll. |
10-03-2012, 01:22 PM | #1153 |
Member#: 334032
Vehicle:2012 Impreza 5 door Black |
Yes, The image with the intake on the car is before I fabricated the plate for the sensor. The Second is the MAF housing, plate, and the sensor being bonded with silicone.
10-03-2012, 01:28 PM | #1154 |
Member#: 317014
Vehicle:2017 Crosstrek ISM |
Looks awesome but it isn't going work on the NA FB20 motor with the MAF sensor. Go to the NA threads on the forums and read up on the CAI/SRI threads and you will learn that the 'Hybrid' mod is the only way it will work right. Hope Williarty isn't reading this...lol
10-03-2012, 01:37 PM | #1155 |
Member#: 73068
*PHEW* Not a troll! Vacuum leaks in the intake path can cause a CEL. Scan your code.
10-03-2012, 01:42 PM | #1156 |
Member#: 317014
I do like the black strut tower brace Grizzuhl. Cusco or Ebay?
10-03-2012, 02:00 PM | #1157 | |
Member#: 329271
South East
Vehicle:2012 Impreza Limited Ice Silver Metallic |
10-03-2012, 02:06 PM | #1158 |
Member#: 189032
Vehicle:2015 STI CWP '12 Impreza Sport Ltd DGM |
The problem with intakes is the MAF scaling. The ecu thinks it is ingesting a certain amount of air based on the stock intake plumbing. If you modify it it is likely flowing a different amount of air. The ECU needs to be re-scaled for the new air flow rate. Otherwise your car could be totally confused as to why the AFR is not behaving the way it was expecting. This could result in a too rich or a dangerous too lean condition.
10-03-2012, 02:43 PM | #1159 |
Member#: 334032
Thanks guys, I am much more informed on my intake project thank before. I will defiantly be doing more research into MAF Scaling and leaks. When I read my codes I did have a system lean error code so that will do it. It is all just a learning experience, hopefully I don't do anything that will lead to permanent damage
As for my Strut Bar, I ordered it through the dealership. I believe the product code is SOA8431130. |
10-03-2012, 03:24 PM | #1160 |
Member#: 317014
Thanks. I didn't know that Subaru had released a non-adjustable strut brace because the adj. SPT one is 500.00 which is crazy....How much was it?
10-03-2012, 03:35 PM | #1161 | |
Member#: 329271
South East
10-03-2012, 03:39 PM | #1162 |
Member#: 323103
Vehicle:2018 WRX Pure der |
Typing in "SOA8431130" into google shopping shows prices around $200 for the spt strut tower brace front
10-03-2012, 03:55 PM | #1163 |
Member#: 334032
Yeah, I got mine for about $230. It took just about a day to ship to the dealership. When I went to order it, the parts department said it was new to the SPT catalog.
10-03-2012, 04:08 PM | #1164 |
Member#: 323103
apparently the SOA8431130 strut is shared between 09-11 forrester and impreza according to google. idk. i want it tho. lol
10-03-2012, 04:19 PM | #1165 | |
Member#: 326540
BAIC
I thought i red somewhere about one that almost fits, but not quite. Hopefully this isn't the one I'm thinking of cause I want it too |
10-03-2012, 04:20 PM | #1166 |
Member#: 317014
Glad to know because I waited 7 weeks for my Cusco brace. Thanks Subaru for just letting us know now...haha
10-03-2012, 04:27 PM | #1167 |
Member#: 334032
It doesn't rub it's really really close to doing so though.
10-03-2012, 09:18 PM | #1168 |
Member#: 317014
Got the Cusco brace installed this evening and snapped a quick pic...Love it!
10-03-2012, 09:24 PM | #1169 | |
Member#: 308742
Vehicle:2012 Impreza Sport Marine Blue Pearl |
http://www.ebay.com/itm/260853047915...84.m1423.l2648 |
10-03-2012, 09:47 PM | #1170 | |
Member#: 334032
I got most of the holes sealed it seems. When I first started up the car I got just under 2000 rpms, took it around to see if there where any holes. I heard some hissing. Turned it off checked the piping and it started up at just under 1000 rpms. So, there's defiantly a lot more work to do. |
10-03-2012, 09:53 PM | #1171 |
Member#: 73068
Just be aware that if you have engine problems it won't be covered under warranty.
10-03-2012, 11:03 PM | #1172 |
Member#: 315759
Vehicle:2014 WRX Hatch Satin White Pearl |
10-03-2012, 11:46 PM | #1173 |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
10-03-2012, 11:51 PM | #1174 |
Member#: 315631
Vehicle:2012 Impreza Sport |
10-04-2012, 12:04 AM | #1175 |
Member#: 315759
or just make them yourself. if you search around you'll find the how to. i was planning on this at some point, not pink but same difference. Once you get the badge off, goof off takes the paint right off the inside of the emblem leaving the chrome stars and a clear background ready for your paint of choice. i'm assuming the 2012 emblem is able to be modified like this as well.
Similar Threads | ||||
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? | somebody else | Southern California Impreza Club Forum -- SCIC | 3 | 12-23-2015 04:34 AM |
factory SS or aftermarket for 2012??? | Myth21 | Transmission (AT/MT) & Driveline | 8 | 01-07-2012 11:18 AM |
Has anyone test drive a 2012 Impreza yet? | pRiMe DiReCtIvE | General Community | 25 | 11-28-2011 10:03 PM |
Hybrid Impreza in the works for 2012? | rsholland | News & Rumors | 43 | 03-12-2010 10:58 PM |
