05-31-2010, 01:35 PM | #1 |
Member#: 225784
Exhaust Hanger Question
I've been doing some searching on this and can't really find a definite answer. I recently purchased Borla headers, track pipe, and a type XA-stromung cat back which has a 3inch tip on it. Does anyone know what size hangers I should use for this setup? Should I just use 12mm all around? or will that cause the tip to rub against the bumper? Or could I do all 12mm except by the cat and do a 12mm XL or a 15mm? Thanks for the help just a little lost and confused
<<<O ya and my car specs are over here<<< |
05-31-2010, 01:48 PM | #2 |
Member#: 22664
The regular sized hangers will work fine, I always say just upgrade them to stiffer ones like Kartboys
05-31-2010, 01:56 PM | #3 |
Member#: 220259
Vehicle:09 2.5i SSM |
Shoot kartboy a PM, I'm sure he'll take care of you
05-31-2010, 02:17 PM | #4 |
Member#: 192553
Vehicle:'04 sti aw |
you'll need the 15mm hole diameter (if i'm not mistakin 15mm is for '07 below and 12mm is for '08 up) and you'll probably fine with standard hanger, since your tip is only 3".. but i pm tom@kartboy just to be 100% sure
Similar Threads | ||||
Apexi N1 exhaust hanger question | Jiggyiroc | Normally Aspirated Powertrain | 2 | 10-02-2005 01:31 PM |
exhaust hangers question | kimwk | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-05-2005 07:51 PM |
Exhaust Hanger Question...(STi + NurSpec) | trey2s | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 04-18-2004 11:48 AM |
exhaust hanger question | dcgear | Normally Aspirated Powertrain | 1 | 01-09-2004 11:50 AM |
Stupid exhaust hanger question | SJwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 01-14-2003 05:59 PM |
