Welcome to the North American Subaru Impreza Owners Club Wednesday August 21, 2019
Old 08-15-2019, 02:39 PM   #1
Phillyg9600
Member#: 500445
Default Am I in over my head ? 04 Wrx main seal
Okay well I brought a really really cheap running and driving 04 wrx wagon cause well it was a good deal haha also I love these little wagons well come to find out it has a very very bad oil leak from what seems to be rear main . I had plans on doing the work my self but want to make sure I'm not over my head. I need to fix this and get it on the road asap or sell and get into something else since this is going to be my DD for the time being . It's at 103 grand so I know that the timing belt and water pump should be done also and it seems to have a small amount of oil coming from value covers also thanks in advance hopefully this is something that I would be able to do solo !!
Phillyg9600 is offline   Reply With Quote
Old 08-15-2019, 03:26 PM   #2
Waddlz
Member#: 395275
2012 STi
I bet money its on the rear oil sep plate leaking, and not the rear main.
but it depends on your level of mechanical skill. being that is a WRX, its easy to pull the trans and swap the seal if its leaking. or you can pull the engine and do everything at once like:
clutch
RMS
Valve covers
Timing belt/WP/etc
Pulling the engine is easy, and I prefer it to pulling the trans UNLESS i have a lift.
Waddlz is offline   Reply With Quote
Old 08-15-2019, 04:07 PM   #3
Phillyg9600
Member#: 500445
clutch
RMS
Valve covers
Timing belt/WP/etc
To be honest with you I didn't even look into that till you brought it up just now haha thanks . Yeah no lift here I have a feeling I'll just wing it and try it I just want to make sure I'm not in over my head done my fair share of work but never pulled a motor/trans. Also for the money I'm into it I guess doing all that work wouldn't be to bad
Old 08-15-2019, 04:11 PM   #4
Waddlz
Member#: 395275
2012 STi
its really not that bad.
You can watch tons of youtube videos on taking out the engine, and there are numerous how-tos
I can have an engine out in about 3 hours by myself. and I like to take the intake manifold off.
Old 08-15-2019, 04:48 PM   #5
Phillyg9600
Member#: 500445
I did watch a few after I posted this just to see one guy on YouTube was helpful but also said he took his out a few times already so I'm sure he had the whole process down by then . Sounds alot more hopeful then I had thought it would be and also seems like if I wanna take my sweet time with it a weekend would be more then enough. Thanks for the advice!
Old 08-15-2019, 04:53 PM   #6
Waddlz
Member#: 395275
2012 STi
no problem
I recommend getting some sandwhich bags and a sharpie and label all the bolts you take off. will make it a ton easier to keep organized.
Old 08-18-2019, 08:12 AM   #7
Phillyg9600
Member#: 500445
no problem
yeah agree that is one trick I do know from working on dirt bikes and cars before deff helps alot with process. Looks like it will be coming out next weekend hopefully it goes smooth
Old Yesterday, 03:24 PM   #8
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
If the rear main seal ISN'T leaking, don't mess with it. They can be a real pain to install properly.
car_freak85 is offline   Reply With Quote
Old Yesterday, 05:43 PM   #9
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
If you have never done it before, you may be over your head. It's a ton of work even for an experienced mechanic and DIY'er. Hence alot pf people screw up their cars instead of fixing it.
Fierysun is offline   Reply With Quote
