09-19-2006, 07:15 PM | #1 |
Member#: 93382
SCIC
Vehicle:2005 Impreza WRX obsidian black pearl |
misfire on all cylinders
so this past weekend i was going about 125 on the freeway and i was pushing my car harder to go faster cus this guy next to me in his new 545 was trying to have some fun with me, he must have thought i was some honda, so then all of a sudden my cel starts flashing i have an 05 wrx with a tbe, perrin crank pulley, cobb ap, clutch and a prolite flywheel, do you think i got the misfire on all 4 cylinders from the prolite flywheel?
09-19-2006, 07:56 PM | #2 |
Member#: 109725
Vehicle:2001 GM6 SRP |
i would say the flywheel, i've heard of lighter flywheels doing some weird stuff with the knock sensor.
09-19-2006, 07:58 PM | #3 |
Member#: 83294
BAIC
Vehicle:2011 E90 M3 2011 Prius |
Here we go...
09-19-2006, 08:02 PM | #4 |
Member#: 54378
South East
Vehicle:2023 WRX WRB |
IBdia-streetracing-f
09-19-2006, 09:26 PM | #5 | |
Member#: 124053
Vehicle:2002 WRX Back to BONE STOCK |
and that CEL flash isn't a misfire... its a knock.... could be misfire, could be detonation, could be preignition... all you know is something is ****ed up inside that cylinder wall... maybe you need new spark plugs or something i dunno i'd go check it out |
09-20-2006, 10:39 AM | #6 |
Member#: 90085
Vehicle:2009 |
From numerious reports here, ltw flywheel isn't a good combo with a ltw crank pulley.
09-20-2006, 11:16 AM | #7 |
Member#: 94605
Vehicle:2005 Saab 9-2X Aero Midnight Black |
I heard somewhere that too light of a flywheel will make the timing belt jump a tooth. Don't know for sure, just thought I'd chime in.
09-20-2006, 11:37 AM | #8 |
Member#: 93382
SCIC
thanks for all the replies and the help, and it wasnt street racing it was ****ing around with the guy, im thinking about selling my pulley but i love the way my car feels with both, its just awesome, oh and by the way i have no problems whatsoever with my car as of now, idles perrrrrrrrrrrrrrrrrfect, and it runs really well, i destroy evos with intakes and exhausts, same with stis'. ill watch what happens do some tests ask my buddys over at harman, still want to go get a protune from them but anyway
09-22-2006, 04:00 PM | #9 | |
Member#: 124053
lol |
09-22-2006, 05:54 PM | #10 | |
Member#: 54412
RMIC
Vehicle:2002 Impreza WRX WRC Blue |
Viggy |
09-22-2006, 06:44 PM | #11 |
Member#: 882
Vehicle:2004 WRX Wagon very blue |
Per federal (or at least California) requirements, the Malfunciton Indicator Lamp (MIL or CEL) will flash when a level of misfire has been detected that is deemd to be high enough to cause immediate catayst damage. Basically, this means the OBD software thinks you're misfiring bad enough to get catalyst temps up over like 1100 degC or so. (see http://www.nyc.gov/html/tlc/download...ro_to_obd2.pdf)
This could be "real" misfire, but it is more likely that the combination of lightweight flywheel and pulley threw off the OBD system. Misfire is detected by measuring very small variations in crankshaft RPM. Lightweight flywheels and/or pulleys reduce engine inertia, which will directly increase the "cyclical" variations in engine speed. (i.e. small changes in RPM with each cylinder firing). It has been reported on various scoobys that this can cause false detection of misfire, although it is typically a problem at idle I believe. Since you don't have any cats (you did get rid of the uppipe cat, right?) cat damage isn't an issue so it was probably a false detection. If you feel any hesitation/miss/etc. I'd grow more concerned and look at your ignition system first (most common misfire cause). For more info than you ever wanted to know about misfire, check the "Diagnostic Trouble Code Detecting Criteria" section of the service manual. Of note is the fact that some older (pre-OBD2) vehicles did indeed flash a light based on various other feedback mechanisms, including engine knock detection... Edit -- found it in the service manual under "Malfunction Indicator Light": 3) If the diagnosis system senses a misfire which could damage the catalyzer, the malfunction indicator light will blink at a cycle of 1 Hz. Last edited by TMessick; 09-22-2006 at 06:58 PM. |
09-23-2006, 12:36 PM | #12 |
Member#: 101730
South East
Vehicle:02 WRX Stage III+ PPG Reppin! |
I just took my car in for inspection, and for the first time Im showing a misfire on all 4 cylinders, I feel like it was because I set my UTEC, to an un-normal stage ( what I thought was valet mode.) Because when I run it with UTEC in 6 it does run a little sluggish and weird....I normally run it on 3(which is Stage III)
anyone heard of a tuning change throwing up a misfire on all 4? also, my check engine light isn't coming on because of it..... odd someone help...ahh I have a lightweight flywheel (fidanza), but like I said, my car hasnt thrown the Misfire out before |
09-23-2006, 12:58 PM | #13 |
Member#: 124053
09-23-2006, 01:04 PM | #14 |
Member#: 41863
NESIC
Vehicle:2015 STI Crystal Black Silica |
I'm sorry...cant let it pass...Destroy? STI's? Come down out of the clouds son, do you want help? Then why a statement like that? Did you have the car dynoed? did you do your own mods? maybe thats the problem?
If you've been in there...check your vacuum hoses and intake hoses...pay particular attention to the pcv hose, it couldve popped off. Next time you want to play...come my way...I'll show you how its done. |
09-23-2006, 11:19 PM | #15 |
Member#: 61197
Vehicle:2004 WRX vf39 + goodies... |
i hope you're not still on stock tires...
09-26-2006, 01:37 AM | #16 |
Member#: 93382
SCIC
wait i dont understand why it would matter if i were on stock tires (sarcasm), off-topic ya those stock tires suck, but ya i looked around and i didnt see any hoses off, i tugged on some and they were all tite, i havent had time to check the pcv hose its kinda hard to get to (its under the intercooler right?) but this weekend ill check around for that too, thanks for all the great comments guys, and yes STI's not all but some, and no im not going to drive cross country to come race you hahahaa
09-26-2006, 01:57 AM | #17 | |
Member#: 92003
SCIC
Vehicle:04 bicycle! |
09-26-2006, 10:24 AM | #18 |
Member#: 34832
Vehicle:1989 M3 White |
did the car buck at all? if it was really missing at that kind of RPM i'd think you would notice it for sure.
I have a LW flywheel. I get misfires on all four... all the time. |
09-26-2006, 01:26 PM | #19 |
Member#: 9106
SCIC
Vehicle:2015 FXT - DGM 2008 STI - Aspen White |
Back in the day, I got solid CELs (misfires in all 4) at idle/near-idle with an ultralight flywheel. They were apparently just the crank angle sensors getting confused by the change in deceleration that the lighter FW allowed.
It wasn't really a big deal, and there are reports here that SOA is now reflashing the old ECUs to make them less sensitive. Flashing CELs are usually a more urgent indicator of a malfunction. |
09-26-2006, 02:22 PM | #20 |
Member#: 92670
Vehicle:03 WRX Silver |
CEL flashing light is not a mis fire, its engine noise, either caused from pinging, detonation, pre-ignition, or just plain and simple engine noise. UTEC can be set to pick up the slightest engine noise and report it...
09-26-2006, 09:07 PM | #21 |
Member#: 59112
Vehicle:02 wrx silver |
How sensitive will the utec be set on a stock ots map?
03-06-2012, 10:24 AM | #22 |
Member#: 263720
Vehicle:2003 wrx blue |
A tuning change can definately trigger a misfire in all four cylinders. I went from a Perrin fmic to a process west tmic on my 03 and before I had a chance to retune it I had to drive it. The tune was way too rich which led to 4 fouled plugs and misfires
03-06-2012, 11:04 AM | #23 |
Member#: 70395
The ****ing thread was from 2006....................
03-28-2012, 05:59 PM | #24 | |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
Idiot! |
CEL - misfire on all cylinders | Cannonbolt | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 12-29-2013 12:18 AM |
Still Misfiring on all cylinders?! | crazycanasian | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 08-16-2009 03:33 AM |
MisFire on ALL cylinders | crazycanasian | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 08-14-2009 02:54 PM |
Misfire On All Cylinders | scoobysti05 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 08-17-2006 06:40 PM |
Misfiring on all cylinders? | Subaruski | Service & Maintenance | 10 | 07-05-2005 10:59 AM |
