Welcome to the North American Subaru Impreza Owners Club Monday June 14, 2021
Old 01-25-2008, 01:43 AM   #26
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Originally Posted by bmxpunk View Post
What about 91-94 legacy Turbo sedan/ wagon I can't remember for sure but I think its 19/20mm front. 13mm? rear
OK according to the subaru Parts computer for the Legacy SS fronts are available in 18mm and 19mm. Rears were available in 16,17,19mm depending on sedan/wagon/ air suspension.
bmxpunk is offline   Reply With Quote
Old 03-17-2008, 05:22 PM   #27
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Bump. Is the OP still maintaining this?
Old 04-07-2008, 11:32 AM   #28
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
My 2000 Outback (Legacy) Wagon started with a 21 mm FSB, which I snapped (yes, snapped, I don't know how other than mild off-roading- defective??). I replaced it with a 22 mm bar that Subaru's computer said was for a 2001+ Outback. I believe the rear was a 14mm initially, which I later replaced with a 17mm from a Baja. This mod was posted on iclub and referred to here somewhere. It was ideal for the car as a "comfort" vehicle.
Frank
Frank A is offline   Reply With Quote
Old 04-16-2008, 06:33 PM   #29
Nashco
Member#: 47057
http://forums.nasioc.com/forums/show...61&postcount=5
2002 to 1/2003 WRX Sedan rear sway = 20mm
1/2003 - on WRX Sedan rear sway = 17mm
I picked up a rear bar yesterday on craigslist from a 2003 wrx sedan...at first glance it looked like a 17mm, but I didn't have anything to measure with and everything I had read before said 2002 and 2003 wrx sedan rears were 20mm. Well, I haven't measured it yet but I did find this doing some searches. First post should be updated with production dates, that way it's easy for shmucks like me to ask somebody to look at their build date before driving across town to pick up parts I don't need.
Bryce
Nashco is offline   Reply With Quote
Old 05-02-2008, 01:01 PM   #30
WRXcer
Member#: 58059
2002 WRX Wagon
Anyone know anything about the 08 WRX sway bar sizes?
WRXcer is offline   Reply With Quote
Old 05-02-2008, 01:13 PM   #31
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
2005 & 2006 Saab 92x Aero
: 20F/17R
2005 & 2006 Saab 92x Linear
: 20F/13R
AbACUZ is offline   Reply With Quote
Old 09-01-2008, 01:46 PM   #32
Ricter
Member#: 18619
'02 WRX
Anyone know what size rsb comes stock on a 98 Forester?
Ricter is offline   Reply With Quote
Old 09-02-2008, 08:58 AM   #33
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
13 mm
SuperRuWRX is offline   Reply With Quote
Old 10-01-2008, 09:51 AM   #34
paktinat
Member#: 155025
2004 WRX
bump again.
I not lets make a new one.
paktinat is offline   Reply With Quote
Old 12-01-2008, 08:59 AM   #35
Butt Dyno
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Looks like this has fallen apart... anyone want to handle keeping this up to date?
Old 12-01-2008, 01:13 PM   #36
Back Road Runner
Member#: 60082
2004 Forester STI
02 Forester (assuming 98-02), 20mm front, 13mm (solid) rear.
My bro has an 04 FXT, 20mm front, rear is hollow, didn't think it was a 17mm but could have been, probably equiv. to the 13mm solid really. They're pretty much worthless twigs, more of just a placeholder for an upgrade then a useful part, imparting very little loading force.
Also, It might be useful to begin converting sway bar sizes to actuall (estimated) spring rates.
http://buildafastercar.com/tech/Sway...ate-Calculator
Data for 02 Forester (and 98-01 Impreza, 98-02 Forester) front swaybar:
A: 5.25"
B: 33"
C: 6.5"
D:20mm
Motion Ratio (MR): 0.50
equivalent spring rate at wheels:
lb/in force: 107.2 lb/in
My stock 20mm front swaybar effectively adds 107 lb/in of spring rate to the wheel on top of my spring, stock being 157 lb/in on my 02 Forester. One could also figure out relative roll resistance and the torque due to the lever arm via the wheel base and track width stance of the car, my 02 Forester being 99.4" in length(CG at 57%) and 58.1" in width on the front. One could extrapolate longitudinal dive and lateral roll resistance from this.
Although the calculator is simply a guessing tool to get close to the actual values, it isn't a precise measurement of the bar. One would actually have to physically test the bar to get real results. However, the calculator would get you close.
I just see it as more useful because the geometry of the bars change front and rear, the relative motion ratios change front and rear, and all this changes between newer and older models too. This means a 20mm front bar and 20mm rear bar doesn't do the same thing and a 20mm front bar from a STI and a 20mm front bar from a base Impreza also do not do the same thing. The geometry and motion ratios vary, making relative wheel rates vary despite being of the same bar size. Hollow vs. solid also play a roll, not to mention that the metal used may vary from one company to another, stepping from one steel alloy to another and using different heat treatments and getting different spring forces for even the same bar shape and size.
Old 12-01-2008, 03:05 PM   #37
Web Foot STi
Member#: 39086
2004 STi
Originally Posted by Back Road Runner View Post
...the metal used may vary from one company to another, stepping from one steel alloy to another and using different heat treatments and getting different spring forces for even the same bar shape and size.
Actualy this isn't quite true. The Modulus of Elasticity for most spring steels that we use in torsion (G) is 11,200,000psi. (Silicon-Manganes is 10,750,000psi) Heat treat has a big impact on streangth, but has no effect upon spring rate untill the yield point. Minor changes don't have a big effect, unlike OD/ID which is D^4. (A solid bar has an ID of 0, so the math still works.)
The comments about motion ratio and wheel rates are very true.
Web Foot STi is offline   Reply With Quote
Old 12-01-2008, 06:19 PM   #38
Back Road Runner
Member#: 60082
2004 Forester STI
Interesting. I would figure spring force would vary a good bit from material to material. I do kind of understand that most companies will use a similar make up and treatment as only specific parameters make a good spring type metal. However, I would have guessed more variation since not all metals are sourced from the same place, formulated the same, and treated the same.
You're right though. Modulus of Elasticity is a linear part of the equation, so even significant changes don't contribute to nearly as much of a change as diameter as it's to the 4th power in the moment of inertia part of the equation. 11,000ksi to 10,000ksi simply isn't a tremendous change(10%) when just one mm added or subtracted may be 20% or more.
Old 01-22-2009, 11:59 AM   #39
paktinat
Member#: 155025
2004 WRX
I'm working on compiling a spreadsheet. you are about to have PM inbound.
Old 10-13-2009, 05:02 PM   #40
Phat04WRX
Member#: 59097
04 WRX
Java Black
back from the dead. any idea what a s203 or s204 sway bar sizes are?
Phat04WRX is offline   Reply With Quote
Old 10-16-2009, 03:13 PM   #41
Phat04WRX
Member#: 59097
04 WRX
Java Black
anyone?
Old 10-26-2009, 04:27 PM   #42
Lufusol
Member#: 221911
2009 OB 2.5i SE
Seacrest Green
Pardon my ignorance but I have a '05 [Legacy] Outback 2.5i and I haven't found the stock front/rear swaybar sizes listed here. Anyone know them? The rest of my suspension is also stock and I am just looking to reduce roll and understeer a little, without affecting the ride too much.
Lufusol is offline   Reply With Quote
Old 07-11-2010, 09:22 PM   #43
Stainless
Member#: 84126
06 forester
can we update this?
Stainless is offline   Reply With Quote
Old 07-12-2010, 02:37 PM   #44
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
front is definitely a 19, same for GR sti. Rear may be 13, but I can't remember for certain right now. Will measure bar that came off my uncle's and report back.
Old 07-12-2010, 02:46 PM   #45
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
i was told 09+ WRX had a 21mm front sway. i dont have a caliper to measure mine though
gsrcrxsi is offline   Reply With Quote
Old 07-12-2010, 04:42 PM   #46
Power6
Member#: 72730
2019 Volvo S60 T6-R
SPORT CHASSIS
Yeah I think there was some bad info floating around. I do have calipers and my 09 WRX has a 21mm front sway, I think we are pretty sure about that one.
To recap:
08 WRX
F: 20mm
R: 16mm
09+WRX
F: 21mm
R: 17mm
Feel free to correct me if I am wrong...
Power6 is offline   Reply With Quote
Old 07-12-2010, 04:55 PM   #47
Lboogie
Member#: 171611
2014 FiST
Blk
08 WRX is likely a 15r
09+ WRX is 20f/16r
08+ sti is 20f/18r
Lboogie is offline   Reply With Quote
Old 07-12-2010, 06:07 PM   #48
Power6
Member#: 72730
2019 Volvo S60 T6-R
SPORT CHASSIS
09+ WRX is 20f/16r
08+ sti is 20f/18r
Corrected above in my original post. You are wrong, stock 09+ WRX is 21/17, only the 08 WRX is 20/16.
Old 07-13-2010, 09:57 AM   #49
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
09+ WRX is 20f/16r
08+ sti is 20f/18r
I'm thinking I was wrong about the 08 WRX front then- I thought it was the same size as my 08 sti.
Old 08-27-2010, 10:32 PM   #50
Yarricc
Member#: 253690
2010 Impreza WRX STI
WR Blue Mica
ok so what are the size's on the 07 WRX?? I don't see them posted on here.
Yarricc is offline   Reply With Quote
FS: 07 STI STOCK struts/springs/tophats/FSB/RSB/front endlinks Fei Jai SCIC Private Classifieds 50 11-12-2009 02:51 AM
fs: Whiteline FSB RSB endlinks 04 WRX FSB xilles 1993 - 2001 Impreza Specific Parts 1 09-30-2007 10:20 PM
FS(MI+IL) Strano FSB, Stock STI RSB sil0nt Suspension/Brakes/Handling 12 07-20-2007 03:43 PM
22mm RSB + stock FSB = scary ride javanaut Brakes, Steering & Suspension 36 05-14-2006 02:12 PM
FS/NJ: stock fsb,rsb, head lights, and hids jumpman86 Private 'For Sale' Classifieds 10 06-22-2005 08:09 PM
