Welcome to the North American Subaru Impreza Owners Club Monday August 10, 2020
Old 07-31-2020, 12:24 PM   #1
raulz888
Member#: 509899
2017 WRX
Default Octane Booster
Hey all. Just wondering if anyone is using an octane booster like Boostane to increase from 91 to 93. No 93 gas in Utah, but would love to run my 91 tune with 93 gas. Anyone making their own 93?? Thanks!
raulz888 is offline   Reply With Quote
Old 07-31-2020, 02:08 PM   #2
numskull50
Member#: 373996
2015 FXT Touring
Quartz Blue Pearl
do you have E85? you can add 1-3 gallons to fill p of the highest octane you have for a boost. and its cheaper than stuff in a can.
numskull50 is offline   Reply With Quote
Old 07-31-2020, 03:07 PM   #3
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
I buy Lucas octane booster online for about 5.00/bottle. It will boost your octane about 2pts per tankful, one of the few octane boosters that actually works. But I'm not sure if it's really good for catalytic converters. You might want to check the Lucas website.
Dave D. is offline   Reply With Quote
Old 08-01-2020, 12:22 PM   #4
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I might if I knew what the hell was in it. The only trusted legit octane boosters on the planet contain MMT. Lucas has it. NOS Racing Formula Octane Booster has it. And Torco has been trusted for years. There may be others these days with MMT as well...been awhile since anyone has spoken on this topic.
Old 08-02-2020, 04:43 PM   #5
F1EA
Member#: 448622
2019 STI SportTech
CWP
I use Lucas and NOS regularly (ie not constantly, but often). They make a noticeable difference and no adverse effects that I've noticed. Logs are all great (including wideband AFR) and never had any misfire issues. So yes... stick to MMT of you want the real deal, as bomber said above.
STP helps a little, but it's not noticeable like those two ^. Mostly useful when in a pinch, to make up for some bad gas, a little extra safety or something along those lines.
I do avoid continuous Lucas/NOS. Usually, no more than 2 tanks in a row; then at least a tank without it and so on.
One thing to do if you use boosters often is to check your plugs like every ~30k mi or so and change if needed. Mine were fine after 50k km on my WRX. Haven't gotten to that point on the STI yet, but so far 0 issues. If you use it only once in a blue moon, don't worry about it too much.
So... in my experience octane booster works fine. Just avoid making it a full time habit. For sure ok to use on days you want to have fun or if you feel you got a sketchy fuel batch.
DO NOT go race your friend the first time you run a booster and flash a new map. Drive the car a bit and do a few logs beforehand to confirm you're all good before going full send. Once you've proven the map/fuel combination you can go with confidence, so it's not like you need to be constantly logging either...
Edit: if stock, use it when you want to have some extra fun. Then back to your normal fuel. I guess you could run it constantly, but then check your plugs as i said above.
F1EA is offline   Reply With Quote
Old 08-02-2020, 05:03 PM   #6
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
You're better off using Touline if they are still sold at Sherwin Williams. I don't remember the last time I typed 'touline'.. lol long long time ago when NOS was cool.
A little bottle of octane booster per fill will net you about zero. If you do a search online, there was a formula to calculate the amount of touline needed to raise the octane level per fill.. and it's quite a lot.
oichan is offline   Reply With Quote
Old 08-03-2020, 01:27 PM   #7
F1EA
Member#: 448622
2019 STI SportTech
CWP
Toluene. It's a slower burning hydrocarbon. Sort of like ethanol. And like ethanol, you need to add a lot more than a little can to raise octane by anything significant.
Octane boosters (with MMT) is different. A different compound. You need less of it to raise octane by a given number, depending on the concentration/dose...
If you're running a 91oct tune with 91+oct fuel, the best octane booster will net just about zero. Or rather, a little safety.
If you run a 93 tune on the 91 fuel plus ~3oct raised by a booster, then it will net you whatever the difference between the 91 and 93 tune. Etc.
Old 08-03-2020, 05:07 PM   #8
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Toluene....I ran that in Cali a few times. You get odd looks at the pump when you are filling up your car with paint thinner at the pump.
Old 08-03-2020, 05:35 PM   #9
oichan
Member#: 492327
19 WRX 16 STI
Yeah, good old days. Haha.
Old 08-03-2020, 07:22 PM   #10
subaru_gc8
Member#: 29292
2004 WRX wagon
gotta be careful with them, they seem to make your o2 sensor not work for very long. At least that is what happened when i used torco for about 3 months
subaru_gc8 is offline   Reply With Quote
Old 08-03-2020, 07:38 PM   #11
turbosiavr
Member#: 490690
i use 110 octane race gas and mix it with 91
turbosiavr is offline   Reply With Quote
Old 08-03-2020, 10:17 PM   #12
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Maybe ask the guys at Corr Performance in Kenner, Louisiana. They keep that on hand as well as e85. They are an awd tuning shop and would probably be able to tell you if there are any gains to be had after adding a can to a tank of typical fuel. Years back, I'd go to the local airport and buy 100 octane avgas. They would let you put it in gas cans but not the vehicle. Haven't tried lately, not sure if that's still a thing.
2slofouru is offline   Reply With Quote
