Welcome to the North American Subaru Impreza Owners Club Thursday August 6, 2020
Old 07-31-2020, 01:08 PM   #1
lts70
Member#: 517149
Default Lightened crankshaft pulley
I have a SOHC EJ25 motor in a boat that I am messing with. I have another thread going on trying to tune the ECU and did not want to muddy the water in that thread with this question.
I am wanting to see if a Lightened crankshaft pulley or Undersized pulleys would be a good option for my engine.
I am only running an alternator as the other accessories were not needed in a boat.
My flywheel has been lightened and balanced.
As far as lightened pulleys I am seeing, Agency Power, Perrin, Grimmspeed as popular. But cannot find much info on undersized pulleys.
Any advise would be appreciated.
lts70 is offline   Reply With Quote
Old 07-31-2020, 01:41 PM   #2
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Why? These components are designed to help the engine accelerate. Boats are pretty constant power, so light weight rotating parts are a waste.
Old 07-31-2020, 01:52 PM   #3
lts70
Member#: 517149
Old 07-31-2020, 02:03 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Why are you making another post about your jet boat?
And, no, you don't need a lightweight pulley.
Samurai Jack is offline   Reply With Quote
Old 07-31-2020, 02:36 PM   #5
lts70
Member#: 517149
I thought I explained it above, I wanted to separate the pulley topic from ECU.
The builder had the flywheel lighted by 10lb to help performance.
I just figured another 5lb would help as well.
Old 07-31-2020, 03:50 PM   #6
Jack
Add Lightness
Member#: 13699
not my president
(From General)
It has zero effect.
In a car, lightened engine rotating parts help by allowing the engine to change revs quickly. If you're accelerating a 3500 pound car, losing 20 pounds means nothing. With your jet boat, I expect the water you're pushing will be a similar significant resistance.
If you do all the math, you might indeed find that all this lightening at full throttle will make 0.1% of difference in acceleration. Once at full speed, and no longer accelerating, it makes exactly zero difference.
