Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 01-21-2004, 06:27 PM   #1
jimtweet
Member#: 52225
2004 wrx 1966 stang
1973 porsche
Default uppipe, downpipe, cat back....how much power gain?
can anyone tell me where to start...been in the VW world a long time and gettin read to receive my new 2004 wrx and wondering where to start with the engine...?
jimtweet is offline   Reply With Quote
Old 01-21-2004, 10:15 PM   #2
abqkid
Member#: 52295
2003 WRX Wagon
Hey,
A good starting place to build some power is the exhaust. Depending on what set up you go with a full exhaust system (up pipe, down pipe, catback) can give you anywhere from 30 to 40 hp at the wheels. The WRX looses a lot of power because it has 3 cats in the exhaust. Keep in mind that you won't pass an emissions test if you replace your up pipe and your downpipe. You will likely get a CEL (check engine light) as well. If you have enough money you should do all of these exhaust components at once as the installation for one component will usually incorporate the removal of another exhaust component. A good cat back will cost anywhere from 400 to 800 bucks. A good DP will cost around 200 to 300 and a good up pipe can be cheap if you simply want to gut your stock one. If not the they are around 150 to 300.
hope that helps
abqkid is offline   Reply With Quote
Old 01-21-2004, 10:52 PM   #3
LotusDriftx
Member#: 48528
THats the sixth time today I have read looses instead of loses on nasioc, its a freaking plague I tell you.
If you check this thread:
http://forums.nasioc.com/forums/show...hreadid=170789
you will find all of your newbie answers, and come back with any specifics you might have and someone will gladly answer them. A little searching goes a long way around here, theres just an insane amount of information.
I haven't seen a dyno result with full exhaust and no ecu reflash but I imagine its somewhere around 250. You should definitely get a reflash though; favorite turners include Cobb (cheapest), Turbo XS, and vishnu. This is commonly referred to as a stage 2 setup (cobb and txs), where as its a stage 1 with vishnu. You should get around 290-310 with these setups.
http://www.vishnutuning.com/
http://www.cobbtuning.com/
http://www.turboxs.com/
LotusDriftx is offline   Reply With Quote
Old 01-21-2004, 11:13 PM   #4
abqkid
Member#: 52295
2003 WRX Wagon
Thanks for the correction man that was my bad.
Old 01-22-2004, 10:56 AM   #5
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
Sport compact car dyno'd a WRX with just a full exhaust back on october 01, but the article isn't on thier website. It was Gary sheehan's touring WRX. If I remember I'll check out what numbers they got.
SlideWRX is offline   Reply With Quote
Old 01-22-2004, 02:42 PM   #6
zombiedog
Member#: 25138
85 e30
PRIMERZ!
What is this engrish crass??? Nternet is the land of poor grammor and mispeled werds.
zombiedog is offline   Reply With Quote
Old 01-22-2004, 10:26 PM   #7
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
If you are on a budget, start with the uppipe. It will allow the turbo to spool faster, add milage to each tank of gas, and just makes the car a whole lot of fun. BEST bang for the buck!
Make sure you get one thermal coated like my Crucial Racing uppipe. Keeps the engine back 30% cooler and allows about 40% more heat energy to drive the turbo.
You will also want the downpipe coated to help keep engine bay tempatures down. You want the heat in the turbo, not under the hood. Coating helps keep it in the pipe, hence moving the heat out the back.
-Valhakar
Valhakar is offline   Reply With Quote
Old 01-22-2004, 11:21 PM   #8
Xman23
Member#: 50224
2004 WRX
I read the up and downpipe FAQ and was under the impression that if you replaced both but left the 3rd cat in the exhaust that you WOULD pass emissions. What's the point if it wouldn't pass? Is everyone here rich and building an off road rally car?
Anyone have *firsthand* experience with an up/downpipe replacement and emissions testing??
Xman23 is offline   Reply With Quote
Old 01-22-2004, 11:30 PM   #9
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Ask your emissions questions in your local forum!!!! Advice given here from someone in Texas about emissions may not apply where you live. Ask local or suffer some unpleasant stuff at your local emissions facility!
Old 01-23-2004, 12:08 AM   #10
Xman23
Member#: 50224
2004 WRX
Well, I was hoping for responses from anyone in the US, from anywhere, with any firsthand input. I realize the laws vary from state to state. Anyone who has replaced an up/downpipe but retained the rear cat...
Since you're from VA beach, and I believe you were the one who wrote the FAQ, and I'm from Delta Charlie (DC), you could answer my question better than anyone <s> I say DC when people ask where I'm from because I've moved back and forth from MD to VA so many times...I'm back in VA now. Who better to ask? You or anyone else in the US...
Old 01-23-2004, 02:27 AM   #11
abqkid
Member#: 52295
2003 WRX Wagon
I can't vouch for replacing all of the cats except the 3rd as i have taken them all out but, what i do to keep from the emissions test is i register my car in a near by small town that has no emissions requirements. All i do is get a p.o. box in the small town and now i have an "address" there where i can register my car to.
how much power gain with timing adjustments??? azn2yunr Engine Management & Tuning 16 06-19-2005 04:50 AM
How much power gain with Espelir JGT 500 with a downpipe? 05STI!!! Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-14-2005 08:56 PM
How much power gain from head P&P work? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-19-2004 01:43 PM
Full Turbo-back Exhaust = uppipe, downpipe, cat-back? wrexsta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-26-2002 05:19 AM
uppipe, downpipe, cat-back, intake JunGdb Newbies & FAQs 21 11-02-2002 02:04 PM
