Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 06-04-2010, 09:07 AM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default OT Photographers - Indoor Pics : Moving Subject
I'm working with a nikon d5000 and I'm wondering if it's possible to take good pictures of a moving subject indoors without an upgraded flash.
I set my aperture to as big as possible
I set the exposure to the lowest possible that will get enough light for a clear picture.
Still objects come out great. Moving wife does not. Are there any tricks to getting a good pic of a moving subject indoors?
Bad Noodle is offline   Reply With Quote
Old 06-04-2010, 09:11 AM   #2
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
If you are trying to give the effect of motion, then panning with a slightly lower shutter speed might get it done. What lens are you using? Aperture?
Sounds like you need a flash. Only other option is to get a lens that opens up to 1.8, or 1.4 which will allow your shutter speed to be fast enough to freeze it.
What exactly are you trying to take pictures of?
Neek is offline   Reply With Quote
Old 06-04-2010, 09:11 AM   #3
maxQ
Member#: 2446
'11 Alfa Cloverleaf
grise
Spend money.
maxQ is offline   Reply With Quote
Old 06-04-2010, 09:19 AM   #4
SCMedic
Member#: 148369
2011 STi Sedan
www.gregfmoore.com
Fast primes are great for this. Otherwise, get an external flash, and bounce it off stuff. Aim at at the ceiling, opposite walls, etc. Use a diffuser as well to keep the light natural and not harsh.
SCMedic is offline   Reply With Quote
Old 06-04-2010, 09:20 AM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
More details on the setup:
Nikon d5000 with 18mm-55mm lens and all compensations/corrections turned off. i have it zoomed out so 18mm focal length for now.
For this image, I have the camera set at f5.6 and 1/2 exposure
At these settings, the background comes out clear and bright, but obviously anything moving comes out blurred.
I'm trying to get the same thing but with a much shorter exposure so I can shoot moving subjects.
Old 06-04-2010, 09:22 AM   #6
SCMedic
Member#: 148369
2011 STi Sedan
www.gregfmoore.com
You'll have close to NO luck shooting a moving subject indoors at 5.6 without a flash.
I can shoot kids inside, during the day, at F2.8 with my 5DII, but 5.6 would be a stretch even at higher ISO's to compensate for the faster shutter speeds.
Old 06-04-2010, 09:22 AM   #7
maxQ
Member#: 2446
'11 Alfa Cloverleaf
grise
what do you mean by 1/2 exposure? 1/2 second shutter? 'cause that's incredibly slow.
Old 06-04-2010, 09:25 AM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
yup 1/2 sec exposure. Iso is set at 200 but can be adjusted to 3200. But I don't want to introduce too much noise into the picture.
What's a good iso setting to try?
Old 06-04-2010, 09:32 AM   #9
maxQ
Member#: 2446
'11 Alfa Cloverleaf
grise
at f5.6, 1600 is probably still optimistic.
Do you want some noise or a blurry wife?
Ultimately, your choice is a flash or faster, $$ lens.
Old 06-04-2010, 09:38 AM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
with a iso of 3200 I still need 1/30s exposure
looks like it's a flash or nothing
Old 06-04-2010, 09:48 AM   #11
maxQ
Member#: 2446
'11 Alfa Cloverleaf
grise
If you have an external flash and are inside, point the flash at the ceiling. The light will be more flattering than pointed right at the subject.
Old 06-04-2010, 09:57 AM   #12
SimonJ
Member#: 135309
With that lens, you will need a flash - full stop.
If you don't want to use a flash, then you need a faster lens, such as a 50mm f1.4 - and then crank up the ISO. Noise is just a fact of life for low light shooting.
Unfortunately, your choices are limited because you have a d5000. Only one of the Nikon 50mm will autofocus on your camera, the AF-S version, which is quite expensive ($5-600).
SimonJ is offline   Reply With Quote
Old 06-04-2010, 10:12 AM   #13
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ good advice, thanks
Old 06-04-2010, 10:24 AM   #14
LokiV7
Member#: 30636
2006 Legacy GT Ltd
Obs Black Pearl
Yeah, I laughed when I saw the 1/2 second exposure at 200iso. For indoor stuff, there's just no way -- I'm actually a little surprised you even managed to get still shots to come out without looking blurry if it's handheld. Far higher iso, and a wider aperture will both help get faster shutter speeds, but obviously you're limited by what the lens lets you do. Flash, as others've said is ultimately a solution too, but I personally never like the way that looks -- often times what I see with the existing light is what I wanted a picture of - flash usually changes the scene completely.
I have Canon's 50mm 1.8 prime, and it absolutely helps with this sort of thing, but it's still not a miracle of science. At the end of the day, you're still indoors without enough light to truly capture something fast.
For others with prime lenses -- is there one you use for indoors that's more of a wideangle than the 50? I struggle a lot with always feeling like I'm too zoomed in for indoor situations if I want something other than an in-your-face portrait all the time
LokiV7 is offline   Reply With Quote
Old 06-04-2010, 10:34 AM   #15
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
f5.6? No way you'll be able to shoot moving subjects indoors without a flash. Period.
Faster glass. My fastest lens is a 50mm/1.4 and I adore it for indoors use.
I totally disagree with LokiV7 about flash. While I try to avoid it whenever possible, there are ways to use a flash in ways that appear more natural. With the fixed forward onboard or popup flashes there is nothing you can do. But a separate flash with a movable head that allows you to reflect the light off the ceiling or wall makes a huge difference. Even better, get the flash off the camera. There is a reason why pro wedding photographers use that big bracket that gets the flash way off the camera. The worst kind of light is flash directed straight at your subjects and in line with the lens axis of the camera.
Old 06-04-2010, 10:37 AM   #16
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
1/2 second exposure...think about that for a second. Read this sentence in a basic normal speed:
I suck.
That took you a half a second to say. Think about all the moving that goes on in that time. It's an absolutely gigantically huge amount of time to have the shutter open and expect to freeze any motion.
Old 06-04-2010, 10:43 AM   #17
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ yeah I get that
I was wondering if these cameras have some kind of magic photoshop/picasa way of iauto adjusting exposure brightness.
Like if the image doesn't have enough variance or most of the pixels are below a theshold, the whole image gets brightened.
The camera has a ton stuff like flash compensation/exposure compensations/ other magic stuff. Kinda wondering if any of it is known to be useful
Old 06-04-2010, 10:44 AM   #18
iguanamafia
Member#: 23426
2010 Forester
Streetfighter
I'm no photographer, but wouldn't increasing the ambient light help in this situation?
iguanamafia is offline   Reply With Quote
Old 06-04-2010, 10:57 AM   #19
hatchd
Member#: 201307
2002 wrx
wrb
It would, but even at that with a ****ty lens (he said 18-55, I'm assuming it was the kit lens that came with it) it's still damn near impossible to get enough light indoors to shoot something like this.
OP - like everyone else has said, get something that stops down to about 1.8 and bump the iso up. That's your only chance without a flash. I have the 50mm 1.8 for my Canon and I've shot decent action shots of my ex's dog indoors, but there was a lot of noise in the background. You can PS away noise somewhat, you can't PS away blurry subjects.
hatchd is offline   Reply With Quote
Old 06-04-2010, 11:00 AM   #20
ForceFed4
Member#: 7370
SGM
Agreed. With the kit lens, you have no other option, really.
If you want a flash that isn't so obvious, the cheapest hotshoe flash you can bounce would be the Nikon SB400, at a little over $120. Cheaper than any lens upgrade.
If you don't want to use a flash, then you need a faster lens...Unfortunately, your choices are limited because you have a d5000. Only one of the Nikon 50mm will autofocus on your camera, the AF-S version, which is quite expensive ($5-600).
Or he can buy the Nikkor 35mm f1.8G AF-S DX for under $200, basically tailor-made for what he wants to do.
Uh sure; may I ask why you (seem to be) using fully manual mode? Try Aperature/shutter priority, or even program mode, with auto ISO "On" and VR set to "On" as well. You'll almost certainly get better pictures, unless you really know what you're doing in "M".
ForceFed4 is offline   Reply With Quote
Old 06-04-2010, 11:01 AM   #21
jacobsen1
Member#: 16711
2011 forester
2015 legacy
you need more light. options:
  • flash (expensive and annoying to your subjects)
  • fast glass (f/1.4~1.8), expensive, but less annoying
  • more ISO (fugly, get some noise reduction software to go with it)
  • RAWs (yes, I said it, much easier to clean up the noise in post with a RAW, plus WB issues are common in low light inside)
I've been shooting inside for ~2.5 years now (since I started my PAD in 2008). I HATE flash, and so does my kid. So I've gone the fast primes route with a 50mm 1.4 and 24mm 1.4. I also use a FF sensor camera because they're at least a stop better with noise. I then run all my shots through NN in post to help.
If you're using a DX sensor (you are) get a fast lens pronto. The siggy 30mm or nikon 35 would be my top 2 suggestions, but sigma's 20 and 24mm 1.8s are also not bad. Expect to spend ~$500. Then crank your ISO up to 1600, or maybe even 3200. Put your camera in Av, set it to 1.8 or 1.4 (the smallest number the lens has) and set auto ISO up with a 3200 ceiling and a minimum shutter speed of 1/125th. THIS IS HOW I'VE SHOT YEARS OF INDOORS PICTURES! Then when you process the pics, run them through NN and you're set.
With my D700, I can get to 6400, 9000 and even 12800 and get shots when needed. Yes you can use 2.8 zooms if you want, but even after going from a 5D to a 5Dii to a D700, I've NEVER stopped using my fast primes because I'm always at the lowest possible ISO I can get to.
And if you miss on your exposures, miss with it OVER exposed unless it means super low shutters, bringing shots down in post lessens the noise.
12800, 1/8th, f/2.8
that's with my 28-75mm 2.8 which I HATE using inside, but it makes testing high ISOs a bit easier.
jacobsen1 is offline   Reply With Quote
Old 06-04-2010, 11:08 AM   #22
jacobsen1
Member#: 16711
2011 forester
2015 legacy
here's why I don't like flash, especially with kids BTW:
http://newschoolofphotography.com/li...ing-flash.html
they hate it and it draws attention (so you get less candid shots).
the SB-24 can be had for ~$50 and will work with some automation in the hotshoe or with a nikon cord. Yes it's almost a manual flash (why I have and love mine) but on a budget it works pretty damn well. But for the OP, if you're going to go down this road, AT LEAST BOUNCE IT, but I'd highly suggest an off camera cord as it makes it much easier to not blind people.
Elias is a year older now and likes playing with my softboxes a bit more:
but they're... ummmm, what's the word I'm looking for here...... Oh yeah, SOFTER!
I'll take dealing with noise anyday over flashes for casual around the house shooting. Flashes have their place, sure, but they're just such a PITA to deal with.
Old 06-04-2010, 11:44 AM   #23
aubsxc
Member#: 91476
2005 9-2x Aero
You need to buy a flash unit. Period. You can make very natural looking images with flash lighting if you know what you are doing.
Or you need to invest in very big glass (large aperture equals more light reaching the sensor, also equals more dollars) and shoot at very high ISO's.
In short, you have to either add light to the scene, or increase the light gathering ability of your equipment. Step 1 is less expensive and will get you "better" results in most cases.
aubsxc is offline   Reply With Quote
Old 06-04-2010, 11:48 AM   #24
shikataganai
Member#: 92634
'19 Volvo XC40
'18 Pacifica PHEV
This. Teh OP is doing it all wrong at ISO 200, 1/2 sec, f/5.6.
shikataganai is online now   Reply With Quote
Old 06-04-2010, 11:53 AM   #25
edkwon
Member#: 453
2017 Kia Niro
2016 Porsche Cayman GTS
1. the kit lens is crap and i'll suited to shoot moving subjects indoors without motion blur and without the benefit of an external flash
2. f5.6 is WAY TOO NARROW at apeture, you need to open it up all the way and even the kit lens sucks as its max apeture is only 3.5 i believe, you need to buy a fast prime lens as suggested before with an apeture closer to 1.7-2.0
3. a 1/2 sec exposure is an eternity in photography terms, you want the avoid motion blur? exposure has to be at LEAST 1/100 sec but ideally much more
4. increase your ISO to at least 800, i'm assuming the D5000 has the same sensitivity range as the D90 which I own which can comfortably take decent high ISO shots up to 1600, you didn't mention what your ISO settings were
5. increase EV compensation up 1/3 - 1.0 stops of light to brighten the shot
and OP, read some basic books/magazines on basic photography, you clearly need to be versed in some of the fundamentals.
edkwon is offline   Reply With Quote
OT photographers. How do I take a pic that looks like this (pic) plunk10 Off-Topic 6 03-17-2006 03:16 PM
OT photographers, choose which pics I add to my portfolio book. Protege Menace Off-Topic 31 01-17-2006 02:03 AM
Attn: OT Photographers...wth do I do with this? DrDRum Off-Topic 30 12-14-2005 10:59 PM
OT photographers, need some advice (making a portfolio to floss) Protege Menace Off-Topic 6 06-14-2005 10:43 AM
OT photographers. Who here's been paid for it? chyisan Off-Topic 5 12-21-2003 02:55 PM
