Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Old 09-02-2016, 01:47 AM   #476
1MOFOSTI
Member#: 375748
04 STi
Originally Posted by Bikelok View Post
Easy and free if you have a Dremel and you keep the stock bolts.
Get OEM eccentric bolts or continue to use OEM non eccentric after slotting?
(Will be doing the rear only)
1MOFOSTI is offline   Reply With Quote
Old 09-02-2016, 10:32 AM   #477
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Continue using OEM non eccentric bolts after slotting.
Bikelok is offline   Reply With Quote
Old 09-02-2016, 11:41 AM   #478
1MOFOSTI
Member#: 375748
04 STi
Got it, thanks Bike
Old 01-06-2017, 11:19 AM   #479
chuckc
Member#: 281802
10 SH XT, TondraGD
Satin White Pearl, WRB
Default more than 2.75 years and 35k miles on GTWorks front camber bolts
Originally Posted by chuckc View Post
11 wrx take-off suspension ,
11 sti rear upper control arms,
rear ISC adjustable LCA's,
SPC adjustable toe arms,
3/4 saggy butt spacers and .25 up front (I plan on going to 1.25 rear)
GTWorks front camber bolts (stock top location)
front SPT underbody chassis brace
NT03's 18x9.5 +40
255-40-18 -- Goodyeard Eagle GT's
before GTW bolts and rear LCA's and toe arms was at
-1.1° camber -- 0 toe front
-1.7° camber -- 0 toe rear
now
-1.9° camber -- 0 toe front
-2.1° camber -- 0 toe rear
peace
I got a fair amount of flak for going with the GTWorks front camber bolts on my FXT with WRX take offs. The bolts are designed for stock location and that was cause for concern to some folks; so I want to give an update.
They have lasted through one winter and one year driving throughout NYC, home to the countries ****tiest pothole ladened roads, and I'm working on my 2nd winter with them in NC. They've been on multiple trips to KY, FL, MS, NY, TN and OH. They've been driven hard on gravel and dirt roads, as well as several spirited mountain pass twisty trips. I've put more than 35K miles on them with no additional alignments needed. So I'm standing by the decision and the product. I'll post up when either an alignment has to be done or I get them to 50K, whichever comes first.
peace,
Chuck
chuckc is offline   Reply With Quote
Old 03-28-2017, 06:33 PM   #480
cmiovino
Member#: 134005
2004 WRX Premium
Anyone have a clue what size sockets are needed for the Whiteline/SPC bolts?
One seems like an 18mm, which I don't have. No American size fits. 19 fits, but slips when turning.
Same with the other side. 16mm fits, but slips. No American size fits either.
Old 03-28-2017, 06:47 PM   #481
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You must have a 17 and 19 wrench if you're working on a Subaru, so you can be pretty confident the bolt head is 18mm if it's between those two wrenches. Only ASA/ISO bolt head sizing uses 18mm heads. The next size down in ASA/ISO would be 16mm but you say it slips. 15mm is a deprecated alternate for 16mm in that system so you should probably locate a 15mm wrench and see if that works.
This is why I have a full set of wrenches even though Subaru factory bolts only use 8, 10, 12, 14, 17, 19, and 22mm sizes.
Old 05-27-2017, 01:16 PM   #482
chuckc
Member#: 281802
10 SH XT, TondraGD
peace,
Chuck
Just an update on the GTWorks front chamber bolts.
I've now had them on the car for 54,000 miles with zero issues. Zero realignments or problems.
peace
Old 05-27-2017, 01:18 PM   #483
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
peace
I can't remember if you ever explained why you decided to waste money and replace the stock upper bolts. What were you expecting to get out of that?
Old 05-27-2017, 11:56 PM   #484
stevenkelby
Member#: 207569
MY04 Forester XT
Red
Maybe he just wanted the stock alignment, but with a weaker bolt.
stevenkelby is offline   Reply With Quote
Old 05-29-2017, 05:30 PM   #485
chuckc
Member#: 281802
10 SH XT, TondraGD
LOL, I guess salt makes everything better right?
It's not personal buddy, why try and make it like that?
I "wasted" my money on these because I lowered my fxt on wrx suspension and wanted better handling characteristics for curvy mountain roads (like the devils whip), spirited driving and overall handling characteristics. I didn't like the idea of using those tiny lower bolts and didn't want the harshness of coils.
Stock numbers with stock suspension: -1.1° camber -- 0 toe front; -1.7° camber -- 0 toe rear
My setup -1.9° camber -- 0 toe front; -2.1° camber -- 0 toe rear
'11 wrx take-offs, front spt H-brace, STi rear sway bar and upper control arms, ISC adjustable lower control arms, and spt adjustable toe arms.
9.5" NT03's with 255's Goodyear eagle GTs
The difference in stability between a stock SH and mine are night and day. Could that have been achieved with smaller bolts in the lower position— maybe. Would they have held up this long without needing a re-alignment— I doubt it.
Neither you nor anyone else that hates on these have ever been able to produce any real life examples of these failing. Couple that with 53k miles on all kinds of roads across the East coast and Midwest parts of the county from Buffalo to Miami, Missouri to Tennessee, with zero need for re-alignment. Sorry, but the "weaker" claim is unsubstantiated.
I'll post back at 75k or if I need a realignment, which ever come first.
I'm not mad in the least, I understand change can be hard.
peace
Old 05-29-2017, 06:05 PM   #486
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
So you're claiming the GT Worx bolts allowed you to to get an additional 0.8* of camber adjustment compared to the stock upper eccentric bolt. First, I'd actually like to see that proven by myself or someone else who I trust. That's not personal, by the way, it's just that in 13 years of being on NASIOC the number of people I've seen make a claim only to have it fall apart when checked carefully is legion. You wouldn't believe the number of times I've had someone bring me a car and say "No one can get more than X out of the stock alignment so I want to add this part" and then I can get several tenths more than X just by actually fiddling with it carefully.
Now, if we take it on faith that your camber numbers are really comparing a properly maxed out stock setup vs no changes at all other than the GT Worx bolts, then we need to think about the geometry. The way camber bolts produce adjustment is to have a size difference between the lobe of the bolt and the shaft of the bolt that allows you to shear the knuckle relative to the clevis to produce a change in camber. The amount of adjustment you get is determined by the ratio of the diameters of the shaft and lobe. The bigger the difference, the bigger the adjustment range. We know the lobe can't be any bigger than the stock eccentric bolt or it wouldn't be able to fit into the hole in the knuckle. That means the shaft of the GT Worx must be thinner to get a bigger ratio between the lobe and shaft. This requires an explanation (not from you, from an engineer at GT Worx) as to how the bolt can be as strong as the stock bolt if it's enough thinner to allow a huge amount of additional adjustment (the 0.8* that you claim).
Neither you nor anyone else that hates on these have ever been able to produce any real life examples of these failing. ... Sorry, but the "weaker" claim is unsubstantiated.
Your success is an anecdote. It is not proof. The GT Worx bolts may be ok (unlikely enough I'd require an engineer's proof) or you may simply be lucky. Hardly anyone is running these. In fact, you are the only person anywhere in the world I've heard of using these things. With only a single data point, there's know way to know if the bolts in fact have a sufficient clamping force and safety margin to claim they're as safe as the stock bolts.
Given that they must be thinner based on simple geometry, the only way to make them as safe as the stock bolts is to use significantly better metallurgy coupled with significantly better production and quality control.
Simply put, your results aren't enough to prove anything and certainly aren't enough to overturn the general idea that putting a smaller bolt in the upper location on the front is risky.
Edited to add: Wait, did you do the camber bolts at the same time as the springs? If you changed the ride height with the springs you also added negative camber. That alone could mean that the GT Worx bolts add no adjustment compared to stock which means they might be the same diameter and a waste of money (but would explain why you haven't had problems).
Old 05-29-2017, 07:47 PM   #487
chuckc
Member#: 281802
10 SH XT, TondraGD
[quote=williaty;45163005]So you're claiming the GT Worx bolts allowed you to to get an additional 0.8* of camber adjustment compared to the stock upper eccentric bolt.....QUOTE]
To your point it is anecdotal and just my experience, but that's all I have.
The stock bolts required an alignment shortly after I had the car in NYC. And I haven't need another since adding them.
I totally understand where you are coming from on peoples wild claims. And really do respect the fact you are a professional with a lot of experience.
The bolts are a different material—they don't rust and are so close in size to the stockers that I didn't think I would even see gains. The geometry argument is not lost on me, to your point it's physics.
as previously noted by another user:
Originally Posted by mwm5094 View Post
So here are the measurements:
GTSPEC: 13mm to 16mm
Stock: 13.7mm to 16.4mm
I lowered the car first on wrx struts (vs just springs) with .25" subtle solution spacers up front and .5" saggy butt spacers in the rear, retaining the fxt knuckles and hubs.
The -1.1 number is factory for stock height fxt. You would know better than me, but I read -1.5 is the most you can squeeze out of the 2011' wrx fronts. I'm a little foggy on my first numbers with the wrx takeoffs, but I seem to recall -1.4. and I wanted to get the front and rear camber closer and avoid rub when I went from a 205 tire to 255.
I added the GT works bolts and rear LCA's when I went with the NT03's (18x9.5) as well as an additional .25" saggy butt spacer for a total of .75" in the rear to avoid rub under load. My overall drop was close to 1.5".
The shop that did the strut install and alignment is GTX SERVICE & ALIGNMENT CORP. in Astoria NY. The shop managers name is George and they texted screen shots of the numbers that I never pulled off of an old phone for what ever that's worth.
peace and thanks for the thread.
Old 05-29-2017, 07:57 PM   #488
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Default Camber Bolt FAQ and Tutorial
The GT Worx bolts are smaller than the OEM camber bolts, BUT GT Worx claims they are stronger than the OEM one. I don't buy that at all, but that's what they say. They should have made a bottom bolt instead of a top bolt.
So the OP is ok putting a smaller bolt up top but not on the bottom.
If the top bolt fails the wheel can lay on its side causing a massive loss of control. If a bottom bolt breaks the wheel will most likely lay against the strut, still allowing you to steer.
Most likely the GT Worx bolt will not fail, but it does not sit well with me. There are better ways to get the numbers the OP it looking for.
Chuckc, I'm not trying to flame you and I appreciate you posting your results. I wish you luck.
Old 05-31-2017, 12:29 PM   #489
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
the strenghty of the connection between the strut and knuckle is heavily derived from the clamping force of the bolt, more so than its shear strenght. this is why cam bolts work well.
half inch bolt, 100ftlbs ~=12000lbs of clamping force per bolt!
On the low end the coefficient of friction for clean dry steel to steel is 0.5, so you're looking at 6000lbs of force to get that connection to move.
you also have the second bolt clamping and the connection, so you need 12000lbs of force to get that joint to slip. Unless you hit something you're not going to get that.
uofime is offline   Reply With Quote
Old 05-31-2017, 01:43 PM   #490
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The frictional force in the joint is a function of the tension in the bolt. The tension in the bolt is limited by the tensile strength of the bolt. The tensile strength is related to the square of diameter, meaning that smaller bolts get weaker fast, lowering the total clamping force available. You can offset this by using better metallurgy and better quality control but that costs money which means most aftermarket camber bolt manufacturers don't do it.
And yet people manage to make their alignment slip due to non-impact loading on a regular basis. I do firmly believe that when that happens it can be traced back to installer error but the aftermarket bolts have a thinner safety factor making them less tolerant of even small errors in installation.
Old 05-31-2017, 03:27 PM   #491
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
the torque determines axial clamping force, yes ultimately the strength of the bolt determines how much torque it will take before it shears.
here's a handy chart:
a grade 8 1/2: inch bolt will take 23k lbs in tension and 18k in shear (you'll note these bolts are in double shear, so functionally it is twice that)
Yes, I agree install error contributes massively to failures, guten tight is not an acceptable spec when you're working on suspension components...
Old 08-25-2017, 08:30 PM   #492
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
White GF8 wagon
Question
Originally Posted by chimchimm5 View Post
All the following camber bolts have essentially the same adjust range; regardless of what is advertised. You can't get more adjustment out of a 14mm bolt. And if you alignment tech is willing to push/pull the knuckle to max out the camber, then the bolt itself is irrelevent for max camber.
SPC/Whiteline/etc camber bolt
PRO: cheapest (or expensive) and found EVERYWHERE; has an antislip tab to reduce change if slippage occurs
CON: narrowest of the bolts with lowest torque spec (~75 ft/lbs) which suggests it's the weakest
I might just end up slotting the struts (as I used this method on a different car and it worked just fine)... but I've got two questions about the above style of camber bolts.
I was going to buy a set of this style to use on my '98 JDM Impreza STi wagon. When looking at offerings at eBay, I noticed some of these style of camber bolts used just one washer per bolt (similar to the ones pictured above)...
... while others used two washers per bolt.
Considering that orientation of the washers appears to be important in regards to actually making the camber adjustment, I'm rather surprised that camber bolts are even offered with only one washer apiece.
So my first question is... Are two washers per bolt superior to having one washer per bolt?
I'm also surprised by the listed torque settings of some of these camber bolts. These ones HERE appear to be limited to 55 ft/lbs. That seems awfully low.
So my second question is... Does a torque setting of 55 ft/lbs indicate that these particular bolts are made of crap steel, and should they be avoided?
Both of my questions may seem to have obvious answers, but I'm hoping they might still encourage some relevant discussion... hopefully civilized.
Vancouver98STi is offline   Reply With Quote
Old 08-29-2017, 07:19 PM   #493
Vancouver98STi
Member#: 459287
White GF8 wagon
Lightbulb Seems like a good deal to me!
Actually, I wonder why there is no tabbed washer for the OTHER side of the bolt. I understand that the tightening of the nut holds that end of the bolt in place, but you are relying on the nut to do more than one thing. If there was a tabbed washer on that end, then the nut is only doing one thing: holding the bolt in one axis.
Maybe you could order a 2nd set of washers for the nut end too.
After poking around a bit more on eBay, I've found the following set of 14mm camber bolts. Four of them, two tabbed washers per bolt, and a grade of 10.9 marked on the heads. 12 bucks... includes shipping. I'm in.
Old 06-03-2019, 03:38 PM   #494
chuckc
Member#: 281802
10 SH XT, TondraGD
Default just an update
[quote=chuckc;45163091]
Here's an update, however anecdotal it may be. I'm now at 92,000 miles with the GT works bolts and no realignments. I'll post back in another couple of years. peace.
chuck
Old 06-05-2019, 02:01 PM   #495
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
GTWORX has never made camber bolts. GTSPEC is a different company.
- Andrew
AndyRoo is offline   Reply With Quote
Old 08-15-2019, 06:47 PM   #496
Bigapples
Member#: 465009
My $0.02 worth,
I found this an interesting thought process.
I sized my camber bolts by the clevis holes. So the top camber bolt was 16 mm iirc and the bottom one was 14mm. The cams then fit snugly in the clevis holes. I placed the tabs that bend in beside the bolts opposite to the cam lobes with the upper cam lobes pointing inwards and the lower cam lobes pointing outwards.
In other words the upper handle points inwards to the motor and the lower handle points outwards to the hub.
Then adjusted my camber. I can get 3.5 degrees if I need it. Currently have a fraction over 3 degrees on the left and about 2.5 on the right (most tracks I race on are right turning predominant tracks). The bolts are Whiteline - grade 10.?? and the washers are also fairly hard with sharp locking points. Bolts are torqued to Whiteline specs.
This is on a Version 6 STi RA Limited.
Bigapples is offline   Reply With Quote
Old 07-25-2020, 11:12 AM   #497
Cokedoutsti
Member#: 517019
2019 WRX STI
Crystal White Pearl
Thank you very helpful
Cokedoutsti is offline   Reply With Quote
Tokico D-Specs + Camber bolts = less camber than stock struts without camber bolts?! formula91 Brakes, Steering & Suspension 10 09-07-2009 12:59 AM
Camber Plates/Tophats and Camber Bolts kjgerz Brakes, Steering & Suspension 3 10-16-2006 05:34 AM
front camber plates, and front camber bolts? rathead Brakes, Steering & Suspension 0 09-11-2006 12:18 PM
Oakos Automotive 14 mm Camber Bolts *New and Cheap* 02BlueSuperRoo Private 'For Sale' Classifieds 8 02-24-2005 03:57 PM
What rear camber setting with lowering springs and camber bolts? kestrel Brakes, Steering & Suspension 3 10-11-2003 02:54 PM
