10-12-2011, 02:16 AM | #76 |
Member#: 131976
SCIC
Vehicle:2006 18g'd WRX CGM on Black |
OKAY...so it turns out that I was leaking around the BPV. My silly self forgot to tighten down the bolts to the bpv, and while driving around, I lost a bolt which opened up the area even more. Everything is dialed in quite nicely now.
Current Settings: Scalar = 950 Code:
6.50 9 11.5 14 16.5 3.64 2.07 1.36 0.95 0.79
10-13-2011, 05:59 PM | #77 |
Member#: 185126
TXIC
Vehicle:2005 STI AWDtuning feels like sex! |
I noticed most of you guys are trying to tune with 1200+ cc injectors, but has anyone had any experience or issues with the 850cc side feed injectors from Five-O? I'm planning on picking up a set, but after reading around it seems like there's a lot of folks having problems with the injectors coming from them =/
11-23-2011, 02:49 PM | #78 |
Member#: 202804
Vehicle:2002 PSM Sedan The 2.0L that could |
Bumping this thread one time. I plan on picking up a set of the 850cc top feed injectors, from the factory they recommend a latency of .75ms @ 14v. Does this seem a bit low? Anyone have a base table they could send my way?
12-18-2011, 04:13 PM | #79 |
Member#: 193014
Vehicle:02 WRX WRB, 05 STI FPGreen E85 400+whp |
I have there 1600s running on stock ecu both on pump and E 85 with success
12-22-2011, 04:50 PM | #80 | |
Member#: 205568
Vehicle:2017 WRX STi WRB |
12-22-2011, 05:19 PM | #81 | |
Member#: 239659
SCIC
Vehicle:STI Mikey & Phatron Tuning Da Subies |
I havent tuned any of them yet. What scalar and latency did you end up with? - ron |
12-22-2011, 07:00 PM | #82 | |
Member#: 193014
stock ecu doesn't like them too much misses at idle on pump allot and few here n there on E. I'm getting ready to move next week so I really don't have time to do another maf plot |
01-14-2012, 04:30 PM | #83 | |
Member#: 123574
Vehicle:2005 STi CGM |
Anybody want a set of 1200cc sidefeeds for cheap? |
01-14-2012, 11:58 PM | #84 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
Sounds like their sidefeeds are not that great, how about their topfeeds?
I was going to order a set of their 1400s, I will post some logs when I get them running.. |
01-15-2012, 12:58 AM | #85 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
It's really not their sidefeeds.....it's pretty much all sidefeeds over 1000cc. They all run like crap on pump gas.
The best solution is to do a tf conversion. |
01-15-2012, 10:26 AM | #86 | |
Member#: 193014
01-18-2012, 03:51 AM | #87 | |
Member#: 59837
SWIC
02-07-2012, 09:45 PM | #88 |
Member#: 180924
Vehicle:2017 Forester |
I have a set of 1000cc injectors on my STi. It was tuned by Mikey from Phatbotti Tuning. I haven't had any issues other than e85 being a bitch to start when it's cold out. And the car eating gas, but that's because its hard to stay out of boost.
For the price and lack of experience with other injectors, I'd buy them again. |
02-07-2012, 10:03 PM | #89 |
Member#: 36033
SCIC
^^. Did u tell mike about the cold starting issues? That can be tuned out. That's not something that's specific to five-0 injectors....that's specific to e85
03-27-2012, 06:20 AM | #90 |
Member#: 137499
Vehicle:2002 STi Wagon 60-1 Black |
Is anyone using these injectors on E85? What latency and flow scaling values are you using? I am having a problem with these injectors at certain throttle position AFR starts to swing from lean to rich and the car is studdering a little.
http://www.fiveomotorsport.com/denso...-fuel-injector |
04-06-2012, 07:57 PM | #91 |
Member#: 179014
Vehicle:'06 WRX/STi Built Motor/6766/E85 |
Anybody have any Latency setting for the Denso 1400cc injectors?
My car is missing at idle pretty bad but at crusing speeds and reving up, it doesnt miss. |
04-07-2012, 05:05 PM | #92 |
Member#: 193014
I've ben having the same problem with my 1600s from them. Its been on going for a while there hard to dial in.
04-07-2012, 07:32 PM | #93 |
Member#: 179014
Guess Ill just switch to E next week. Seems these injectors start acting right then.
04-10-2012, 06:58 AM | #94 |
Member#: 212154
South East
Vehicle:02 billet crank pauter rods, pt5857, E85 |
I want to bump this thread. I have been tuning a car with side feed 1200cc for the past few days. I just want to say that these injectors SUCK!. And that is putting it lightly. The fueling is all over the place at idle. The fuel corrections will be flat one minute then out of nowhere the afr will shoot rich and corrections swing wide. That may last a few seconds then back to normal for a while. But corrections still arnt what I would call acceptable.
As for idle control. SUCK! You can stop at a light and idle corrections are ok, stop at the next light and corrections will be -25. Next light they may be ok again. System voltage is stable, maf voltage is stable, map, all the data is correct and nothing to cause this behavior. I would not recommend these injectors to any customer or client to install on there car. |
04-10-2012, 08:15 AM | #95 | |
Member#: 193014
04-17-2012, 01:30 PM | #96 |
Member#: 167827
Vehicle:2004 STi WRB |
I have the 1600's and was having trouble with the afrs swinging from stoich to ~19 at idle and light, light throttle. Turned out I had a bad injector that was misfiring like crazy (logged roughness and it was reaching 100 at idle). Log your roughness on all 4 cylinders and if you don't see anything out of whack raise your idle and play with your tip in and you can correct the stalling issue.
04-17-2012, 04:57 PM | #97 | |
Member#: 212154
South East
04-17-2012, 05:57 PM | #98 |
Member#: 193014
Yep time to ditch these cheap magnets
04-17-2012, 06:18 PM | #99 | |
Member#: 152576
SWIC
Vehicle:2009 GTR 10.7@ 133 Mayhem Tuning!!!!! |
04-17-2012, 06:20 PM | #100 | |
Member#: 170439
Vehicle:I <3 Lamp |
Five O Motorsports Injectors | apsdsmracer | Car Part Reviews | 185 | 02-26-2016 12:48 AM |
The 2.0 vf34 that did, now a built 2.0/2.5? hta green on e85 | karlknaupp | Proven Power Bragging | 684 | 06-30-2015 08:20 AM |
555 Motorsports June Tuning Trip (June 19-22) | Benchmark Tuning | MWSOC Vendor Classifieds | 35 | 07-14-2008 10:21 PM |
555 Motorsports Chicago Tuning Trip & Dyno Day #'s | Benchmark Tuning | Proven Power Bragging | 11 | 07-13-2008 01:48 PM |
Primitive Motorsports/Cobb Tuning/JC Sports??? | Kevin Thomas | General Forum Archive | 24 | 10-01-2000 06:54 PM |
