Welcome to the North American Subaru Impreza Owners Club Thursday August 6, 2020
Old 07-29-2020, 09:20 AM   #1
JakeHovarter
Member#: 498308
Default 2011 sti only making 10psi after engine rebuild
So I recently rebuilt my 2011 sti after going stage 2 external after spinning a bearing new short block was installed and many new hoses and lines also installed Iím only hitting 9-10 psi in S# have tried OTS 93 map from access port and that didnít change anything boost wise. Iíve done a boost leak test and no leaks I have a decent size waste gate crack running the oem boost control solenoid but no codes are thrown to show itís bad Iím a little lost and would like to see if anyone has any other thoughts on this issue I was making full boost before the rebuild with a boost leak and now no boost leak and I have an issue halp plz
JakeHovarter is offline   Reply With Quote
Old 07-29-2020, 03:49 PM   #2
Jedi03
Member#: 491095
2009 STi Blue
how many miles on block now? if its not broken in rings may not be sealing completely yet
Jedi03 is offline   Reply With Quote
Old 07-30-2020, 03:58 PM   #3
cknowlen
Member#: 189077
2011 STI limited
First off: Punctuation man! That run on sentence was absolutely terrible to read.
Second: I am honestly not sure if the 2011 still uses the restrictor pill (which is sad because I also own a 2011)...but if you replaced "many new hoses" it is quite possible this vac line was replaced and a now "pill-less" line is in its place....read more here:
https://cobbtuning.atlassian.net/wik...l+System+Works
cknowlen is offline   Reply With Quote
Old 08-01-2020, 01:11 AM   #4
Jonikopsuka
Member#: 515863
1997 Legacy GL
2 tone, turquoise-green
I have no idea what kind of boost you should be making but could it be that your wastegate spring is only rated for that ~10 psi. If there are no leaks that's the next thing I'd check.
If the spring is rated for more and is in good condition, could it possibly be that your turbo doesn't flow enough air. I know that's really unlikely but better to know for sure.
Jonikopsuka is offline   Reply With Quote
Old 08-01-2020, 01:15 AM   #5
Jonikopsuka
Member#: 515863
1997 Legacy GL
Ok so scratch the second part
A quick Google tells me you should get 14+ psi
I personally would check the spring to see if it's gone bad.
