Welcome to the North American Subaru Impreza Owners Club Thursday August 6, 2020
Old 07-29-2020, 11:34 AM   #1
thehippiesubaru
Member#: 505428
Default Changing 4 tires?
My 2019 Impreza Hatchback damaged one of the tires, now, do i need to change all 4 tires when the other 3 has only 3,000 miles on it?
I just changed 4 tires about 6 mos ago only.
thehippiesubaru is offline   Reply With Quote
Old 07-29-2020, 11:41 AM   #2
numskull50
Member#: 373996
2015 FXT Touring
Quartz Blue Pearl
I think your allowed 2/32 if you buy the exact same tire. Some shops/tirerack can shaved the new tire to match the others.
numskull50 is online now   Reply With Quote
Old 07-29-2020, 12:09 PM   #3
NighthawkSTI
Member#: 495630
you absolutely dont need to replace all 4 tires. get a tire gauge, measure the depth in tread of the 3 good ones and then go to tire rack and buy ONE new tire of the same brand and model as the other 3 and have them shave it down to the same depth. I did it with a continental DWS when one went flat, had tire rack shave down a new one, and it matched the others perfectly. Tires have the best grip when they are worn down 3-4/32 anyway.
NighthawkSTI is offline   Reply With Quote
Old 07-29-2020, 12:26 PM   #4
rtv900
Member#: 428511
2016 STI
if the others have 3000 miles on them you don't need to do anything, replace the one.
If there was meaningful wear in 3000 miles we'd all need new tires every 10k
rtv900 is offline   Reply With Quote
Old 07-29-2020, 12:48 PM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I'd like to know how the Impreza damaged the tire and not the driver?
Like others have already said, replace the one unless there is other damage to the others tires you haven't mentioned.
Samurai Jack is offline   Reply With Quote
Old 07-29-2020, 01:03 PM   #6
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
^ Car rolled backwards at the rental car return entrance? Not sure..
oichan is offline   Reply With Quote
Old 07-29-2020, 03:15 PM   #7
thehippiesubaru
Member#: 505428
I hit a curb, it didn't go flat then but had sliced off the tire wall.
Old 07-29-2020, 03:15 PM   #8
thehippiesubaru
Member#: 505428
thanks for your reply
Old 07-29-2020, 03:16 PM   #9
thehippiesubaru
Member#: 505428
Old 07-29-2020, 03:16 PM   #10
thehippiesubaru
Member#: 505428
Old 07-29-2020, 04:21 PM   #11
rtv900
Member#: 428511
2016 STI
well in that case losing the tire was lucky
a wheel would cost way the hell more
Old 07-30-2020, 12:43 AM   #12
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
You don’t need to RR all 4 tires
Now if 3 are have more than 1/2 tread worn out then yes
Engineers purposely put ‘a range’ built into the transmission/differential
If they didn’t......what would happen if you put your spare on and drove 200miles to a town?
Manufacturers would be buying Transmissions left and right.
I had denied several “AWD Expert Customers “ for wanting 4 new tires went one was damaged. Whether it be Ford/Audi/Subaru/etc
All manufacturers have a tolerance (it’s quite large in fact) for tire circumference
Hell I had some guy said needs 4new tires and he had 3different sizes on his POS
AliBenn is offline   Reply With Quote
Old 07-30-2020, 09:35 AM   #13
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Well, obviously, he was right then!
Old 07-30-2020, 06:21 PM   #14
AliBenn
Member#: 487
Acadia Green RS-T
