Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2020
Old 12-06-2006, 02:12 PM   #1
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
#78 ST, MAXIMUM ATTACK!
Default Tie-Rod Jam Nut Size?
Please someone help; i'm trying to replace the Jam Nut for the Tie Rod, and don't know the size of it..
Anyone please?
ASAP
SiFuSpEc is offline   Reply With Quote
Old 12-06-2006, 02:16 PM   #2
RallySport Direct
Member#: 33174
Chat Email or Phone!
888-457-2559
The Castle nut? They are like a quarter dollar from Subaru.
part number: 023212010
I think I might have a couple in stock here too.
Let me know if you have any questions
Thanks
Rick
801.619.1779
[email protected]
RallySport Direct is offline   Reply With Quote
Old 12-06-2006, 02:18 PM   #3
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
nono the 19mm nut; i don't know the specifications of it..
its displayed as 19mm like this photo ( not mine )
Old 12-06-2006, 04:27 PM   #4
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
bump up
Old 12-06-2006, 06:17 PM   #5
jamesohoh7
Member#: 39070
GTF off my lawn!
Originally Posted by SiFuSpEc View Post
bump up
So, you want the thread pitch? ... off hand, I don't know, but if you're near any reasonable auto-parts store, you can probably pick up a thread-pitch gauge for a few $$ and measure it. It's a little folding tool, in the form factor of a pocket-knife usually.. that has serrated little 'blades' that are marked with the pitch they correspond to (like 1.25 or whatever). You flip out one of them at a time, and try to line it up in the threads of the thing you want to measure... either directly on the threads of the tie-rod, or inside the nut if you have it off the car already.
A good tap+die set will usually have one in it as well, if you know someone that has such a set you can borrow it.
If all else fails, buy several metric bolts in various thread-pitches at your local hardware store then take them to the car and do this same 'match-up-the-threads' test... interlace the bolts on the threads of the tie-rod. Surely, one of them will match up and then you take that bolt back to the store and find the 19mm nut that fits it.
jamesohoh7 is offline   Reply With Quote
Old 12-06-2006, 07:08 PM   #6
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
lol i've went to every parts store and hardware store in the area, inc.
Lowe's
Home Depot
Sears
Advanced Auto
Autozone
Subaru Dealership..
it seems to be a M14 1.5 or 1/2 18 in Standard.. But NO ONE has it.. the lowe's tool had the reading for it but no nut..
So i had to order it from subaru .79 cent nut that should be in by Friday
i'll post the part number when i get it so if anyone has this same problem..
Old 12-08-2006, 01:04 PM   #7
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
well i bit the bullet and bought it,
.74 cents and 2 days to get here..
Here's the part # for future if someone is in same situation;
021814000 ( on the invoice )
021814006 ( label on the bag )
Old 06-21-2019, 01:41 PM   #8
StarkWRX
Member#: 473969
2006 WRX
World Rally Blue
Reviving from the dead because I am curious also.
I have a tie rod end with the first few threads f-ed up and went to measure it yesterday and it was M12x1.25 but now that I'm looking for taps and dies, I'm questioning myself.
Does anyone know for sure? 2006 WRX
StarkWRX is offline   Reply With Quote
lock nut for tie rod stuck (adjusting toe). Fix? xcdhridr Brakes, Steering & Suspension 19 10-07-2009 12:02 AM
Tie rod end jam nut madmax718 Service & Maintenance 1 01-10-2009 05:35 PM
Can't get tie rod lock nut loose sorrowfulkiller Brakes, Steering & Suspension 2 10-19-2008 06:50 PM
Tie Rod Thread Size and Pitch? williaty Brakes, Steering & Suspension 2 07-20-2008 10:56 PM
is there any aftermarket inner tie rods and tie rod ends for subaru? Track Assassin Brakes, Steering & Suspension 2 01-28-2004 12:39 PM
