Welcome to the North American Subaru Impreza Owners Club Monday August 10, 2020
Old 07-10-2020, 11:32 PM   #1
Raikkonen-F1
Member#: 411992
2018 WRX STi
ISM
Default Alignment issue and/or tire issue? 2018 STI
Hi all - have a 2018 STI with the original bridgestone tires (12K on them).
The car pulls slightly to the right when off throttle but as soon as you give throttle, it pulls to the left quite noticeably. I decided to rotate the tires - put the fronts in the rear and the rear in the fronts. Went for a test drive and now the inverse happens - pulls slightly to the left off throttle and to the right under throttle. At first i thought it's a tire issue but thinking alignment is also at play. I checked the tire depth on all 4 tires on different groves and they are all 7/12th. Will schedule an alignment at the dealer but was wondering if anyone had this issue before. Tire pressure is 32/33 psi (factory specs).
Raikkonen-F1 is offline   Reply With Quote
Old 07-11-2020, 02:57 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
While the alignment may be at least part of the issue, the rest, if not all of the issue, may be belt separation in the tires.
Why?
Because simply rotating tires front to back should not cause an exact opposite reaction.
I know there have been tire recalls in the past due to this issue ( belt separation ).
Check to see if there have been any tire recalls on your brand/model tire.
Samurai Jack is offline   Reply With Quote
Old 07-12-2020, 12:00 AM   #3
Raikkonen-F1
Member#: 411992
2018 WRX STi
ISM
Why?
I took all 4 wheels off and visually inspected them very closely - nothing stood out to me. They all head a uniform wear.
Old 07-12-2020, 08:35 AM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You can't tell if the belts are separating by looking at them. They are covered by the rubber.
Old 07-14-2020, 06:50 AM   #5
ians19832
Member#: 516619
Since the issue changed from right to left and vice versa when you rotated the tyre's, Maybe an issue with wheel balancing? Unless you took the tires off the rims and rotated them?
ians19832 is offline   Reply With Quote
Old 07-14-2020, 01:22 PM   #6
rtv900
Member#: 428511
2016 STI
The only thing I'm wondering is if you just moved rears to the front but didn't change sides?
Or you moved rears to front and switched sides at the same time and just moved the fronts back
rtv900 is offline   Reply With Quote
Old 07-15-2020, 07:34 AM   #7
cknowlen
Member#: 189077
2011 STI limited
From my experience, a car which pulls in a specific direction on throttle and lets off after is usually do to a loose/failed bushing. In my specific cases it is typically one of the rear control arm bushings (on the front control arms). Now, since your car is a 2018, its really unlikely one of these bushings has failed already, but I would at the very least do a sanity check and get under the car to inspect all of the suspension bushings up front to make sure you do not have any that are worn or loose. Food for thought.
cknowlen is offline   Reply With Quote
Old 07-16-2020, 03:12 PM   #8
Raikkonen-F1
Member#: 411992
2018 WRX STi
ISM
Moved fronts to rear and rears to front. Did not change sides.
Old 07-16-2020, 03:13 PM   #9
Raikkonen-F1
Member#: 411992
2018 WRX STi
ISM
Will have the dealer look at it - scheduled appt next week.
Old 07-29-2020, 11:23 PM   #10
Raikkonen-F1
Member#: 411992
2018 WRX STi
ISM
What do you guys think?
That rear left toe isn't very symmetrical with the right rear.
Car still pulls in one direction under throttle and opposite direction off throttle but that's not caused by toe. I still think it's a tire issue but according to dealer it's not.
https://drive.google.com/file/d/1MyH...ew?usp=sharing
Old 07-29-2020, 11:39 PM   #11
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
I'm not an expert on this new gen of Subaru but in my old 04 WRX my front camber was always more negative than the rear....not sure why the rear on this has more negative camber than the front..? Anywho, I would check all your bushings like the other member has suggested..
murrdogg24 is offline   Reply With Quote
Old 07-29-2020, 11:55 PM   #12
Raikkonen-F1
Member#: 411992
2018 WRX STi
ISM
I haven't checked bc swapping location of tires (i/e, front left with front right) has an opposite effect.
