Welcome to the North American Subaru Impreza Owners Club Monday October 25, 2021
Old 07-31-2021, 06:23 PM   #1
benflynn
Member#: 515308
Default Max injector size on stock ecu
Where is the limit on injector size before the ecu canít handle the small opening times? My 1300 already miss on pump but I imagine itís the dw1300s thatís the issue. Smooth on e85
benflynn is offline   Reply With Quote
Old 08-03-2021, 10:42 AM   #2
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Are you on 16 or 32 bit ecu?
Old 08-19-2021, 11:41 AM   #3
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
I'm running 1300 cc's and have a smooth idle with either pump or E85. you might not have your injector latency correct if you are having idle issues.
GeoNV is offline   Reply With Quote
Old 08-19-2021, 11:46 AM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
on IDs the point where idle starts to get effected with a gas tune is 1700's not really sure about DW but I would assume maybe you're getting to that point with those, wats your AFR at?
Old 08-19-2021, 03:22 PM   #5
benflynn
Member#: 515308
Merpíd 06 sti rom in my o5 fxt ecu. 32bit
Old 08-19-2021, 03:24 PM   #6
benflynn
Member#: 515308
I am using dw original supplied latencys
