Brakes & Suspension Forum sponsored by The Tire Rack |
07-11-2011, 10:50 PM | #1 |
Member#: 179439
Vehicle:2004 STI JBP |
STI pulls right after new alignment
I have an 04 sti that has been in a minor accident by the previous owner. I never noticed a pull on the old tires but after getting coilovers installed and new tires(pirelli pzero nero) stock size the car pulls to the right more so then it would with just a crowning of the road. The shop I got it done at is very reputable for performance alignments. My question is will a four wheel alignment always detect frame damage what would cause the pull? Feels like it pulls harder right during acceleration.
I have had 3 previous alignments on four wheel racks and they never told me the car had any damage. Any input appreciated
07-11-2011, 11:24 PM | #2 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
A shop worth its salt should be able to tell you if there's any frame deflection.
07-12-2011, 08:43 PM | #3 |
Vehicle:OK buy Nates beans westcoastroasting.com |
post up the alignment numbers
07-12-2011, 09:11 PM | #4 |
Member#: 246895
Vehicle:05 WRX WRB |
agree with scotty post alignment numbers. It could be a number of things, steering wheel not centered, tire pull, previous accident damage. Toe, camber, or caster could be in spec but could still cause a pull if not almost perfect.
07-13-2011, 05:59 PM | #5 |
Member#: 179439
Camber:-1.6,-1.7
caster: 4.8, 4.6 toe:.03, -.02 SAI 16.6, 16.3 included angle turning angle diff 14.9,14.6 rear Camber -1.6, -1.8 toe .02,.03 rear cross camber .2 total toe .04 thrust angle -.01 |
07-13-2011, 06:02 PM | #6 |
the toe in the front is likely making it sensitive
that and the pirelli tires |
07-13-2011, 06:03 PM | #7 |
Member#: 114481
Vehicle:2006 Sti WRB |
Check your tire pressure.
07-13-2011, 06:10 PM | #8 |
07-13-2011, 06:16 PM | #9 |
Member#: 179439
I hear that the pirellis are very sensitive to the roads. Might try switching them around and seeing what happens
07-13-2011, 11:01 PM | #10 |
Member#: 277507
TXIC
Vehicle:2002 WRX Silver |
Swap the two front tires from side to side, most likely a radial pull.. see it at my shop all the time. That toe will not make a noticeable pull, it may just have your steering wheel crooked ever so slightly.
07-21-2011, 10:01 PM | #11 | |
Member#: 252981
TXIC
Vehicle:2007 wrx wrb |
Similar Threads | ||||
new alignment pulling to the right?? | captballa | Brakes, Steering & Suspension | 4 | 01-19-2009 12:41 AM |
Got a P0420 DTC code right after new Fuel Filter. | flamaest | Newbies & FAQs | 9 | 02-14-2008 05:01 PM |
2 months after alignment, car pulls right again!!! | Mikeye | Legacy Forum | 10 | 01-24-2008 10:26 AM |
Got an alignment, car still pulls right | LotusDriftx | Mid Atlantic Impreza Club -- MAIC | 28 | 02-01-2005 09:47 PM |
STi pulling left after alignment and track day | bcristea | Brakes, Steering & Suspension | 11 | 07-05-2004 11:27 PM |
