Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Old 01-18-2007, 06:11 PM   #1
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Default Clicking sound when I turn right
Anyone know what is the potential problem with this? Whenever I turn a hard right with my car at any speed (not quite full lock starts at maybe even half) somewhere around the front passenger wheel side of the car it starts making a loud CLICK CLICK CLICK sound until I turn the wheels straight again. Same thing happens to a degree when I turn left as well but it's not nearly as loud or last as long.
TIA!
Uncle Ben is offline   Reply With Quote
Old 01-18-2007, 10:24 PM   #2
rallymarty
Member#: 17418
1968 Camaro SS/RS
c.v. joints going bad? might check your boots and see if they're torn. if so, dirt, germs, and nasties have gotten in there and are killing the joint.
rallymarty is offline   Reply With Quote
Old 01-18-2007, 10:48 PM   #3
SeanB23
Member#: 87309
2002 wrx
I have the exact same thing except it is my driver side rear... no idea what it is. just got coilovers and gonna check it out when I install those...anyone else got ideas?
SeanB23 is offline   Reply With Quote
Old 01-18-2007, 10:52 PM   #4
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
CV Joint!! +1
dstan is offline   Reply With Quote
Old 01-19-2007, 12:36 AM   #5
Wannascooby
Member#: 112992
2006 WRX TR
Crystal Gray
probably the CV joint. Happened in my Integra... Check the CV boot to see if its cracked or worn.
Wannascooby is offline   Reply With Quote
Old 01-19-2007, 01:16 AM   #6
michaelrocks
Member#: 118642
04 sti
java blk
mine does that on the driver side...
its does it frequently... i took it to dealer and they said nothing was wrong...
dunno..
michaelrocks is offline   Reply With Quote
Old 01-19-2007, 03:08 AM   #7
smarteex1
Member#: 93142
2005 WRX
WR Blue
+1 for CV joint also. It happened in my Integra too.
smarteex1 is offline   Reply With Quote
Old 01-19-2007, 03:27 PM   #8
Uncle Ben
Member#: 28628
2003 WRX Sedan
What is involved in fixing the CV joint? Parts needed? More important how much am I looking at spending lol.
Bad if I don't repair it ASAP?
Old 01-19-2007, 08:41 PM   #9
triguy
Member#: 27109
2002 WRX Wagon
2.5L Crawford, 6 spd
Other possibilities could be your wheel bearings or your tire rubbing against your brake line (if you have aftermarket lines). Worn out wheel bearings can make rotational clicking sounding. How many miles do you have on your car? Ever take it to the track and get the brakes hot? Track sessions will speed up wear and tear on wheel bearings.
triguy is offline   Reply With Quote
Old 01-21-2007, 01:52 AM   #10
Uncle Ben
Member#: 28628
2003 WRX Sedan
I've only taken it to the track once. My car is coming on 4 years old with about 50,000 miles on it...
Is it common for wheel bearings to go on our cars? Never had problem with that on any of my previous vehicles.
Old 02-11-2007, 08:28 PM   #11
SeanB23
Member#: 87309
2002 wrx
I had the same problem, mine was my a spring, it was not seated right..just somethin to think about.
Old 02-22-2007, 11:58 PM   #12
BMW Man in 2.5RS
Member#: 4162
2001 Impreza 2.5RS
I have this same problem. Sounds like its coming from the drivers side front. I replaced the drivers side fron axel and it still is making the noise. Should i go ahead and try to change the passenger side? How do you test if a wheel bearing is bad?
BMW Man in 2.5RS is offline   Reply With Quote
Old 02-23-2007, 09:43 PM   #13
flybyesti
Member#: 140695
2007 STI
Satin White Pearl
Yeah I have the same problem also! It kind of jerks as it does this weird clicking noise. So CV joint or springs? Anyone know how much it'd be to fix?
flybyesti is offline   Reply With Quote
Old 02-26-2007, 09:42 AM   #14
BMW Man in 2.5RS
Member#: 4162
2001 Impreza 2.5RS
The cv joint isnt too bad. I just replaced my drivers side axel. It was $79 from advanced auto with a lifetime waranty. The problem is that wasnt the problem. I am going to put mine up on jack stands this afternoon and drive it to figure out where the sound is coming from.
I have done a lot of research on this problem. It seems like a lot of people have it but no one knows exactly how to fix it.
Some of the possible fixes are:
CV Joints
Tie Rod Ends
Ball Joints
Sway Bar Endlinks
Wheel Bearings
Internal Tranny Problem
I am hoping that its not the later of the list.
Will keep you updated
Thanks,
Joe
Old 02-26-2007, 04:48 PM   #15
BMW Man in 2.5RS
Member#: 4162
2001 Impreza 2.5RS
Turns out my carrier bearing was loose. Caused the drive shaft to move around during initial acceleration. I would suggest everyone check this.
Thanks,
Joe
Old 06-29-2007, 03:13 PM   #16
only1agam
Member#: 56183
bump i'm having this in my wrx, a clicking/thudding noise when i take a left in the front right wheel.. whats the issue?
only1agam is offline   Reply With Quote
Old 07-05-2007, 09:37 AM   #17
BMW Man in 2.5RS
Member#: 4162
2001 Impreza 2.5RS
if you have had your rear drive shaft undone for any reason make sure you check the carrier bearing. That was my problem.
Old 12-05-2009, 12:35 AM   #18
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Wow, it's been two years on this thread. Hey everyone, I am having the same clicking sound coming from my passenger front, I posted my own thread on it but not much response so I decided to do further research.
BMW, what's a carrier bearing? How did you come to that conclusion?
I am a little frustrated because me and a friend took a look tonight and couldn't really find what's wrong. We took the wheel off and tried to diagnose where the nosie is coming from but no sound came from turning the steering wheel without the car actually sitting on the front right wheel so obviously it has something to do with weight and stress. We tried to see if anything was loose or any grease was splattered under the wheel well but everything was intact. So, I left his place with dissatisfaction because I can't freaking find where this sound is coming from.
The time that we tried to find this sound with the wheel on, he said that it came from the dust shield that's behind the rotor. He sounded pretty positive about it but I find it hard to believe because it wasn't rubbing on anything when we inspected it.
This happened after I replaced my brake pads and put on new wheels and tires. I did the brake pads without removing the calipers, I have a 06 WRX with 4-pot calipers.
This is driving me nuts.
kenliu84 is offline   Reply With Quote
Old 12-05-2009, 11:04 AM   #19
super-u-man
Member#: 226123
03 bugeye
blue
I am having the same problem on my 03 wrx, i had to put new kyb gr-2 struts and eibach springs on my car all the way around. my spring it shifting in my strut and it causes it to pull to the direction i just turned my wheels to, it also makes a clunkin noise and i dont know how to cure it. so if any one figures anything out let me know cuz im goin crazy!!!!!!
super-u-man is offline   Reply With Quote
Old 07-26-2020, 06:51 PM   #20
rally me
Member#: 100127
02 WRX wagon
carrier bearing? today i replaced my leaking passenger side cv axel with a heavy duty cv axel from advanced discount auto. do you think this will be an issue? the heavy duty axel looks visually different, it’s beefier for sure. it cost $140 but i used a coupon and a speedperks discount. the car quest cv axels were $70. thanks drive safe
rally me is offline   Reply With Quote
Old 07-27-2020, 12:39 PM   #21
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Responding to a 13 year old post where the OP's last activity was 2008?
Samurai Jack is offline   Reply With Quote
Old 07-27-2020, 02:46 PM   #22
rally me
Member#: 100127
02 WRX wagon
yup and iíve had the same subaru for almost eighteen years. i havenít had too many issues i that couldnít solve on my own �� is having two different cv axels problematic? my abusing the subaru days are in the rear view mirror. drive safe
Old 07-27-2020, 03:25 PM   #23
Aristocrat Autosport
NASIOC Storefront Vendor
Member#: 384404
MANY WRX, STI, 997TT
wrb
is the car auto or 5 speed? i do know that after market axles in an auto give it some "shutter" vibration like when sitting a traffic light as the aftermarket are close but not a 100% match to OEM spec
Aristocrat Autosport is offline   Reply With Quote
Old 07-27-2020, 03:51 PM   #24
rally me
Member#: 100127
02 WRX wagon
5 speed with a legacy GT gear set, TWM short throw shifter and kartboy bushings. if any of that matters.
Clicking-ticking front driver wheel when I turn right and only forwards??????? Rallly2000 Brakes, Steering & Suspension 4 07-25-2009 03:23 PM
Clicking Sound When Turning and Brake Pedal Pressure Issue WebMasterP Brakes, Steering & Suspension 14 10-11-2008 05:38 AM
Clicking sound when turning wheel in reverse Dynamite59487 Service & Maintenance 13 09-01-2007 01:41 PM
Clicking sound when turning, pls help! Diezel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-09-2005 12:38 AM
Clicking sounds when I turn the wheel CVJoints/Axles/Suspenion? This is an 04 DAMNIT! elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-01-2004 02:29 AM
