Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 11-15-2008, 05:45 PM   #1
mrcoder
Member#: 93785
2005 STI
Default Lab results of pressure drops for dirty AEM air filters
Figure 1 page 3
Pressure Drop (inches H20) versus Dust Retained (grams)
http://www.aempower.com/files/dryflo...coarsedust.pdf
and
http://www.aempower.com/files/dryflo...andcleaned.pdf
It occurs to me that AEM Dry Flow air filter users (myself included) can also use this chart to estimate their pressure drop on their dirty filter if it's too inconvenient to measure pressure drop directly. You can just weigh your filter before and after you clean it (and wait for it to dry before weighing).
Thank you AEM for testing your Dryflow filter at the independent lab, and also publishing the results!!!
Now notice that this is also very good information for the owners, not just the prospective purchasers.
FWIW Here's what I learned from this chart: If my air filter weight loss is greater than 60 grams after the next cleaning I give it, I am going to be cleaning it more often. Minimal pressure drops for me, if I can help it!
("Pressure drop" is another word for "flow restriction" if you are new. Pressure drops are baaaaad. Zero drop is gooood for car performance. You do like performance, don't you?)
Would be nice if more manufacturers also got their equipment tested like AEM did.
By the way, I am also sending props out to APS / Air Power Systems in Australia for testing (albeit themselves) and posting both their lab-measured pressure drops and sound pressure levels for their exhaust systems. Their pressure testing results is a big reason why I bought an APS exhaust system even though it was pretty expensive, rather than buying an exhaust from other companies. I have the R2 turbo-back, and it totally rocks. 88dba at the tip but same exact pressure drop as the R1 when cat is present, so R2 is quieter, and less likely to attract some fuzz, yet is every bit as powerful on the dyno (344 w/stock turbo, thanks to Hill @ Agile) as R1 on this application.
Extra kudos to AEM on the integrity meter for forking out the money to get the test done, by a different company (SWRI) rather than doing the test themselves.
SWRI is the company that AEM contracted to do the testing. SWRI also has some other interesting automotive testing articles on their web site also.
http://www.swri.org/3PUBS/D03.HTM
mrcoder is offline   Reply With Quote
Old 11-15-2008, 05:57 PM   #2
mrcoder
Member#: 93785
2005 STI
Default 20 grams of dust in AEM filter causes 1 inch pressure drop
This other chart shows that it only takes 20 grams of dust to cause 1 inch pressure drop.
http://www.aempower.com/files/dryflo...eabusetest.pdf
60 grams of dust is what caused 1 inch in the chart which I referenced in my previous post.
Confused...
OK I guess 20 grams of dirt loss after cleaning (versus dirty weight) is my new target air filter cleaning interval....
Old 04-06-2009, 12:56 AM   #3
jarencibia
Member#: 187021
2004 WRX Sedan
So did you weight your filter yet? I'm interested to see how much dust you would pick up after 10k miles. 60 grams seems like a lot of dust.
jarencibia is offline   Reply With Quote
Old 05-08-2010, 03:01 PM   #4
09rexspeed
Member#: 216923
does it matter if you clean the filter w water or w/ the solution? I bought the solution but its on back order. pm me for response thanks
09rexspeed is offline   Reply With Quote
Old 08-01-2010, 03:01 PM   #5
MRF582
Member#: 48219
. Always drive
the race line .
Bump from the dead, I know. But I'm researching air filters.
Just to put things into perspective for those that get super excited over numbers but have no idea what UNITS those numbers are in...
1 inch (of H20) pressure drop due to a reported 60 (or 20, whatever) grams of dust correlates to a .036 psi of resistance. Yeah, that's zero point ZERO three six pounds per square inch... That means your turbo has to work 0.036 psi harder... OH NOES! THE WORLD WILL END!
MRF582 is offline   Reply With Quote
Perrin Intake tube colapse - AEM air filter test - etc - video Dyno Flash Proven Power Bragging 94 05-26-2007 06:33 PM
AEM air filter cleaning. Absolut Newbies & FAQs 2 05-31-2003 06:46 PM
Does anyone know the new part # for the amsoil air filter? Robmat Normally Aspirated Powertrain 2 05-03-2001 10:57 AM
part # for K& N air filter auricom Normally Aspirated Powertrain 17 04-06-2001 12:34 AM
Does anyone know the part # for the secondary air filter box gasket for a '99 dandbest Technical Forum Archive 4 07-16-2000 02:08 PM
