Welcome to the North American Subaru Impreza Owners Club Saturday February 17, 2018
Old 10-21-2003, 01:25 AM   #1
trymyrex21
Member#: 45638
WRX 12.9 1/4
now a [email protected] AUTO
Default Automatic trans torque converter
I just had a pro torque torque converter installed in my car after about 50 miles of driving it my check engine light came on and my At Oil Temp light came on? What could this possibly be? everything was installed properly i have a trannycooler, the only thing i can thing of is a bad sensor or my chip, i have the old turbo xs chip for automatic not the utec , that might be throwing it off. My oil heat is not rising, i have plenty of oil in my engine and in my transmission. As soon as i turn the car on even after a whole day of sitting the lights still go on. If ne body can help me i would appreciate it so much THANK YOU
trymyrex21 is offline   Reply With Quote
Old 10-21-2003, 09:51 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
go have your tranny codes pulled, as well as ECM codes. No sense in us guessing what the problem is when your computer knows the problem.
Legacy777 is offline   Reply With Quote
Old 10-21-2003, 12:23 PM   #3
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Are you sure the tranny cooler is hooked up properly? If that thing has the hoses backwards it wont cool it at all and the trans fluid will get hotter and hotter because instead of sending cooler fluid back to the tranny its still hot.
WRX_02_227 is offline   Reply With Quote
Old 10-21-2003, 07:08 PM   #4
trymyrex21
Member#: 45638
WRX 12.9 1/4
Im pretty sure the tranny cooler is working, because my oil is not getting hot in my trans if the car sits for a whole day then turn the car on the light automatically comes on. i unplugged my chip to see if thats the problem and the light hasnt come on yet, i do not have the utec chip i have the piggyback chip could this be the problem or would it be something bigger thank you very much!
Old 10-26-2003, 06:26 PM   #5
WOTEVA
Member#: 45356
2002 WRX WAGON
BLACK MIDNIGHT
Try disabling the unichip to see if the same problem occurs.
If that solves the problem you know it is the unichip.
I tried installing a unichip i bought off ebay for a stick, Then engine ran, but i remember that the tranny light was on.
Next, check out www.projectwrx.com to see if the tranny cooler is connected the right way round. The guy...Jorge..claims to have the fastest auto wrx.. Good Luck
WOTEVA is offline   Reply With Quote
Old 10-26-2003, 11:41 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
trymyrex-is the light just flashing or is it solid? i had one installed in mine also and when i accelerate my AT oil temp will flash, it will continue to flash until i turn off the car and turn it on again, i had codes pulled and nothing involving the tranny came up. so i think its fine, but thats my car, yours could be diff.
Ben
PHATsuby is offline   Reply With Quote
Full Drag Automatic Trans Parts.. Valve Body, Converter, Switch Box, Console...... STEALTH-WRX Drivetrain 12 01-21-2008 12:32 PM
Trans Swap or Torque Converter? RedlineRacer Transmission (AT/MT) & Driveline 5 01-17-2005 05:29 PM
Automatic Stall Torque Converters subaru18 Transmission (AT/MT) & Driveline 3 08-27-2004 10:42 PM
How much Auto Trans Fluid does the Torque converter hold? bdoss123 Legacy Forum 5 10-07-2003 08:00 AM
wanted: automatic trans torque converter zuparoo Private 'Wanted' Classifieds 0 08-06-2003 02:16 PM
