Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Old 07-25-2020, 11:15 AM   #1
Cokedoutsti
Member#: 517019
2019 WRX STI
Crystal White Pearl
Default Whiteline Camber bolt snapped
My whiteline camber bolt snapped in my lower front hole and now I cant get it out, Iíve tried hammering it out didnít help much, and then tried removing the upper oem camber bolt so i could get some play and still wouldn't do anything besides move a little back and forth, any help?
Cokedoutsti is offline   Reply With Quote
Old 07-25-2020, 11:17 AM   #2
Psychoreo
Member#: 79643
2021 STI TE
Terminal black pearl
Bigger hammer and a punch.
Air hammer.
Drill.
Torch.
Psychoreo is offline   Reply With Quote
Old 07-25-2020, 04:47 PM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
How many times are you going to post about the same damn thing?????
One post is all you need, not three!
Samurai Jack is offline   Reply With Quote
Old 07-26-2020, 08:42 AM   #4
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
I'm betting that the eccentric on the bolt has turned and that the holes in the strut tabs aren't lined up with the hole in the knuckle close enough for the eccentric to clear. Loosen the other bolt (a lot) so you can wiggle things around with things like floor jacks and pry bars, and try turning the bolt. If the bolt head end was what broke, I'd probably tackweld the nut to the bolt, cut the flag off of the washer, and turn the nut to different positions before getting out the hammer. Don't just use the hammer.
Now, on to other matters.
Have a little patience. At least wait more than a minute or five before poking the forum again for an answer to the same question. The time would be better spent looking at your busted crash bolt situation. If you don't know what this Whiteline bolt looks like, look it up. It'll help you see what you're up against.
And now you know the main reason I won't ever endorse the use of aftermarket reduced-shank strut to knuckle fasteners (gee, I bet that means reduced strength as well).
Norm
Norm Peterson is offline   Reply With Quote
