Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Old 10-13-2010, 12:32 AM   #51
2wickedWRX
Member#: 151211
2007 RWD STI
WR blue
^^^^^ i would also like to know. Are the 07 wrx sedan sways the same as the 06 sedan?
2wickedWRX is offline   Reply With Quote
Old 10-13-2010, 05:58 AM   #52
vicious_fishes
Member#: 158864
2003 SOHC destroker
yes. 5 characters
Old 02-21-2011, 11:19 PM   #53
pocketdrummer
Member#: 197301
2005 WRX STI
W R Blue (02C)
Does anyone know why they went with a 17" rear sway bar on the wagons? Is there some kind of benefit in the 20/17 combo for wagons or would a 20/20 be better in this setup?
I'm kind of new to these things. Still trying to work everything out before buying
pocketdrummer is offline   Reply With Quote
Old 02-21-2011, 11:24 PM   #54
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
"it depends"
read the swaybar FAQ
Butt Dyno is offline   Reply With Quote
Old 02-22-2011, 01:21 AM   #55
pocketdrummer
Member#: 197301
2005 WRX STI
W R Blue (02C)
Originally Posted by ButtDyno View Post
"it depends"
I did, but I'm not sure exactly how much under steer there is compared to what a 20mm would have. It seems odd to have the sedan with one setup and change it for the wagon. Was the choice due to the thinner wheels or additional weight at the rear?
I know a larger sway bar in the rear will make it step out more, but to my understanding, the extra weight in the rear will probably exacerbate this effect. So, my theory (from a complete noob's point of view) would be that the smaller bar was in the original design for some reason or another, specifically.
I guess I need to understand the logic that went into the original design before I can really figure out how I'd like to alter it.
Old 02-22-2011, 06:29 AM   #56
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Perhaps you should look at it from a different angle. What is the car doing now that you don't like and how do you fix it. If you find you understeer too much for your liking then a small increase in rear bar diameter might help you find the place you're looking for.
Old 02-23-2011, 07:00 AM   #57
Arnie
Member#: 1725
2002 Subaru Forester
SG silver
The sedan is seen as the Performance Car of the brand, not the wagon. So the wagon is set up with a milder suspension tuning, i.e. smaller rear swaybar(02/3) and narrower track than the sedan. The bug-eyes were the first iteration of the new-age Impreza and Subaru wanted to maintain the handling prowess that made the GC so popular. The Sedan was seen as their performance model so it was given the wider track and larger rear swaybar compared to the family truckster wagon. So the wagon got more sedate handling characteristics out of the box. As far as the wider track, there have been rumors over the years about it being due to tax reasons in japan, as the wider track cars are taxed higher. I've seen this in print (Subaru Impreza, Brian Long, 2003) but I'm not too sure as to its truth. There are normal sedan Impreza models in Japan that did not have the wider track of the WRX. After 03 Subaru went with a smaller rear swaybar on the sedan, most likely because people were wrapping the cars around poles due to lift throttle oversteer issues.
Arnie is offline   Reply With Quote
Old 02-23-2011, 11:14 AM   #58
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
please, this thread is for facts about swaybars. Discussion of subaru's design strategy or how to apply it to your car should be taken to another thread.
Frank A is offline   Reply With Quote
Old 02-23-2011, 04:42 PM   #59
pocketdrummer
Member#: 197301
2005 WRX STI
W R Blue (02C)
I personally disagree. This is perfectly relevant to sway bars. If there is a logical reason behind Subaru favoring a larger sway bar in the front, I'd like to know why. Perhaps many people (who don't have a research facility of their own) may have overlooked something. It's either for performance, safety, or cost... knowing which category it falls into will help us understand the logic behind it and therefore influence more informed purchases.
Old 02-23-2011, 10:47 PM   #60
Butt Dyno
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
It is emphatically NOT relevant to compiling a list of swaybar sizes.
Old 07-03-2011, 03:24 PM   #61
turboaddiction
Member#: 257266
I measured my jdm 97 sti fsb so you can add it to the list it measured 20mm
turboaddiction is offline   Reply With Quote
Old 07-03-2011, 10:24 PM   #62
FromEvoToRS37
Member#: 91396
anybody know the 2011 WRX front and rear sizes?
FromEvoToRS37 is offline   Reply With Quote
Old 07-04-2011, 04:41 PM   #63
rolling_death
Member#: 235872
05 WRX
21mm front, 16mm rear
rolling_death is offline   Reply With Quote
Old 07-04-2011, 10:42 PM   #64
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
nevermind - we all have hatches so I assume we are talking about the hatch...
Old 07-07-2011, 03:04 AM   #65
gregroot198521
Member#: 280844
2006 STi
This for the 2011 sedan or hatch?
gregroot198521 is offline   Reply With Quote
Old 10-13-2012, 02:56 PM   #66
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
looking for mild upgrade to FRONT of 06 WRX wagon that will work without 'drama' with kartboy drop links.
any suggestions?
thanx
1 Lucky Texan is offline   Reply With Quote
Old 11-26-2012, 04:50 PM   #67
Dragon_Ski
Member#: 178153
1996 555 Sti
blue
How about 2010 wrx I just bought one and understand the 2011 suspension was a big improvement so want to update the suspension right away and need to know what is different . Not interested in going to after market .
Dragon_Ski is offline   Reply With Quote
Old 11-26-2012, 11:00 PM   #68
paulpat
Member#: 237145
02 WRX
12 FXT
paulpat is offline   Reply With Quote
Old 09-09-2014, 01:58 PM   #69
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Does the wide body 2011-2014 WRX use the same length sway bar as the 09-10?
(I know they use the same thickness 21mm front)
chimchimm5 is offline   Reply With Quote
Old 08-19-2016, 07:41 PM   #70
mikeblo
Member#: 268311
i want to know if i can install an aftermarket whiteline sway bar from a wrx to an 04 sti with the oem link kit?
mikeblo is offline   Reply With Quote
Old 08-20-2016, 06:29 PM   #71
Web Foot STi
Member#: 39086
2004 STi
'04 WRX?
Front: Yes. The rear is more difficult as the bars are different widths.
Edit: Just saw your other post: '02-'07 is the same for USDM cars.
Web Foot STi is offline   Reply With Quote
Old 12-17-2016, 08:43 PM   #72
NubImpreza
Member#: 413825
2015 base Impreza
Jasmine Green Metallic
Anyone here have the info on the stock FSB and RSB sizes for a 2017 WRX base? Been searching but the car is too new for regular sources. My '15 green Impreza was totaled by an idiot on the opposing traffic who made a left in front of me. I upgraded to a Rally blue WRX base 6 speed.
NubImpreza is offline   Reply With Quote
Old 10-24-2018, 09:08 PM   #73
S2000_Europe
Member#: 297373
2017 and 2018 STi has 24mm front and 20mm rear
2018 Type RA has 24 mm front and 19mm rear (same part #20451FG020
same as 2011 STI rear bar)
S2000_Europe is offline   Reply With Quote
Old 08-01-2020, 07:03 PM   #74
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Bumping this up, would be a very helpful thread if the OP hadn't stopped posting eleven years ago.
Can a moderator update the first post whenever someone shares new specs? The first post stops at 06 and is missing a lot of model and trim specific information.
FS: 07 STI STOCK struts/springs/tophats/FSB/RSB/front endlinks Fei Jai SCIC Private Classifieds 50 11-12-2009 02:51 AM
fs: Whiteline FSB RSB endlinks 04 WRX FSB xilles 1993 - 2001 Impreza Specific Parts 1 09-30-2007 10:20 PM
FS(MI+IL) Strano FSB, Stock STI RSB sil0nt Suspension/Brakes/Handling 12 07-20-2007 03:43 PM
22mm RSB + stock FSB = scary ride javanaut Brakes, Steering & Suspension 36 05-14-2006 02:12 PM
FS/NJ: stock fsb,rsb, head lights, and hids jumpman86 Private 'For Sale' Classifieds 10 06-22-2005 08:09 PM
