Welcome to the North American Subaru Impreza Owners Club Saturday February 24, 2018
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 08-03-2005, 04:34 PM   #1
brianecarlson
Member#: 90845
1999 Outback Limited
Winestone
Default Check Engine Light: CODE P0420
Does anyone know what this code means or what needs repaired:
PO420 Catalyst System Efficiency Below Threshold. Bank 1
Thanks!
Brian
brianecarlson is offline   Reply With Quote
Old 08-03-2005, 04:52 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
From what I've read its either an 02 sensor or your cat is bad...
fibuz
fibuz is offline   Reply With Quote
Old 08-03-2005, 05:19 PM   #3
brianecarlson
Member#: 90845
Winestone
What is the "CAT" or "Catalyst"?
Old 08-03-2005, 05:22 PM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
catalytic converter...part of the exhaust.
Old 08-03-2005, 08:11 PM   #5
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
That's you rear (second) O2 sensor saying the convertors are not doing their job. Have you done any exhaust mods? That is a frequent code for people that have aftermarket headers/exhaust parts. There is a couple ways to fix it if it is due to aftermarket stuff. Otherwise, depending on warranty, let the dealer help you. Brian
bheinz57 is offline   Reply With Quote
Old 08-03-2005, 09:09 PM   #6
brianecarlson
Member#: 90845
Winestone
I haven't done any mods at all. I"ll take it to my "Authorized Subaru Dealer" tomorrow. Thanks for the advice.
Old 08-05-2005, 08:20 PM   #7
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
I have the same problem... However i did put on GReddy Evo2, GT spec II headers w/ catless UP and Daddy's SCP high flow catted DP...
I bought an ODB2 scanner and got rid of it that way, but is there another way?
Thanks,
leon
leonbmx is offline   Reply With Quote
Old 08-16-2005, 01:55 AM   #8
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Peaty is offline   Reply With Quote
Old 08-29-2017, 09:35 PM   #9
WindyCityYinzer
Member#: 473674
2005 Outback
Default Resistor Fix
So pulled the P0420, tried the Resistor bypass, but now its pulling P0137 for low voltage. Anyone try this, and have a similar result?
2005 Outback 2.5i
WindyCityYinzer is offline   Reply With Quote
Old 10-04-2017, 02:21 PM   #10
amiexploited
Member#: 251061
2002 wrx sold
garage queen 2015 WRX
Dealing with this too, same 2005 Outback but the CA emission one (profile probably doesn't say it)
I'm the last one to post on the http://www.subaruoutback.org/forums/...nosis-126.html and haven't gotten any responses.
Starting around 2005 you can't use the spacer for the rear 02 sensor.
@brianecarlson
any luck at the dealer? I know they will just wire that the cats need to be replaced when the code pops up instead of solving why it popped up.
amiexploited is offline   Reply With Quote
Old 10-04-2017, 02:56 PM   #11
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
2005 Outback 2.5i
@brianecarlson
Sometimes you get that code with an exhaust leak near the rear O2 sensor, so check for leaks first.
If you have a scanner that does realtime data, check activity of the rear sensor, ideally they are at 0.5VDC, lower voltage is lean, higher voltage is rich.
Engine running, change RPM's by a lot, should see the voltage change.
If it's pegged at 0 or 1, likely a sensor issue. Exhaust leaks usually make the voltage go below 0.5VDC.
Old 10-04-2017, 10:05 PM   #12
amiexploited
Member#: 251061
2002 wrx sold
Thanks for the reply. I'll check for exhaust leaks this weekend.
My rear 02 averages at 0.6V during acceleration. The middle 2 are around 0.8V and 0.7V. At idle the rear is at 0V. Voltage changes with throttle. all drop when I let go of the throttle.
Do you have experience reading logs? I have 2 one at idle and one at steady 70mph.
Old 11-18-2017, 09:29 AM   #13
jagoulet
Member#: 471876
Default current thinking?
I own a 2009 Impreza with base, normally aspirated motor. Has 103K miles. No modifications, exhaust system and sensors original.
Car runs fine but PO420 has come on twice in recent months. Gas mileage might be down a tad, not sure (wife's car).
When you guys say you are "logging data" what are you using for a tool to do this?
What is the current thinking on this problem? For example, should I replace the rear O2 sensor as a starting point? I realize they age. Exhaust leaks? can't hurt to look.
Of course the inspection sticker is due to expire the end of this month . . .so motivation to get on with it.
Any thoughts appreciated!
John - MA
jagoulet is offline   Reply With Quote
Old 11-21-2017, 12:47 PM   #14
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
John - MA
Check for leaks first. Cheap test is get the front up, start engine, have someone use a rag or heavy gloves to block the exhaust tip/tips while you go under the car and listen/feel for leaks. Exhaust tip blocked off makes even small exhaust leaks stand out.
If that is OK, then do downstream O2. Based on age, it may just be tired.
Old 11-28-2017, 06:56 AM   #15
MyLongForeskin
Member#: 478383
Chapter/Region: PRSIC
Just ohm test the O2 snsr.
MyLongForeskin is offline   Reply With Quote
Old 12-11-2017, 05:08 PM   #16
shaunm1311
Member#: 419277
Default P0420 with hesitation at acceleration
Ive searched a lot for anyone who has had the P0420 code with actual performance symptoms as well. I own a 08 2.5i NA completely stock, got the P0420 code 2 months ago with no performance issue, as of the last few days I have a hesitation at take off and low rpms. Does the performance issue help narrow down whether or not its a sensor or cat? any help would be appreciated thanks.
shaunm1311 is offline   Reply With Quote
Old 12-19-2017, 01:18 PM   #17
amiexploited
Member#: 251061
2002 wrx sold
If you have a clogged cat you won't be able to rev high. Only way I've seen people diagnose the true problem is to log the car.
Old 12-26-2017, 04:19 PM   #18
nickyclix
Member#: 479685
My factory 07' impreza threw a P0420 a while back. I cleared the code by pulling both terminal connections off the battery. Sure enough, the code kicked back on another couple thousand miles later. I brought it in to a local subi shop who has done great work for me in the past. They installed a metal flange in the exhaust just upstream of the O2 sensor. Never had the problem again. Catalytic converters rarely go out on modern cars with less than 300K miles on them but a bunk O2 sensor can burn one out because its telling the car's computer to combust fuel in ways it shouldn't.
nickyclix is offline   Reply With Quote
Old 02-21-2018, 03:39 PM   #19
amiexploited
Member#: 251061
2002 wrx sold
Have any other issues arisen from the O2 spacer? I read that on 05+ that you'll get different issues since the rear O2 gives more data than just if cats are working or not.
Check engine light: P420 code pulled allsubaru83 Normally Aspirated Powertrain 19 05-02-2005 01:24 PM
Check engine light code 1443??? k2snow North West Impreza Club Forum -- NWIC 9 06-05-2003 07:51 PM
check engine error codes gpd323 Service & Maintenance 10 10-17-2001 10:56 AM
Check Engine Light Code 103 bmwk12rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-17-2001 01:10 AM
Pulling the check engine light codes Attn: ColinL and anyone else BoomerRS Technical Forum Archive 7 09-12-2000 12:45 PM
