Welcome to the North American Subaru Impreza Owners Club Wednesday August 21, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 08-16-2019, 05:37 AM   #1
rst.ack
Member#: 500326
2015 WRX Premium 6MT
Default Exhaust burbles/pops when rev-match downshifting but not when double-clutching
Bit of an odd question - I have a 2015 WRX that is stock powertrain-wise other than a Nameless catback.
Before installing the exhaust I could hear some subtle burbles when rev-match downshifting. After installing the exhaust the burbles became much more prominent (as expected) and came with some bonus pops every now and again if I downshift just right.
The weird thing I've noticed is that there is no noise if I double-clutch downshift.
Any ideas why this is the case?
rst.ack is offline   Reply With Quote
Old 08-16-2019, 06:48 AM   #2
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
AFR, I believe. Different when repetitive throttle input and release.
oichan is offline   Reply With Quote
Old 08-16-2019, 08:52 AM   #3
DarkGreyMetallic
Member#: 487896
2018 WRX
Dark Grey Metallic 6MT
I've found that revving in neutral on the crackle tune I made doesn't give any pops, but revving in first while stationary does. Crackle tune was made by setting both idle ignition timing tables to negative.
This makes me think there's a different table for idle ignition timing when you're in neutral, so the pops will be different. There's a neutral safety switch so the car knows if you're in neutral or not.
I think stock behaved the same way. I haven't found the 'neutral' table in ATR
DarkGreyMetallic is offline   Reply With Quote
Old 08-16-2019, 10:17 AM   #4
Schoat333
Member#: 452248
2017 Base WRX
The tables adjust based on calculated load.
Schoat333 is offline   Reply With Quote
Old 08-16-2019, 10:49 AM   #5
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
The ECU will allow extra fuel in certain conditions.
I notice if you floor the engine in 1st gear to about 5000 rpm and clutch in quick and rev, you will get pops. But if you just randomly rev in neutral, it will not.
jasonwrx86 is offline   Reply With Quote
Old 08-16-2019, 01:19 PM   #6
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
The sound only gets better when you add a downpipe and get loud pops when shifting from the fuel overrun in your tune.
That might just be me though.
gn4rwhals is offline   Reply With Quote
